Question about Canon GL1 Mini DV Digital Camcorder
Canon CCD GL1
When I turn on the camera, nothing happens and the screen is blank. When I put it in VCR mode, it turns on, the power button lights up, but there is a quick beep, which has never happened before.
Hey hill,
This happened to me one time. Judging from the date of this, you probably have found a solution. The bottom line is that the camera has accidentally been placed in "Standby" mode. It is the lever surrounding the back of camera record button. When this is moved to standby, the VCR mode works, but nothing for the Camera mode. Hope this helps.
Posted on Jun 16, 2008
When i chage the option of oFF to CAMERA nothing turns on and when I change the option OFF to VCR the screen just show strange symbol and SP and it does not work
just so you know, your camera model was included in the list for what we call the "ccd program". this program has ran for 5 years and unfortunately ended march this year. sony gave free repairs for cameras and camcorders affected by the defective ccd imaging sensor before the said date. issue with the camera shows a black or distorted screen in camera mode. but the you should still be able to see the indicators on the screen. when switch to vcr you should be able to play back previous recordings that you made. better to really make sure its a ccd issue, play a tape that you're sure contains a movie recording and play it, then set it to camera mode and see if you get just a black screen. if you try recording using a tape, you may see nothing but should hear the audio part. if this is what's happening we can be sure it's a ccd issue. if your camcorder just won't turn on in camera mode, maybe the power switch turned defective or it can be other parts of the unit that stopped working.if this is the case, then of course, your unit may require service to address the problem.hope this info helps.thanks:)
Aug 25, 2010 | Sony Handycam DCR-TRV250 Digital Camcorder
Canot see subject trying to photograph
Hello, You should contact Canon about the situation. Let them know you are aware of the problem CCD sensor on the S1 camera. Actually S1 is repaired free of charge because of the CCD problem. You should suggest that your camera probably has the same defect as the S1. See what they say. If you need more info please advice. Arpi
Jul 28, 2007 | Canon PowerShot S2 IS Digital Camera
My screen is very dim, my pictures turn out clear and light but i cant see anything on the screen, even stored pictures. I have to put my memory card into a different camera or upload my pictures to see...
This problem is only related with back light in lcd screen and has nothing to do with ccd imager chip as explained by previous expert.
LCD screen is not getting enough voltage to lit back light to show its image thus you get darker image.
I suspect back light circuit section at main board got physical damage due to drop of camera. Visual check by qualified camera tech is needed to fix it.
Aug 25, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
When I turn on the camera, nothing happens and the screen/view finder is blank. i checked the standby switch its off. when i press record it will record but on the tape it is just a black screen? any ideas...
i know exactly whats wrong! the same thing happend to me.
1. turn off the gl1 2.look at the record button with the lock and standby switch 3.flip the switch all the way to standby because it might be stuck in the middle 4. turn on your camera
Dec 03, 2009 | Canon GL1 Mini DV Digital Camcorder
Dropped Canon A1000 IS and it won't turn on
if u turn the photo mode on and the lcd is blank in black color or white or fuzzy pictures and same on pics then it is
possibly a CCD failure !
but u are lucky canon is repairing it free of cost just see the link just call them they tell u how to send ur camera dont worry if u are not on list just call them
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
Apr 08, 2009 | Canon Powershot A1000IS Digital Camera
Digital ixus i power shot sd10
Could be deffective CCD chip. CHeck with Canon service, they repair it for free
Jan 20, 2009 | Canon PowerShot SD10 / IXUS I Digital...
Digital Camera Malfunction
its a problem with the iris of ur camera and also sumtimes the CCD .... get it repaired from a repairman
Sep 05, 2008 | Canon PowerShot A70 Digital Camera
The camera function will not work
Hey Uttado,
Check to see if the stanby lever that surrounds the record switch on the back of the camera has inadvertently been put on standby. If this has happened, the VCR will work but not the camera. Move it off of lock to standby and it should crank right up.
Apr 10, 2008 | Canon GL1 Mini DV Digital Camcorder
Canon gl1 - no picture in the fold out lens
By placing the POWER switch into CAMERA mode, you will then be able to press the MENU button, and access all camera adjustments....including the LCD function.
Mar 05, 2007 | Canon GL1 Mini DV Digital Camcorder
Blank Screen
Camera is designed with one cirucit board to control most functions. The camera probably has a damaged component or dead CCD chip. There is no economical solution but replace the whole camera because the part is not available to replace it.
Mar 12, 2007 | Vivitar ViviCam 3500 Digital Camera
Canon GL1 Mini DV Digital Camcorder Logo
174 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
