Question about Frigidaire FEF355 Electric Kitchen Range
Frigidaire Stove We just purchased a new stove and my husband is having trouble getting the oven changed over from Natural gas to bottled propane. He got the top burners to work. He is following the instructions and don't understand why it won't work. We need help.
  • 1 more comment
  • cathaer Nov 05, 2008
    He did change the orfice. We called a local service rep and he told what to check and he got it to work. Thanks for getting back to me.
  • Debbie Malicoat Nov 26, 2008
    We can not get the flames of the oven and broiler to reduce in size. They come half way up the oven. The orifices corrected the top burners but can not adjust the oven. We have adjusted the air flows but that only adjust the color of the flames not the size. Any help????
    Deb
  • butch welch May 11, 2010
    what wont work. Did you change the orfice.
    Sergeant:
    Champion:
  • 324 Answers
You may have to adjust the flame size so you can simmer.
Posted on Nov 05, 2008
Can you use propane for this stove ?
no info on stove so cant answer correctly --but most can be converted or have a conversion kit available do online search of make and model
Sep 02, 2017 | Kitchen Ranges
I've just converted my stove from natural gas to propane and the oven and broiler flame are both to high, how can I lower them?
When converting from natural gas to propane you have to switch the regulator to propane. then on most modern stoves you have to turn the orifice hoods down to adjust for the higher pressure of propane. there are some stoves that you have to purchase a propane conversion kit with different orifices for the burners and oven burners.
Oct 01, 2015 | Kitchen Ranges
I need to change my frigidaire oven orficis from natural gas to propane?
how do i change my frigidair cook stove from nataul gas to propane modle fgfl67dck
Sep 16, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Frigidaire Stove, Model # FGF316ASA. It was changed from propane to natural gas. The oven works well. The burners, however, will only burn a low flame. Is there a solution for this?
When converting an appliance from propane gas to natural sometimes a technician will drill the orifice to a larger size rather than replace the orifices. Either way is fine, but sometimes the orifices don't get drilled to the correct size. The regulator must be on the propane setting if it is a convertible regulator. If your oven is working fine.... the top burner orifices probably need to be checked that they are the correct size. A simple fix.
Tom
Aug 11, 2010 | Frigidaire FGF316 Gas Kitchen Range
I purchased a new natural gas range a couple years ago for our cabin. I need this range to use propane.can this oven be changed to use propane instead of natural gas?
should be able to change orifices to propane. some ranges offer these on the back of the stove or you can buy them at a local parts dealer. take your model # with u when you research a part
Jun 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Problem gas cooker
Go on line to westing house.com and look up your model, go to the help page and ask for their assistance, gas is not something to fool around with, I suspect it is the orifice that have not been converted to propane, I had a similar problenm with the stove top burners, and the orifices needed to be changed to (converted ) to run on propane gas.Some times manufactures send the converter orfices but most of the time you have to ask for them if you are running on propane, most stoves are set up for natural gas not propane.Most of the time the store clerks don't ask you if you will be running on propane , you have to tell them and the professional who installs the unit needs to install the orifices. Please be careful! If you installed the stove your self, you need to contact a professional installer to correctly adjust these .
Jan 05, 2009 | Frigidaire FGB24S5A Gas Single Oven
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
How do I adjust the flame on my Frigidaire model FGS383BADK stove?
its going to be listed in the installation manual ,not use and care, youre going to need to convert oven for lp gas. i would call the manufacture with the modelk number and ask for hte coorect conversin kit, for such a thing
Nov 03, 2008 | Frigidaire Ovens
Change from lp to propane on my whirlpool stove
Propane is LP...(i.e. Liquid Petroleum)
The burners are working only as a fluke. It is extremely dangerous to operate a natural gas stove on propane. STOP USING IT IMMEDIATELY. Call your local propane supplier and ask them about converting it to LP/Propane.
Jan 15, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Frigidaire FEF355 Electric Kitchen Range Logo
174 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
