Question about Panasonic PT-60LCX64 Television
Air filter notice
Tv will not turn on
  • Anonymous Apr 25, 2009
    tv will not tur on green light flashees
  • 32 Answers
You have a fwe things that can be wrong. Either your switch is bad which is located on the lamp cover and is also part of the back cover of the television. If you remove the cover you will see the switch I am referring to. You could also have a faulty fan, or just plain dusty on the inside. Start with that and if you have futher problems then repost your question.
Posted on Feb 20, 2010
How do I change the filter that my thermostat is telling me needs replacing?
Your air conditioner uses the furnace blower to circulate air. The filter to be changed is the one in the furnace.
Aug 21, 2014 | Heating & Cooling
Valve breather shots out oil when engine is running
I do not think this is a gasket issue, if the machine has beed tipped up oil will travel up the breather tube and enter the air filter case, over filling will also cause this, if its been tipped it will clear if you run it for a time with the filter off.
Jul 03, 2012 | Toro Lawn Mower With Toro Power Tools
When the tv is on,Theres a cloud starting to appear in the middle of the screen and really noticeable on a black background,Seems to be getting bigger..!
If you have a rear projection LCD TV the cause is excessive heat, that in turn is normally caused by dirty air filters or poor air flow.
If you clean the air filters out it may halt the progress of the problem.
Dec 18, 2010 | LG 50PK550 50 in. TV
Open air filter box to replace filter on a 2000 dodge caravan
the filter element is actually below the box that says air filter element. You remove it from air intake and disconnect from frame and element case. The element is in a black box behind drivers side headlight, facing sideways. Its a pain, but working on this particular engine is rough. They designed it to be worked on at a shop with specialized tools. Average wrenches and sockets don't have enough room to turn! Since this element is hard to replace, you'll notice a marked improvement after changing this bad boy/
May 24, 2009 | 2000 Dodge Caravan
Cleaned the plates and the back filter and went to turn it on and it will not turn back on
Be sure the tab on the filter is making the safety switch click in and stay in. Sometimes, all you need to do is push in on the lower right corner a little and it will start.
Mar 25, 2009 | Alpine Air XL-15 Air Purifier
Panasonic rear projection tv air filter
heres what you do remove front panel "little black door below the screen" get some software cleaner "air" clean all in that box that you just removed the cover from also you might try cue tips and alcohol let dry thoroughly put cover back on and turn on tv it should work if the message comes on again turn the power on and off about 6-10 times and turn back on it should turn on and be fine .if that happens again just open the cover and blow with sopftware clean.sound wierd but after alot of experimenting i fixed my tv that i bought as a salvage because of that error message bhope it works
Feb 19, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Oil in my air filter?
This is normal. The air filter is re usable on a lot of two stroke engines and you wash the filter and oil it lightly to help catch dust.
Nov 10, 2008 | 1974 Yamaha DT 360
Panasonic PT-60LCX64 Television Logo
163 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
