Question about Panasonic PV-DM2799 27 in. TV/VCR/DVD Combo
No picture or sound with TV/DVD/FM, VCR works, but cannot change volume
When I tried to watch TV just a few days ago, I was greeted with this problem. When on the TV setting, there is no picture and no sound. When I change the channel (I'm on cable), there is none of the usual static or snow. The TV displays "TV" and the channel on the screen. Same problem in DVD and FM mode. It displays all the normal stuff on the screen. With a tape, it plays, a picture shows up and is normal, but the volume won't change. I've tried turning the TV on and off in TV, DVD and FM mode, unplugged it, tried playing different DVD's and CD's, unplugging the cable box, unplugging the TV from the cable box...I think I've tried all the various ways anything could be plugged or unplugged, powered up and powered down. Nothing is connected to the TV besides the cable box. Any ideas?
SOURCE:
  • 8 Answers
SOURCE: No audio
are u using av cables for cable box or cable tv cable
Posted on May 04, 2007
  • 4 Answers
SOURCE: No display with DVD, VCR, or tuner
It sounds to me without knowing the model or type unit that you may need to unplug tv AND take batteries out of remote for a few seconds, replug and start over. Hope it helps
Posted on Aug 06, 2007
voodoomox
  • 1689 Answers
SOURCE: Can't get TV picture after hooking up PS 2
How many sets RCA ports (for Video 1 / Video 2 so on and on) does your TV have?
Posted on Jul 26, 2008
Jay_Sav
  • 93 Answers
SOURCE: viera TH-46PZ85U. gray box where picture should be
If it was a setting on the television, then the cable info would also be affected. Try a reset on your cable box, as the cable info is generated within the box from the data stream, whereas the picture is streamed from the provider.
If the reset doesn't work, it's time to call the cable company - it's not a fault with your telly.
Posted on Mar 05, 2009
  • 13 Answers
SOURCE: No sound from built-in DVD player on TV?
It sounds like the audio cable from the DVD drive may be loose or damaged. Did you wall mount the TV and this is when the problem started or has it always been like this? If its under warranty, contact the helpline on 0871 2000 463, be warned, if its becuase the cable is damaged by a wall mounting screw, its clearly evident and they will charge for repair.
Posted on Jun 10, 2009
VCR plays tapes, then within 5 minutes we lose sound, and the picture is "choppy". This does the same thing when we try to watch DVDs, and this started happening about a week ago - we've done no...
Check all the cables and wires,might need is to be replaced,if u still have the same problems,the device have problems,buy a new one,not worth the priced to repair it,the DVD recorder/VCR combo is pretty cheap these days.
Dec 14, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Samsung DLP TV no picture or sound 2 weeks old lamp
Hello, DAvid43, what model is your Samsung DLP tv?
Jun 01, 2008 | Televison & Video
NO SOUND IN THE TV MODE.....
Try pressing the mute button on the remote
Jul 29, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
We have sound but no picture i have sound but no picture. when you change inputs the word input is doubled up and distorted
There were not much info in the manual but it did suggest trying this.
1st- Unplug for a few minutes and then plug it back in. Or use the reset button look it up in the manual. MANUAL
2nd- Blank screen troubleshooting
• If you're trying to watch TV, change channels or press the ANTENNA button to switch tuners.
• If you're trying to watch something that's playing on a component connected to the TV (like a DVD or a VCR tape), press the TV
button on the remote, then press INPUT until you get to the correct video input channel.
• If you're trying to watch a component (like your DVD player or VCR), make sure the component connected to the TV is turned on.
• If you're trying to watch a component (like your DVD player or VCR), make sure the component is connected correctly.
Post back if non of these ideas work and explain if there are any lights flashing or changing colors on the front where the green light usually is. A fixya rating would be appreciated, thank you for stopping by Fixya!
Feb 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
WD-52725 TV loses picture while playing DVD but not sound
replace DM or try to fix it.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Jan 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sony KV-24FV12 Image intermittant Blackout
Hello Robert, the picture tube on your TV set is exausted. Please contact your nearest Authorized Sony Service for further help/advice. After all, Sony is a good choice. The next TV set you buy could be one of Sony-s Bravia LCD. Kind regards, Arpad
Dec 20, 2006 | Sony KV-24FV12 24" TV
DVD/TV Problem with TX-LR552
Did you change your TV input to DVD as well?
Jul 26, 2017 | Onkyo TX-LR552 6.1 Channels Receiver
Dvd/vcr combo,vcr is fine ,but dvd no picture,or sound,disc reads.
Hi There is an I/P button on your player's remote control. Power your player on then press the I/P button on your remote control.
Aug 16, 2006 | Apex Digital ADV3800 DVD Player/VCR
Panasonic PV-DM2799 27 in. TV/VCR/DVD Combo Logo
296 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
