Question about Miele Novotronic H350-2B Electric Single Oven
Miele Oven I am trying to set my Miele Deluxe H806 Oven clock to the day light saving time and can't find how to
  • 3 Answers
SOURCE: Kitchenaid superba 27 double oven clock - can't change the time!
I went to the website:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203177060.pdf
http://www.kitchenaid.com/custserv/service.jsp
from page 8
Turn the knob to the left until a tone is heard and "time" appears in the display window. The previously set time will appear in the display window.
Continue turning the time knob in either direction until the correct time of day appears in the display window
Press the START button to begin clock operation
Posted on Dec 09, 2008
paulc118
  • 15 Answers
SOURCE: Need to set time on Miele Oven H398B2?
Turn the upper oven on. Hit 'MORE' once or twice until you see 'SETTINGS' touch that and navigate to 'CLOCK' Once there, you can enter the time using the keypad. Hit 'OK' to exit. You can download the manual from the Miele website or request a printed version from them.
Posted on Feb 27, 2010
BElectric
  • 1140 Answers
SOURCE: Oven manual for a Miele
Here is a direct link to download your manual (free) from the manufacturer:
Click link and download will start
http://www.mieleusa.com/manuals_pdf/Residential/Ovens/H814_818_868_gb.pdf
Please rate this solution if you find it helpful. Thanks.
Posted on Oct 16, 2010
Testimonial: "Right on, thanks! - the manual not even on their website!"
  • 354 Answers
SOURCE: how do you set the
Just play with it or go to the manual or support site online
Posted on Feb 15, 2011
amsmith525
  • 99 Answers
SOURCE: How do I set the
I don't believe this model has a clock feature - just cooking timer. I checked through the operation manual and did not find any indication of a clock function. The manual is available here:
http://www.mieleusa.com/manuals_pdf/Residential/Ovens/H350-2_us.pdf
Posted on Mar 15, 2011
HOW TO SET CLOCK ON MIELE H806 OVEN
On the control panel: Beneath the label "Cooking Time," press the "Duration" and "End" buttons simultaneously and hold using your fingers on your left hand. An arrow will display above each button.
Using your other hand, rotate the knob to the left of the panel to adjust/set the time one direction or the other. Once set to the appropriate time HH:MM, release your fingers from the "Duration" and "End" buttons.
The time is set.
Jul 22, 2012 | Zanussi ZBF660 Electric Single Oven
I have a Miele H383BP-KAT oven. For some time the clock has not been able to be set. It keeps flashing 12:00 but hitting the arrows to change the time has no affect. Any help would be appreciated.
Just had the same problem with my Miele H383 oven clock. In my case the root cause happened before the power outage. It was a bad connection between the clock printed circuit board (pcb) and the main control pcb .I only discovered it when I couldn't reset the clock. So what appeared to be a serious fault after the power spike was fixed by simply moving some wires (gently).
The wires concerned are the small black loom which go from the back of the clock to the edge of the main board in the top of the oven. There are 16 of them into one connector that fits on the front edge of the main board.
To access this you need to remove the top cover immediately behind the oven control panel. There are only two screws which may have Torx heads but you will prob. get them out with a flat head screwdriver if you try hard enough .If your oven is mounted underneath worktop you probably won't need to take it out completely to do this but take care it doesn't tip or slide out.(remember there are up to 4 small wood screws, accessed by opening oven door, that secure oven to the housing).
The next step requires you to be aware that mains voltage is present around the main control board and the main rotary selector switch so keep your fingers out of this area.
With the power on press the two outer clock setting buttons (as per normal clock setting) and at the same time wiggle or manipulate the 16 wire loom coming from the back of the clock. Try it in all sorts of positions. I was lucky and had success after just a few attempts. I also removed the clock complete with the 16 wire loom and checked the continuity of each wire from main board edge connector to the clock pcb but I could not find a problem So there may be poor soldered joint on the clock pcb which makes and breaks as I move the loom around. Whatever, I am happy again and have saved a lot of cash!
p.s Have your vacuum cleaner to hand and clean the dust out the inside whilst you have the lid off. Good luck.
Nov 09, 2011 | Ovens
How do I set the clock on the Miele oven?
Mar 15, 2011 | Miele Novotronic H350-2B Electric Single...
I was getting a small "0" error message on the display of my Miele dg 155 steam oven. Tried Descaling but the process didn't complete, stopped at 10 minutes (33 minutes total) and started...
GO TO SERVICE MODE. TURN OVEN OFF OPEN DOOR MOVE KNOWB COUNTER CLOCK WISE TO DEFROST PUSH TEMP BUTTON 3 TIMES PUSH + BUTTON TILL YOU REACH 67 CLOSE DOOR AND WAIT FIVE MINUTES VOILA......
Feb 26, 2011 | Miele DG155-1 Steam Oven Single
How do you set the clock on a miele deluxe h 818 oven please
Feb 15, 2011 | Ovens
Miele H 5240 B CS oven Purchased E & S Trading, Ashburton, 1 October, 2010 When I press the arrows and the OKin between, about 70% of the time nothing happens. Sometimes wetting my fingers seems...
Hi the is a two year g/tee on all Miele appliances. I would contact Miele and book a service call. The appliance most likely requires new clock. Modified clocks are available which allow you to change setting via control knobs rather than keypad.
Jan 16, 2011 | Miele Novotronic H350-2B Electric Single...
Nov 02, 2009 | Miele H398BP2 / H398B2 Electric Double...
from page 8
Nov 17, 2008 | Ovens
H348 B2
turn of at mains, wait 5 mins and turn back on then consult your handbook to set clock. i suspect you have the oven on automatic by mistake. if this don't work, you may have a problem with the clock itself. you can bypass the clock by connecting together the two contacts adjacent to the clock relay
May 17, 2007 | Miele H348 B2 Electric Double Oven
Miele Novotronic H350-2B Electric Single Oven Logo
312 people viewed this question
Top Miele Ovens Experts
Paul Bade
Dan Webster
Dan Webster
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
