I found the mac address for my MC9090 Barcode scanner guns by doing the following: From the Demo desktop, select the Terminal Emulator, drop down the Option tab, select About Telnet, select Network. The mac address is listed on this page.
This could be 2 thinks. First check to see if under your wireless profile that the card is set to CAM (Constantly Awake Mode). This doesn't help you battery life, but stops the radio card switch off and closing any open connections.
Next you could see what you power settings are. In control panel open up the power settings. You can change the time when the terminal goes into standby when running on battery power and also the CPU power mode.
Hope this helps.
If you need any more help then please do not hesitate to
contact us:-
select your unit type from the pull down menu's and search for Datawedge. Install it through ActiveSync. You will require a cradle and USB cable and ActiveSync installed on your host PC.
Once installed it will allow you to enter barcodes directly into apps on the MC9090.
If you need any more help then please do not hesitate to contact us:- [email protected] or TEL +44(0)1202 620955 http://www.biastechnology.com/
I'm not sure if you can trigger the scanner based on a web field but you can just enable the Data wedge software which will allow the scan to input anywhere you have the cursor. The scanner will be "active" all the time but won't actually scan until you pull the trigger. You can download the datawedge software from www.symbol.com.
you can download MS active sync from microsoft website. then connect the gun to your computer to sync it. Once it sync, drag the barcode app to the windows folder in the gun.
You may need to replace the scan engine - I can help you out with this (or any other issues you may be having). Contact me if you need anything: Ian DC Solutions [email protected]
