Question about Hoshizaki Cubelet Ice MakerDispenser Water Cooled LED Sensor Operation
Compressor starts then shuts down like head pressure building to high
Km-450mab starts to run water for one min then compressor kicks on for about half min or so then sounds like head pressure high -boggs down and kicks overload out.kicks over load out each time trying to start.compressor sounds good first time comes on
  • 51 Answers
Make sure that your condenser fan is working. If your unit is water cooled make sure you have water flow.
Posted on Feb 20, 2009
Air Compressor trips breaker under load. If I remove the belt the motor runs fine, spins freely as does the compressor pump. With the tank pressure empty, the compressor starts and runs fine. When it...
Most people recommend replacing the motor capacitor in this situation, since a faulty cap will reduce the starting torque. But in my case the check valve was the culprit - there was too much back pressure on the head.
Oct 22, 2013 | Campbell Hausfeld VT6290 2.0 HP 20 Gallon...
Im told my orphise on my a/c is clogged
if the orifice is clogged the a/c compressor should, with motor running, kick in when you turn on a/c. it will run for 30 to 45 seconds, pulling down engine VERY slightly but noticeable. then the high pressure switch will activate and compressor will stop. if its not completely clogged it will run loger, even a few mins and maybe start to cool a little. when pressure drops enough it will start again and should do same thing over & over. if compressor never starts running it may be a fuse or relay or low on freon. it has a low pressure cutoff also and will not operate under low press, just like high press. cutoff wont let it run with too much. so a cycling compressor that pulls engine down would be proof of clogged orifice
Oct 16, 2011 | 1994 Lincoln Town Car
2000 mazda 626 4 cyl a/c problem - unit runs for 15- 20 min then compressor shuts down. If you shut car down for 20 - 30 min a/c function will resume
Might be time to get some r134a freon added. When the car sit's it will build up pressure and when the pump kicks on it looses the pressure and goes into safety mode to not burn up the pump. If you do it yourself get the dye and pag oil also with the freon. It is very tricky to do it yourself so follow instructions carefully. Then check with UV light to see if it's leaking.
Jun 29, 2011 | 1999 Mazda 626
I have an older camper with an coleman mach 3 unit. it runs and cools fine at night. but it the heat of the day the compressor kicks out. after 15 mins. it starts back cooling for 15 mins or so. if i keep...
Have you checked the high and low pressure switches on the unit? If you are cycling on and off, look at your pressure switches to see if they are opening during operation. Also, when was the last time you cleaned out the condensing unit coils with soap/degreaser and clean water?
Jan 21, 2018 | Coleman Mach 15 Air Conditioner
My compressor runs and builds pressure but, with nothing touched all of a sudden does not produce the same amount of pressure as before, it will not run my printing machine. What should I check?
Does the compressor have enough CFM to run the printing machine. Will the compressor build up pressure and shut off if you close the discharge valve at the tank. Your printing machine may simply be using to much air. If the above items are not the case you may have a faulty check valve in the receiver tank or valves going bad in the LP or HP heads. The valves may also simply have carbon build up or dirt of some type not allowing the valves to seat properly. I would start at the check valve. One way to check the check valve is to see if you have air blowing from the bleed off line at the pressure switch all the time. Another way to check is loosen the fitting at the High Pressure head an see if you have air blowing continously. Caution do not remove the fitting at the head completely. If the check valve is bad you will have high pressure air blowing until the receiver tank is drained.
Feb 23, 2011 | Ingersoll Rand Type 30 Fully Packaged Ir...
My GE portable a/c will cool when I first turn it on. The compressor kicks on and it cools fine, but after it runs a few minutes it kicks off and never cools again. The fan just runs. It does not appear...
I would say that if it starts cooling when it's turned on, then it has freon in it. Sounds more like it's kicking off on high head pressure, meaning the condenser is not getting cooled, head pressure builds up then a safety limit switch shuts it down to save the compressor from burning out.. Is there a condenser fan maybe not operating? or are the condenser coils clogged up with dirt?
Jul 15, 2010 | General Electric APE08AK Portable Air...
Unit does not cool. Original unit was replaced because of defective compressor. Replacement unit worked in store but now does not cool and alternates blowing cool and warm air.
Is this a window unit? Sounds like the compressor may be cutting on and off. That would cause the alternating air temp you are feeling. Make sure the condenser fan is running. If it isn't running head pressure will build up on the compressor until it shuts down. Then the pressure will equalize and the compressor will kick on again. Also check your filters and the condenser coil to make sure it is clean. Let me know what you find.
Jul 08, 2010 | Frigidaire Heating & Cooling
Have a husky 19 gal 1.5hp it kicks on when first start to work and when it builds up air and i use it and when it wants to kick back on it wont i have to wait till it cools down.
Is there an option for you to run this compressor on 220 volts vs 110 volts??? If so, you may want to convert it by following the re-wire instructions on the motor or wire access plate/instuction book. The reason your compressor won't fire up again after building pressure is the head pressure is to great at restart and 110 household current is not enough to give the power needed to turn the piston. You'll need to replace the plug and have someone run a 220 volt circuit once the conversion is completed.
Jan 18, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Model KM-450MAB--Ice Machine Making Beaping Noise
Keeps on beeping? Every 3 to 4 seconds? Try putting the thermostat wires together. An open bin thermostat will cause this problem and the board see it and starts beeping.
Oct 07, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
Ice cube cycle time very high
i suspect a defective liquid line or pump down seleonid coil. just make sure you hear the "click" when it starts up if not the selenoid coils could be defective. also verify that the condenser fan is running,because if not you are short-cycling on high head pressure. please contact if you need any additional info
Jun 11, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki Cubelet Ice MakerDispenser Water Cooled LED Sensor Operation Logo
238 people viewed this question
Top Hoshizaki Kitchen Appliances - Others Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Hoshizaki Kitchen Appliances - Other Expert? Answer questions, earn points and help others
