Question about Dishwashers
Dishwasher machine fills with water goes through complete cycle but rotor arms do not dispence water . I have checked and cleaned rotor arms.
    Scholar:
  • 157 Answers
Hello davidweavers, Does the motor run during the wash cycle? If yes the flow control valves have a problem. The valve to direct flow to the arms is not activing. #1 Close the water input, disconnect the AC power, and open the housing to aquire access to the internal water routing. Check the wiring connections to all componets by reseating the plugs. Physicaly check all valves by moving the arms, if one will not or is very hard to move this could be the problem. Remove the valve & soak in a 50/50 mix of vinegar over night. Test movement. If bad contact Mgfr. for replacement. #2 All valves move freely and all wiring connections check good you have an electrical control problem. Contact the Mgfr. for a control box replacement. When & if you contact Mgfr have the model & serial#s handy. #3 Please E-mail yours truly of results.
Posted on Nov 05, 2008
Dishes are not coming clean no matter what cycle I use.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps... Please post back if you need more information.
Daniel
May 06, 2011 | Kenmore Dishwashers
Dishwasher leaves behind particles from the rinse cycle
Hi
Hope this helps...
Daniel
Apr 17, 2011 | Dishwashers
Hello, our Whirlpool dishwasher is about 3 years old. It is not cleaning the dishes; I don't think the arms are turning because the door is always dirty, so no water is getting that far. Also, the cycle...
Hi
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Mar 26, 2011 | Whirlpool Dishwashers
Dishwasher fills goes through some motions drains but nothing ing clean
Hi
Hope this helps...
Daniel
Mar 25, 2011 | Frigidaire Dishwashers
Dishwasher does not clean dishes completely model # kudso3ftss3
Hi
Daniel
Mar 24, 2011 | KitchenAid Dishwashers
Dishes not clean after they go through the washing cycle
Hi
Jan 24, 2011 | KitchenAid Dishwashers
Dishes are not coming clean. The detergent basket is not emptying out, after cycle has run, the detgergent is still partically in the dispencer
Hi
Jan 24, 2011 | Maytag 24 in. MDB3700 Built-in Dishwasher
My dishwasher is not cleaning my dishes. at the end of the cycle there is still liquid in the dispenser.
Hi
Daniel
Dec 13, 2010 | Whirlpool 24 in. GU1500XTLS Stainless...
Detergent is left in the dispenser cup. Dishes are not clean after going through a complete cycle.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it’s kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Please post back for any further assistance.
Daniel
Aug 02, 2010 | GE 24 in. GSD6660GSS Built-in Dishwasher
Does not clean like it did soap dispences goes through the cycles does not seem to have the pressure
Hello there"
Please go thru this list that i have provided for you and check each item ok
It doesn't get the dishes clean dot_lineone.gif 1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, we recommend Dishwasher Magic®.
Jan 12, 2010 | Bosch SHU3306UC Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
Mike Cairns
Mike Cairns
