Question about Dyna-Glo (PPH16-LP) Utility Heater
Black smoke I have a kerosine heater. I stored it for the spring and just started it up 2 weeks ago . I put a new wick in and it worked great. It started smoking real bad. It is a dark black smoke. I can`t figure it out. The only thing I can think of is the fragrant that I put in , It is possible I used to much,
  • David olmsted
    David olmsted May 11, 2010
    what type of fragrance did you put in it?
    Scholar:
    New Friend:
  • 51 Answers
If you did put too much in it most fragances are oil based that could cause it to do that empty it out completely add fresh kerosene and see if that fixes it
Posted on Nov 06, 2008
Our radiant kerosine heater will not turn off. Either by lowering the wick or safety switch. Should we just let it burn out
sounds like the wick was not installed properly, not sinking low enough to extinguish.
Oct 04, 2017 | Heating & Cooling
Knob up at max , but flame is 1/2" below the top plate of burner. Is a near new unit with only k1 kerosene . How can I get the flame up ?
Have you trimmed your wick lately? When the wick burns it becomes black, carbonised and no longer absorbs the kerosine like it should. You should have a wick trimmer which is like a can lid with a circular groove and two cut outs in the groove to shave the wick of its black carbon.
Jan 24, 2016 | Heating & Cooling
Put in new wick cleaned it up wait an hour lit it and it smokes any suggestions
new wicks in kerosene heaters will smoke till the mfg coating burns off it , burn it outside for a few hours then readjust wick height then it should stop smoking
Mar 11, 2015 | Heating & Cooling
Flame too low and putting off soot
Raize the wick up and trin off the burned section off Or replacethe wick.first take some of the kerosine place a clear glass ,should be as clear as water if not replace the fuel. Use only K-1.
Jan 22, 2011 | Corona 23-DK Compact Heater
Heater puts out black smoke when lighting and wick does not get flame all the way around
Sounds like the wick (if it's a new one) was improperly installed and is not soaking up enough kerosene. Or you're using old kerosene.
Jan 19, 2011 | Heating & Cooling
Heater turns off leaving lots of smoke and is hard starting
If this is a kerosene heater,the wick is most likely not adjusted up enough,or the wick is contaminated.The fuel could be contaminated also.Remove the old wick and replace it,and refuel it with clean kerosene,after you pour the old out.
Oct 14, 2009 | Heating & Cooling
DynaGlo RMC-95-c6
did you soak the new wick a good hour in clean kerosine before you installded it???is your wick in the correct position? it needs to be 5/8" showing when installed in the up most position.very important to soak the wick or it won't wick up fluid as it is suppose to.
Feb 24, 2009 | Corona 23-DK Compact Heater
Dyna glo RMC95C6 kero heater
I suggest you replace the wick and clean the wick feeder assembly. I did not own that model but did have one a number of years ago. The wicks can begin to dry out.
Jan 08, 2008 | Northern Tool 10,600 BTU Radiant Kerosene...
Why am I replacing wicks every 3 weeks
could be you got the flame a little too high so its burning off the top of the wick.
Dec 27, 2007 | Corona 23-DK Compact Heater
Electric starter
I have a different make and model, but many of these use a similar design. A battery pack (2 x D or C cell) is mounted on the kerosine tank. The batteries are used to heat a coil. The coil is pressed by an external button against the heater wick. Pressing the button also engages the switch, heating the coil until it glows red hot.
1. Open the burner chamber of the unit and confirm it has a wick installed (this is a used heater--who knows it's condition). Close the chamber.
2. Make sure the tip-over protection hasn't retracted the wick. Generally the tip-over protection is reset by a lever on the base of the burner.
3. Adjust the wick all the way up. A knob on the base of the burner does this.
4. Fully depress the electric starter until the coil touches the wick.
5. When the kerosine on the wick ignites, release the starter and adjust the wick to the desired level.
If the electric start coil does not glow, check the batteries. If the batteries are good, the starter coil may be bad. These are also
replaceable.
Nov 08, 2007 | Corona 23-DK Compact Heater
Dyna-Glo (PPH16-LP) Utility Heater Logo
206 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
