Question about Abit KT7-RAID Motherboard
New Hard drive xp install
I have and Abit kt7a-raid motherboard. I bought a new Seagate 320 gb hard drive. I am trying to do a fresh install of xp home on the new drive. I slipstreamed service pack 3 into my install disk, and updated the bios to the latest version available on abits website. I tried to install xp several times before each of the steps mentioned. I have gotten checksum errors and the bios defaults have been restored. Xp will start to install from the disk I can get to formating the hard drive and copying the install files to the hard drive. At the first restart, the hard drive is not found. When I press del and enter the bios settings the hard drive is shown and size is listed.
I haven't recreated the partiation on the hard drive since up updated the bios, I am going to try that now and create a relatively small partiton because I am tired of waiting for it to format a 320 gb drive.
Any help would be great thanks Bruce
  • 1 more comment
  • flyandride Nov 06, 2008
    The drive is and IDE drive. This is an old motherboard circa 1999 or 2000. The bios I updated to is A9. The drive does show up in the bios. I installed it as a slave drive on the same IDE channel with the old hard drive and it seems to work fine, although it didn't recognize it as formated even though I formated it with the install disk. I used autostreamer to slip stream service pack 3 into my install disk. Maybe it didn't work correctly. My XP disk does not have service pack 1 so it won't recognize the large drive if the slip stream was not successful.
  • flyandride Nov 07, 2008
    I ended up running Maxblast 4 that came with my previous hard drive setting it up as a boot drive and cloning the current install of XP onto the new drive. Maxblast 4 popped up a window and told me that my system was not configured for hard drives larger than 137 Gb and offered to fix it. I said yes and it has been smooth sailing since then. I don't know what it changed. The seagate software that came with the new drive wouldn't even recognize the drive, even though I could see it in the bios setup utility and in XP.
    I was able to install a new version of XP over the cloned version without any trouble.
    Thanks for the help.
    P.S. I tried to get a copy of "Hirens Boot CD" and the only version I could find was compressed as a .rar and was concerned about unziping it, not knowing for sure what would be inside, plus having to find anouther utility to do that.
  • Frank
    Frank May 11, 2010
    did the BIOS detect it as what IDE or SATA???
    I asume 320GB is SATA.
    Genius:
  • 1,605 Answers
OK!
MS Windows is funny thing. it want what it wants.
you have to use Windows Installation Disk to format the 2 HHD. no way around it. even you formated with the disk manager.
once you have the Windows Formated the disk, you should not have the error, and you should be able to slipstream the application.
good luck
Posted on Nov 06, 2008
  • 781 Answers
If your hard drive is SATA and your windows disk does not have SATA drivers on it it will not find the hard drive this is your problem
http://driverpacks.net/DriverPacks/
Go to the above site and download "driverpack mass storage" and slipstream into your windows CD.
I have done this with one windows install disk that could not find disk then it worked perfectly
  • David
    David Nov 06, 2008
    Try checking hard drive with "Hirens Boot CD" it has many different utilities on it
    Sometimes when I have had this problem I have used "Super Fdisk" and done a full format with it
    And found drive on windows install.
    Give it a try.
  • David
    David Nov 07, 2008
    If you go to the Hirens boot CD web site you will see all the programs on it
    Also it is a very useful CD to have I have cleaned up numerous computers with it.
    Lost passwords. No hard drive, no MBR etc.
    Get it for futures use very handy
320 gb seagate hard disc formating problem
Send your seagate back under warranty (RMA) they will send you a new one.
May 26, 2010 | Western Digital (WD3200JS) 320 GB Hard...
How to make partition in a new seagate freeagent Go 320 GB
Here is a link to Microsoft on how to get to and use disk management. I do not know what operating system you are using but disk management has not changed a lot. The link below references XP and if you follow this step by step it will work great.
http://support.microsoft.com/kb/309000
Mar 10, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
No hard disk found......
You must first press f6 to load the SATA drivers for the hard drive before you go forward with the install.
Good Luck,
NOLA Tech
Feb 06, 2010 | Seagate Barracuda 7200.10 320 GB SATA Hard...
I an trying to set up raid 0 with two 500 gig wd hard drives on my abit awd9-max on a new install. I am running xp.raid is enabeled in bios. I hit f6 on windows setup installs dirvers but seems to be a...
In bios make sure the raid chipset is active. Ususally there's 2 one needs drivers one doesn't. I use the one that doesn't then in bios there should be a way to set up your array. Raid 0 is striping mode so you should only see one hard drive,the d drive should be the cd/dvd device. If this is right then you did it right.If it were raid 1 then you would see both hard drives,because one is mirroring the main drive for backup.
Dec 31, 2009 | Abit AW9D-MAX Motherboard
When I boot up i am prompted to press cntl e or f4 for raid utility. I am trying to clone my ide c drive onto a new seagate sata
Some older mainboards only allow you to use SATA after you have declared your disk through the raid utility. Watch out when you do so that you select the right configuration (Raid 0)
Aug 10, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
ABit-Th7 raid Drivers
This problem is very simple.... Using RAID in booting in cd/dvd cannot be done in this kind of processing. you have to change the setting of Hard Disk and CD/DVD to IDE in BIOS . To change the setting in the BIOS you need to press the Delete After you power on the computer.. In Main menu in the bios you will find the hard disk or cd/dvd settings to IDE, SATA, and RAID. change both hard disk and cd/dvd to IDE configuration. make sure the first boot in the Boot menu is the cd/dvd, where your windows cd installer is inserted. Save the settings by pressing F10 key in the keyboard.. I have the same problem as of you because i try it to change SATA, RAID but cannot boot to cd and cannot detect the hard disk when installing OS, but in IDE settings its okay.. and it works perfect.. after you installed the windows properly, you can change the Hard Disk or cd/dvd configuration to SATA or RAID. TY
HOPE I CAN HELP
Dec 08, 2008 | Abit KT7A-RAID Motherboard
Version number?
Bios 7N is for the following
  1. Support up to 137GB HDD and above.
  2. HPT 370 RAID BIOS version 1.11.0402. The RAID function is for KT7-RAID / KT7A-RAID only. This BIOS version is also for non RAID boards and HPT BIOS will be automatically disabled while RAID controller chip not detected.
Version A9 is the last update
  1. Fix nVidia GeForce4 Ti 4x00 AGP card compatible issue with Windows XP.
  2. HPT 37x BIOS version 1.11.0402.The RAID function is for KT7A-RAID only. This BIOS version is also for non-RAID boards and HPT BIOS will be automatically disabled while RAID controller chip not detected.
  3. BIOS Compile Date: 7/11/2002.
LINK
The above link is for the KT7a with Raid, however the standard KT7a also lists the same bios updates, the KT7a Raid ver1 lists different bios that won't be compatible with your board.
Apr 12, 2008 | Abit KT7A Motherboard
Installing windows xp with 2 new sata wd 150g 10k 16m raptors to NO avail...
I guess you are trying to install Windows XP in RAID 0 configuration. If so, you need to do several steps:
1. Configure the bios to work as RAID 0
2. Download the RAID driver from the mobo vendor site, copy it onto a floppy disk and have it ready for when Windows asks for it.
See this link for detailed example http://www.duxcw.com/digest/Howto/mb/abit/kx7-333/raid1.htm
In SATA there is no master/slave configuration, so there is no need for jumpers.
I hope this answers your question.
Dec 26, 2007 | Western Digital (WD1500ADFD) 150 GB Hard...
How to install a new seagate hard drive?
I have one thats ide ultra, & my computers see it as a disc drive, like a cd drive when i put it in an external seagate case. but when i put it in as an internal it shows up in cmos w/ 320 g space, & no matter which pin config i use it doesnt show when the os is booted. I enabled LBA like it says on the drive, & tried all the other options in CMOS & havent got it to go yet, but it sounds like its running perfectly when it powers up. it'll go, but its actin crazy. ill post it when i get that bastard.
May 02, 2007 | Seagate Barracuda 7200.8 300 GB Hard Drive
Abit KT7-RAID Motherboard Logo
129 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
