Question about HP Office Equipment & Supplies
Need help releasing print cartridges from my HP All-in-one Officejet printer, model 5610. They are jammed in the machine and I cannot remove them without breaking them or the printer. Can I get some help? Thanks, Walter Metrokin
I've permanently solved the problem...I'm recycling my HP piece of junk unit and getting another brand. PROBLEM SOLVED!!!!
Walter Metrokin
Posted on Nov 13, 2008
Need to find out how to put ink cartrdiges back into hp 5610 all in one printer.
First, turn the printer on. Open the print-carriage access door by pulling it forward. The print carriage moves to the far right side of the HP All-in-One. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right Pull the print cartridge toward you out of its slot.
Now we're ready to install the new cartridge. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket. Close the print-carriage access door.
Mar 21, 2011 | HP Officejet 5610 All-In-One InkJet...
Hp officejet 5610 All-in-one having 'cartridge error', need help to solve it. thank you.
Remove both cartridges and clean the electrical contacts with a dry cloth. Clean the contacts in the carriage, inside the product too. Put the cartridges back in.
If that doesn't work, remove the black cartridge from the printer and try to print something. If the color one prints, you need to change the black cartridge. If the color one won't print, and the black does, then you need to change the color cartridge.
Apr 11, 2010 | HP Officejet 5610 All-In-One InkJet...
HP 5610 printer won't print
Unplug this beast. Take the old ink cartridge out and re-insert. Also, check for any other jammed papers that need to be removed. Then turn this beast back on. See if that does anything old chap.
Feb 04, 2010 | HP Officejet 5610 All-In-One InkJet...
Cartridge jams during printing
Uneconomical to repair. It's time to buy a new printer.
Dec 14, 2009 | HP Officejet 5610 All-In-One InkJet...
I put the black cartridge #56 into the tricolor in an HP 5610 Off
It just is "jammed" into place, like a round peg into a square hole.
Use a bit more strength, in order to "unjam" it.
Or, if you are not comfortable, take it to a qualified printer technician,
and let him/her remove it.
Nov 19, 2009 | HP Officejet 5610 All-In-One InkJet...
Carraige jamming, prints but does not release printed copy. Print cartridges jamm as well. Have to turn off printer open print cartridge door and then they release when turned back on. Opened rear and...
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
aswq14
Aug 12, 2009 | HP Officejet 5610 All-In-One InkJet...
My print cartridges are stuck
Make sure that the printer is turned on before opening the print carriage access door. Lightly press down on the print cartridge to release it and slide out.
Color cartridge on the left slot and the black cartridge should be on the right.
I hope this helps.
Mar 12, 2009 | HP Officejet 5610 All-In-One InkJet...
HP OfficeJet 6110 All-In-One
go to hp.com, support and troubleshooting, type in your pirnter model number and download the user manual. follow the direction to disassemble the printer. you might not need to disasseble the printer, if you can see the jammed paper.
follow the direction and clean the roller and the printer head.
it should work.
Oct 05, 2008 | HP Officejet 5610 All-In-One InkJet...
80 people viewed this question
Ben Johnson
