You'll need a repair disc or system disc to boot from. Once you boot from it you want to got to the Recovery Console so that you can run the DOS prompt in the black window that appears with white writing. Type the following command: Chkdsk /r
Check disk will run well over an hour so be patient. You'll even see the percentage of completion going from high to low but that's normal too. Once it complete reboot your machine. If you still have problems you'll need to reinstall your operating system. There are ways to do a repair install which preserves your files, docs, music, pics, videos and data. If you do a new install you'll lose everything.
SOURCE: toshiba satellite x205-s9800 - Frozen boot screen
hi,
try this one
take out the battery and take out the Ac adapter now press and hold the power button for 15 sec this will release any static charge residing in your laptop.
now try start your laptop with battery in.
Further Queries are welcome
SOURCE: i gt power to the pc but it does not boot and the
well on the satellite x205 it could be a couple things. there isnt any beep code? if there is no beep code then it would need atleast a main system board. i worked on 2 last week but they had beep codes (3beeps) which were video cards. in your case pull each stick of ram, then if thats not the case order a main system board.
SOURCE: I have a toshiba satellite X205-S9810 and i was
if you mean to replace a screen i advise you have a specialist do it as many things could go wrong and by doing it yourself you have no protection from error, if a techie does it its his A$$ that replaces it if he messes up
SOURCE: My toshiba M55 Satellite will not boot up. My
Take the hard drive out and see if anything comes up on the screen. If so, replace the hard drive.
Does the screen get any brighter when you turn on the laptop? If not, the lcd cable, or power inverter may have gone bad.
Did you have any blue screen of death errors, or any other kind of errors before the screen problem? If so, you may have bad memory. Do you hear any beeps?
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Testimonial: "Quick response from pctech1. Helpful"
