To isolate the cause of the issue, we suggest that you do the following: 1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture. Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps: 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera. 5. Depress the shutter button as you would to take a picture. Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card. If the message does not appear, please complete the following steps: 1. Turn off the camera. 2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body. 3. Reattach your lens. 4. Turn on the camera. 5. Depress the shutter button as you would to take a picture. If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician. If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
if the solution helps . please rate the solution. thanks.
I am thinking about buying a Nikon L100 camera. I would like to know what others think about the...
(More)
I am thinking about buying a Nikon L100 camera. I would like to know what others think about the camera.
