Question about Dell PowerEdge 2600 Server
DELL Poweredge 2600 Bios FREEZES After Cpu check and before SCSI Drives check HELP!!!!
As said above my dell poweredge wont boot past the cpu check which is in my case 2 x Intel xeon 2.4ghz Cpu's and it Freezes and wont go to the Setup, or it wont even load the HDD check it justs sits their at the Cpu check how can a BIOS Freeze I dont KNow Helppp Please !!
  • Q4SteveB May 11, 2010
    ASSUMING there is no CD (especially no 'bootable' CD) in the CD drive ..
    .. I am going to guess the 'most likley' problem is the PERC SCSI RAID controller ..
    You can try the following :-
    1) Remove all the drives .. see if the BIOS gets further = if so, you have a very broken drive ..
    if not =
    2) Remove the PERC card from it's PCI slot .. see if the BIOS gets further .. if so, the card is 'hogging' the PCI bus ...
    Problem Solver:
  • 13 Answers
The BIOS check can freeze for many reasons.
Can you tell me if this is an existing system that was working fine and then had this problem, or is this a new (or new to you) system?
Can you give more information on what is actually showing on the screen?
Posted on Nov 06, 2008
My dell poweredge 2600 wont load up
  1. Can you access the Bios configuration on boot by pressing F2? Check the setting
  2. By load up do you mean your server software does not boot? use F10 on post from the utility partition main menu under Run System Utilities.
  3. Is the server working with RAID? Press CTRL + R and check the RAID
I am not going to say check all the cables because I am sure you will have already?!?
Aug 21, 2013 | Dell PowerEdge 2600 Server
Drive Options with a Dell Poweredge 2600
I would definitively not recommend to remove the backplates, unless you want to ask for serious trouble with your system.
I would install a PCI SATA adapter card (one like these) and connect your SATA drives to it.
May 27, 2009 | Dell PowerEdge 2600 Server
Dell PowerEdge 2400
I have one for sale at www.JonRosenSystems.com. This is an extremely large and heavy unit. It has two P3-733 CPU's, 512mb RAM and three 18gb Quantum Atlas SCSI drives. I have more drives and RAM available.
Dec 03, 2008 | Dell POWEREDGE 2400 Server
Problem with creating array
The Perc RAID controller in a 2600 doesn't support RAID 4.
You can do RAID 0, RAID 1 and RAID 5.
With 3 HDD's your best bet would be a RAID 5.
Mirroring is RAID 1 (which would only use 2 of the drives)
Aug 31, 2008 | Dell PowerEdge 2600 Server
Dell poweredge 2600 upgrade
Look at the service tag on the unit and go to support.dell.com to get the specs on the exisitng drives. Mine came with Seagate Ultra320 SCSI 80Pin 15K drives, You can shop for the 146GB versions and use your existing caddy's if you would like.
May 27, 2008 | Dell G6632 146 GB SCSI Ultra320 Hard Drive
1600sc second CPU
Hi
Yes, some systems (newer PowerEdge Servers, generally 6/7th Generation and above) have onboard VRMs.
1600sc is a 6th gen PowerEdge (with Simple Computing). I can checked and be absolute certain from within Dell. I'm on VAC until Saturday.
In the meantime, check the PRC model and revision and ensure that they match. Given that a single PRC POST/Boots, try upgrading (if not already) the system BIOS to latest revision.
If the PRC model/revision does match and you have the latest BIOS version, also if the VRMs are not needed, then from the Troubleshooting you have already done, we may conclude that the PRC 2 slot is faulty.
I will confirm the VRM query on Saturday.
PowerEdge 1600SC, BIOS A12 Update Package for Microsoft Windows - http://ftp.us.dell.com/bios/PE1600SC-BIOS-WIN-A12.exe
PowerEdge 1600SC, BIOS A12 Floppy Update Package - http://ftp.us.dell.com/bios/PE1600SC-BIOSA12.exe
Mike
May 14, 2008 | Dell PowerEdge 1600SC Server
Constant beep on poweredge 840 appears to work alright
Hi
Besides standard beeps codes indicating Processor, CPU, Memory or Systemboard failures,
Dell PERC (PowerEdge Expandable Raid Controller) or SAS Controllers (Serial Attached SCSI) generate beeps to alert failures on the RAID sub-system.
From your description of the issues (when the beeps start), i suggest you check PERC or SAS setup. If you have Dell OpenManage Server Administrator installed, you can log-in and check for more information. Additionally, on the next reboot check the PERC/SAS/CERC boot up for any messages. You may also access the PERC (Ctrl+M), SAS (Ctrl+R) CERC (Ctrl+A) Management Menu for specific failures and attempt a rebuild (assuming you have a redundant RAID Volume).
You can also speak with Dell Support and raise a warranty call if the system has warranty.
Note: PowerEdge 840 would ship with PERC or SAS Controller. PowerEdge 700 will ship with PERC or CERC.
Mike
Apr 02, 2008 | Dell PowerEdge 700 Server
I want to format scsi drives and configure raid0
You can either do this in the BIOS or (easier) just run a Linux installer (such as Ubuntu) and it will offer to do it for you when it sees Windows-formatted partitions.
Jan 06, 2008 | Dell PowerEdge 2600 Server
PowerEdge 2600 does not boot up ?
you need to set the boot device order. Usually F12.
or you can go to bios with F2 or F10.
your cd-rom is wrong you need the Instalation and Server Management CD. I think it's possible to download this cd at their site.
good luck
Dec 03, 2007 | Dell PowerEdge 2600 Server
Adding a second processor to my 2600 server
I hope that you fixed your problem without troubles by now, but if you still have not, I can help. I added a second xeon processor to my Dell PowerEdge 2600 a couple of years ago.
Lay the server on its left side then loosen the three thumbscrews on the right front side and "slap" the cover off backwards.
You should have by now identified the current processor by running cpuid software that I think comes from Intel's website in order to buy an identical cpu. That was the hardest part, finding an identical one still for sale. If I remember the Poweredge 2600 could only use xeon processors with only up to 512 kb of cache or someother small amount and are not that available still new in the box.
You also have to get two identical voltage regulator modules (vrm). I was not able to get a second one for some reason and just bought two identical ones specifically for the xeon processors that I was using. Be sure to do your homework on this. MATCHING cpu's and MATCHING vrm's.
That's it. Each processor has two cores and you should see all four after you boot.
Another thing to think about would be setting the processor afinity to run your most intensive process to all four cores while only letting most applications to only use the first core.
I hope this helps if you haven't already had any success.
Nov 16, 2007 | Dell PowerEdge 2600 Server
Dell PowerEdge 2600 Server Logo
949 people viewed this question
Alun Cox
