I have a GO VIDEO mod. HT2015. I turned off the power and left the house. When I returned, it had somehow turned itself back on. I turned it off again, but now I have absolutely no sound at all. Connections are fine, and no connections have been changed. What gives?
  • handeemom Nov 05, 2008
    It is plugged in to a surge protector (high end), which I thought was to prevent this problem.
  • handeemom Nov 06, 2008
    Thanks for the suggestions. Unplugging the unit solved the problem. I guess I threw my money away on that expensive surge protector. Your quick responses were greatly appreciated.
    Sergeant:
    Novelist:
  • 196 Answers
As the device was OFF when you left .and got ON automatically .the electric supply of your house just would have gone for sometime and then came  on again .due to this the GO video device would have turned OFF then ON again.in this procedure the electric component on the circuit board of your device  which was controlling  the sound got  blowned off so there is no sound.check on the main board of the device and get that component replaced and your device will work properly.
or remove all the wiring connections connected externally to the device and then wait for some time and then reconnect all the wires again.it should work if it is not due to the component failure.
Posted on Nov 05, 2008
  • 790 Answers
Hello!!
Check the input connections again... Remove and insert the cables again ..
    President:
  • 624 Answers
This sounds like a problem with the microprocessor. You may have had a small power surge in your home while you where out and it could have affected your Go-video machine. A problemm with the microprocessor could be turning on the mute switch (which is a transistor on the circuit board) from the malfunction. The only real user fix for this would be to unplug it for about an hour or 2, then plug it back in again, this should reset the microprocessor. If it doesn't help, you should take it to a service center and get an estimate to see if it is worth fixing.
  • Dave DeGain
    Dave DeGain Nov 05, 2008
    Surge protectors are good to have but they are not perfect. But the unit turning itself back on is a mystery. Maybe it did not take a surge, but it still sounds like a microprocessor problem to me, it is too unusual of a problem to be a loose cable or anything like that. Most electronics have power going to them at all times, just enough to keep the microprocessor on stand-by. It can still be a problem with the microprocessor. Most problems with electronics require a high degree of electronic troubleshooting skill to isolate accurately and the proper tools. Please try to do the reset procedure I described previously, unplug it for an hour or two, then plug it back in and see if it works.
    Please rate this solution, accept it, or do not accept it, it's your choice.
    Let me know if I can be of any further help.
    Dave
  • Dave DeGain
    Dave DeGain Nov 06, 2008
    I am glad that my solution helped you with this, could you please rate this as a "FixYa!!
Engine problems
Sounds like it could be the kicker spring. If it is getting weak it could be not fully returning which in turn is still engaged while it's running. I would pull the cover and see if there's any debris in the housing. Sounds like it could be the spring or the assembly itself, but you won't really know until you pull it apart.
Nov 02, 2013 | Honda CRF 250 R Motorcycles
Turned off by itself and wont turn back on. How do i fix it, so it will turn back on?
take apart, clean and do xclamp mod. make sure everything is tight. but first just try a new power supply. good luck
Oct 25, 2010 | Microsoft Xbox 360 Console
Marantz sr780 whole house system
try speaker a and b function unplug unit for a couple of hours. check your sound field.
Jun 01, 2009 | Marantz SR-780 Receiver
Recoil not returning rope when pulled
There is a spring inside the pull cord housing that makes the cord come back in, it probably undid itself, remove the housing cover and rope assembly and you will see the spring, you need to retighten it and place everything back. hope this helps
May 31, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
PSP doesnt read even with new laser
if the psp still turns on and the memory card reader works i suggest you pay to get your psp modded.with the psp modded you can play the games of the memory card with out even using the umd drive.i got mine modded a while backs and i love it you can even play emulators and homebrews.hopes this help
Feb 03, 2009 | Sony PlayStation Portable (PSP) Console
360 problem
hi has your xbox been modded in any way or has the warranty been broken if so and your box has been modded and had firmware flash it may be corrupt even if it hasnt been modded it may be corrupt. this may be a problen with the rf board aswell .do you turn it on using controller .how long after your plug it in does it switch on any problems email me at
omega_mods@hotmail.co.uk
Oct 07, 2008 | Microsoft Xbox 360 Console
Reset left margin
Turn machine ON and return to what is set as the left margin. then press the MAR REL key (upper left side) one time and then press the BACKSPACE the number of times to get where you want to set the left margin.
Once you are at the desired position for the LEFT MAR then press LEFT MAR ONE time and it should be set OK.
Hope this solves your problem, sneaky pete
Jun 12, 2008 | Olympia Mastertype 3 Typewriter
DVD drawer will not open
I had the same problem with mine and what I had to do was take off the outer case and unscrew the 4 screws that hole down the dvd player in side the unit and left them out.
For some reason it was binding on the dvd player and would not let the tray slide out.
Hope this will help you out off the mean time.
Oct 28, 2007 | GoVideo HT2015 System
Xbox prblem
Did you try to somehow mod or alter you hard drive?
Apr 10, 2007 | Microsoft Xbox Console
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
