Question about Philips Magnavox Learning Universal Remote
My remote control for my t.v
No matter what button I press, I just dont get a response.
The batteries are new.
It was quite some time in between using it. ????????????
    Problem Solver:
  • 7 Answers
Make sure the batteries are in correct alot of people make that mistake . There should be a diagram inside the cover or under where the batteries go. Also try streching the springs out a bit and clean them with a alcohol pad. Also make sure that there isn't anything blocking the little window/reciever on the tv. If that dont work you may have to replace the remote.
Posted on Nov 11, 2008
No response when remote control buttons are pressed.. I put new batteries. but not work..
Does the unit work from its onboard controls or is this only a remote control failure?
If the latter...
Try this advice:
"Dead" Remotes Can Be Saved
How to Re-Start Your "Dead" Remote Control
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the unit.
If it works, Great!
If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Find new or replacement remotes:
or eBay: search for "(model) remotes", check the 'include description' box. Usually cheaper than the vendors.
Apr 23, 2011 | Panasonic SC-PT464 Theater System
Hi I have a Panasonic IDTV remote control that was working and now isnt The failure began as a slow response when any button was pressed and now no response at all New batteries haven't remedied the...
My idtv remote has only just started to break my ok button has stopped working.this is due to loose connections inside the remote. Drop the remote from 3ft
Dec 09, 2010 | Panasonic Televison & Video
New ML-L3 remote light doesn't shine
It's an infrared light (like on the remote control for your TV) and you shouldn't be able to see it.
Set the camera's shooting mode to one of the two remote modes. Quick-response remote takes a picture as soon as you push the button on the remote. Delayed-response remote waits two seconds so you can hide the remote behind your back.
Feb 11, 2010 | Nikon ML-L3 Remote Control
2001 ml320, remotes quit working. new batteries,
Turn ignition switch to position II. Turn ignition switch to position 0 and remove key. Within 1 minute: Press and hold key lock button. Press unlock button 5 times. Remote control should now operate system. If not: Repeat procedure.
Key remote control added or replaced. System malfunction.
Keys can only be programmed using diagnostic equipment
Jan 09, 2010 | 2002 Mercedes-Benz C-Class
Remote will not control DVD/VHS
Tries change with new bateries,clean the The IR infered in the DVD/VHS combo unit,and the remote.
Aug 16, 2009 | Panasonic DMR-ES35VS
No response to any button on remote or tv except power button
Press the 'Favorite' button on the remote. You may have accidentally pressed it. It locks the channel. Pressing again unlocks.
Apr 22, 2009 | iLO 3200 32 in. LCD Television
My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Aug 03, 2008 | Televison & Video
Accidentially dropped something on remote.
Replace the batteries for starts. If the remote was having any buttons pressed for a long period of time, the power capacity of those batteries is quite diminished...accordianman
Mar 16, 2008 | RCA RCR860 Remote Control
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Sep 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Go Video DVD player remote has gone haywire!
it sounds like your remote has got damp or over time the dust builds up behind the buttons you should be able to take the controll apert and remove the buttons check the pads are clean and not greasy then wipe over the board with some clean cotton cloth where the buttons pads press on to activate usually its just a bit of grease but check their is no button jammed it sounds like this could be the case as you get a different response to pressing the play button so try this first then if dont work still clean the buttons and pads be carefull not to dammage the pads they should come out all together and have little black pads stuck to them make sure their xlean and grease free if this still dont work then you can get but make sure its not one of the cheaper ones a all in one remote this should solve your problem hope this helps
Mar 07, 2007 | GoVideo DV2150 DVD Player/VCR
Philips Magnavox Learning Universal Remote Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
