Question about Dell Inspiron 6400 Notebook
Why does sprint ad freeze my computer
My computer sticks in euchre when a sprint ad comes on, it is when the card dangles i am unable to click nothing.
  • 3,940 Answers
Try updating your Java and flash player
www.java.com
www.adobe.com
Posted on Jan 25, 2009
I have a 512MB sandisk memory card for my sprint
Take the SD card out of the phone, if the card is micro sd you may need to put the card in the adapter that usually comes with it. Next, insert it in the computer's memory card reader, then drag and drop you files and music onto the card. If you see a folder labled MUSIC, thats where the music would go, just match up the names.
Oct 27, 2009 | SanDisk 2GB microSD Memory Card
Camera freezing issues, on htc touch from sprint
Did you purchase this NEW from a sprint store?
If no, I think you can figure out the rest on your own
If yes, continue reading
Well there could be several problems here, most likely the camera has been physically damaged. Water damage is also a possibility. If your attitude is at more than 1,500 FASL. The liquid dichloric heydroxide starter up fluid may be off slightly, causing the camera to malfuction.
Oct 11, 2009 | HTC Touch P3450 Smartphone
Tried to install Sprint wireless card on computer
Try restarting computer and as you see anything on the screen, start tapping F8 key. This will take you to Safe Mode and will not load many drivers including the Sprint card. I'd go to Control Panel >Programs/Features(or Add or Remove programs if you're running XP) and uninstall the Sprint app. Restart the computer and it should come up normally. Then call Sprint Tech Support for help.
Jul 30, 2009 | Acer Computers & Internet
Disney Mix Sticks Unable to Remove songs
works best when u add and delete from a music program like windows media, and go to sync tab
u can add them and delete from there
May 19, 2009 | Disney Tink Digital Mix Stick MP3 Player...
Memory card freezes psp after trying to convert a movie
one thing u should learn is that u shouldnt cancel an ongoing process so as not to corrupt ur registry. formatting it should ease the problem
Jan 07, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
Pc freezes when new memory installed
You problem is the motherboard.On your PCs mother board the 128MB that came with the motherboard might be the highest memory the chipset on your motherboard can accommodate. The chipset is built in and you cannot change or upgrade it. You can speed up the PC with how many memo sticks you added, if the chipset can handle. So it look like if you want a fast PC you need to get a new motherboard chipset with higher memory clock frequency.
Here's the pic of the chipset on the motherboard(square type)
Nov 24, 2008 | Compaq Presario 5000 PC Desktop
My computer crashes now and then... Tends to happen alot when im playing a pc game? It makes this loud screeching noise when it freezes i am forced to shutdown manually
Your Memory card is the problem.
Try this steps:
1. Remove added memory
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
2. Open computer and reseat memory
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
3. Swap memory location
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
4.Try another computers memory
If you have access to another computer that uses the same type of memory try using its known good memory in your computer. If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard and/or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
Aug 25, 2008 | Computers & Internet
Computer freezes up
Ok so i'm going to probably get flamed for my suggestion here, but bear with me.
  1. Take out the new fx5200 video graphics card and reboot the computer. If the freezing stops, then the card itself is most likely faulty or incompatable with your particular PC, or may also simply have a fault in it.
  2. Computers that ran fine before a new piece of hardware/software was installed, can nearly always be blamed on the new device or program. Simple solution is to remove the last thing you added and work backwards from there.
  3. If the freezing still happens, i suggest that you could also have a faulty ram stick, and you can test these with a RAM testing program, but they don't always show errors the first time you run them, so it may take several test runs to show the problem.
  4. An easy solution ( if you think you may have a faulty ram stick or Dimm slot, you can try removing the stick/s from the Dimm slots 1 by 1 until the problem stops, this can mean you have either a bad slot or bad ram stick, either way you should be able to work out what the problem is fairly easily.
  5. The only other problem i know of that causes long freezes or pauses, is not enough ram - or what is called missmatched ram.
Feb 04, 2008 | Nvidia GeForce FX 5200 Video Card Graphic
Dell Inspiron 6400 Notebook Logo
48 people viewed this question
Alun Cox
