Question about Toshiba Tecra T9000 Notebook
Wireless problem could anyone help me out i cannot get wireless to work on this laptop any more i have even purchased a usb wireless stick and taken out the wirless device from the laptop it still does not pick up any networks
  • Anonymous Sep 02, 2008
    here we go i cant connect to a wireless connection even thou i no its workong because i pick it up on my xbox my wireless connection r showing 0 when i useally pick up 4 so it cant be my router or i would still pick up the other 3 ? i think ive made it clear ?
  • Anonymous Oct 09, 2008
    the wifi sign dosent even show when i switch on the button. i have a toshiba t9000
    Novelist:
  • 114 Answers
Not all wireless networks can be "seen'. This is because they are not broadcasting the SSID. This is done for security reasons. In order to connect to a wireless network, there are three things that one typically needs: 1) SSID. This is a name for the wireless network. You may not always be able to see this, as it is a common security practice to not broadcast this out. Even if it is not broadcast, you will still be able to connect to it. 2) Encryption type. There are several flavors out there, including the option of none at all. The key here is that this setting must be EXACLTLY the same on both the laptop and accesspoint for proper communications. 3) Encryption key. Again, this must be EXACTLY the same on both ends. Finally, make sure you are in range. Depending on the wireless technology in use, the effective range may not be more than a 100 feet. While initially configuring wireless, it is best to be as close as possible to the access point, and then slowly move away to find the outward bounds of the access point's communication range.
Posted on Oct 10, 2006
First thing I'd do is disable security(enable after connection is fixed) then remove all network drivers that arent being used at the time(uninstall). Next turn off the "Let Windows connect wireless network". I have had better luck with the wireless network adapters connection manager opposed to Windows. Good Luck.
Posted on Apr 04, 2007
I need a better connection
Posted on Nov 22, 2008
4 Suggested Answers
  • 55 Answers
SOURCE: wireless network undetected and problem with wireless lan
first check for whether the wireless switch on laptop is turned on or not u have to keep it turned on .further install the drivers for wireless lan
s_4u_11
  • 535 Answers
SOURCE: my laptop wireless adapter is not working
see the wiress btton on laptop its on or off chak it if its on then remove and reinstall your wireless driver
Posted on Jan 18, 2009
MrObvious
  • 115 Answers
SOURCE: Wireless Not working
I thnk i have you in for a treat.. here is a site that hosts the drivers you need...
http://www.gzrcw.net/drivers/toshiba/Tecra/drivers_1199.html
if that doesnt work i found the name of the driver so that you could continue the search..
tm1wlanx
Good Luck... pls dont forget to rate me..
Posted on Jun 22, 2009
I have bought a netgear wn111 wireless usb adapter and i have no driver cd. As i have bought this to connect my pc to the wireless network, i cant access the internet to download the drivers onto the pc. I...
If you have access to the Internet using a LAN cable, then download the Netgear wireless USB adapter to install the driver. After downloading you can remove the LAN cable.
You can also save the driver from your laptop to an USB memory stick and then install the driver in your computer with the USB memory stick.
May 23, 2011 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
I have a dynex enhanced wireless g network adapter. The computer that uses it is a windows xp. The computer will recognize it and it will show up but I can't connect it to any wireless networks. There is a...
Does the stick see any other wireless networks? Can you try creating an Ad-Hoc network from your other laptop to this one through the USB stick? If the answer to either of these two questions then the stick is working fine.
I would check to make sure your router is not using solely a N network type because the USB stick will not support it.
If you are using a duel band router and you are currently using the 5ghz network then the USB stick will not detect this either.
Lastly if your network is not being broadcast, your laptop may connect to the network but your USB stick will not be able to locate the network.
You can also try power cycling the router (unplug for 30 seconds) and then search for networks again.
Thanks,
Pat
Nov 07, 2010 | Dynex Wireless-G USB 2.0 Network Adapter
Don't have a place to install the cd to download software trying to install netgear G54 wireless USB Adapter to IBM Thinkpad 2662
Find another computer with a CD-drive and a USB port.
Purchase a USB memory-stick.
Connect the memory-stick to that computer, and copy all the files from the CD onto the memory-stick.
Move the memory-stick onto your computer, and install from the files on the memory-stick.
Sep 27, 2010 | IBM ThinkPad X24 2662 Notebook
Have re-installed win xp on an IBM T42 laptop, but can not access the internet to update drivers ect
1. if you have wireless, purchase or borrow an add on usb wireless stick. this will allow you to access the internet and add in your missing drivers. 2. or add in a pci card that has ethernet connection to get your drivers. 3. use someone elses computer and download the drivers from the IBM site, put them on a usb stick and then apply them to your unit, (ie more the ethernet driver as a primary and then you can download the remaining ones as you go after it is working. hope this helps.
Aug 25, 2009 | IBM Computers & Internet
My sony memory stick pro duo doesn't work
It sounds like the software on the card has suddenly dissappeared. Try downloading the software from sony back onto the card. Let me know if this helps.
Jun 19, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
I have a ASUS N10 laptop with windows xp os.Wireless was working fine on it for atleast a week after purchase..After a windows update it has now stopped working.Every other pc or laptop in the house works...
I forgot about the update that you mentioned. Yea go into safe mode and choose the latest date that the wireless card was working properly, then let the machine reboot and see what happens. Let me know.
May 14, 2009 | ASUS N10Jc-A1 Notebook
Compaq presario 1250, Wireless internet
you need to buy a pcima card if there is a slot on the side of that laptop to fit it. if not but it does have a usb port you can purchase a wireless stick... that plugs into the usb port. very compact, about the size of a usb flash drive.
Robert
Sep 19, 2008 | Compaq Presario Notebook
I have a Toshiba Satellite notebook with Vista Home and NAV 360 and recently purchased a Sierra Wireless Mobile Broadband USB modem T-Stick D597. When I try to install the T-Stick, I keep getting an error...
You might want to disable the WiFi that is built into your laptop before installing that device. It is very possible that the built in WiFi is conflicting with that Wireless Broadband Device.
Aug 16, 2008 | Computers & Internet
Sony vaio PCG CIXD picturebook laptop
You should be able to use any usb wireless network adapter, or any cardbus type II wireless adapter. BUT if you are running windows 98 or ME or an older version than xp... before you purchase one, go to the manufacturer site and be sure that there are drivers for the version of windows that you are running. Here is what to look for and a link to some items that may work.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833129133
http://www.newegg.com/Product/Product.aspx?Item=N82E16833124280
Mar 30, 2008 | HP Pavilion dv6000z Notebook
Belkin N1 Wireless Adaptor not connecting on PC
what the adviser meant was your pc cannot provide enough power to the usb port to power the unit, assuming you have tried other ports and it still wont work; you will need to either purchase a pci usb 2.0 card adapter or purchase a mains powered usb hub and connect to this instead.
Sep 15, 2007 | Belkin N1 Wireless USB 2.0 Network Adapter...
Computers & Internet Logo
1,145 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
