Question about GE WBVH6240F Front Load Washer
Soaking wet clothes
My GE front load washer is about 7 months old and is now starting to screw up. It pauses for long periods of time so that it takes forever to finish a load and the clothes are soaking wet. Any help??? Laundry is piling up!
  • 3 more comments
  • Harmony Campbell Oct 10, 2006
    OH MY GOD!!! Thanks so much, it worked perfect. You saved me a bunch of time (meeting repair people etc..)
    Thanks a million!
    Harmony
  • Anonymous Jan 06, 2009
    I found a sock I'd been missing for a year! Boy, how stinky... Thanks for the great advice.
  • Anonymous Jan 13, 2009
    Washer keeps pausing on rinse cycle and not continuing on to spin cycle, plus the water is not completely draining out of the washer.
  • TinaBee Feb 19, 2009
    Ours did the same exact thing!!!!!!
    I was going to throw the washer out 8:30 am this morning!!!
    Are all the washers like this the same?
  • Anonymous Apr 05, 2009
    The filter behind the lower panel was TOTALLY plugged. Cleaned it out and washer seems to be running fine now. Found a $5 bill, three $1 bills, two quarters, six dimes, three collar stays, an Australian coin, and about a 1/4 pound of lint/dirt/sand/gunk. Nasty smell, too.
There is a good reason this is not in the Manual. Being under the bottom cover, GE would say to only have an Authorized Service Rep work on Washer. Reason being that this is also where the Motor and Controller are located. This presents a Risk to the consumer than GE would prefer not recommend accessing because some unsuspecting consumer is going to put his/her hands on something else underneath that might hurt them and then GE would be open to lawsuits. GE is as much trying to protect the consumer while at the same time keeping their Service Reps in business.
If you ask me, this Strainer should be accessible without having to remove any covers, because you obviously need to clean once or twice a year. My problem started over a year ago and I thought the PLC was going out and it made me furious because the warranty had just expired when it started to not spin.
Many users on Fixya have this problem and others related to water not draining out. Once the strainer is clean, most the problems go away. Clean the strainer yourself, and you save $100 Service Call. I was ready to call a Service Rep until I read up on GE Front Loaders on Fixya.
Posted on Feb 17, 2009
    President:
  • 878 Answers
Harm, remove the lower panel and you will see the filter right in front. Unscrew the filter strainer and clean all the lint and debris. This machine has a pressure switch that won't allow a high spin if it detects water in the tub. Therefore you get these pauses and slow tumlbe. Try this and see if it's normal after cleaning the filter...Catriver...post back
Posted on Oct 10, 2006
Yes, we unscrewed the bottom panel, turned the circular disc counterclockwise and a bunch of water came gushing out.  Make sure you have towels down and something to catch the water with.  Then, remove the filter. You will find all sorts of interesting things.  We found 2 infant socks, a penny, an allen wrench?,  a marble, and a bunch of lint.  Once you clean the filter, just put it back in and twist the cover clockwise.  Run the rinse cycle once and make sure no water leaks out of the bottom before replacing the panel.  Works like a charm!  You are supposed to do this every year, but the manual says nothing about it.
Posted on Feb 08, 2009
Thanks works great now!! Found 1 dime, 2 nickels, 3 pennies, 1 tiny screwdriver and alot of lint. woohoo!!!! Money saver!!!
Posted on Jan 31, 2009
Thanks for posting this was a very quick and inexpensive fix. We have spin cycle again!!!
Posted on Nov 28, 2007
Great suggestion. Why is this not in the users manual in the troubleshooting? You saved me a bunch of time and coin. Thank you.
Posted on Sep 04, 2007
Thanks a lot. worked perfectly for us as well.
Posted on Sep 02, 2007
Our washer smells like mildew or mold whats up?
is it fully draining? old water will start to cause this. wash ur clothes and immediately dry them. dont leave wet clothes in the washer over a days period. hope i helped
Mar 12, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
GE Aurora Front Load Washer leaves the clothes soaking wet
there is a filter under the washer door behind the panel...its white just unscrew it and clean out the filter and that should solve your problem.
Sep 18, 2009 | GE Washing Machines
Ge front load
I had the same problem. There is a filter under the front lower panel. You need to remove the four screws and on the right side you will see a filter this gets cloged easly. One time there was a sock in it. I do not know how, but clean your filter and this should help. I hope this helps you. Bubba
Jul 30, 2009 | GE WBVH6240F Front Load Washer
Remove the front lower panel (3 screws on lower lip - lay on floor to see). Panel come right off. there is a round "dial" to the front housing. Put down a bath towel on the floor and unscrew dial - then pull it out.
Aug 15, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
Shuts off in middle of cycle
I am having the same problem w/ our brand new front loader washer, it pauses constantly, and even when I can get the load to finish, I have to drain and spin atleast 3 x before I can even attempt to put in dryer, at this point it is taking me hours to do one load of laundry!!
Ugh-- Service man is coming tomorrow, so I will share what I learn...
Apr 19, 2008 | GE WBVH6240F Front Load Washer
Spin Cycle doesn't work on our GE Energy Star frontloader, please help
You may have to remove the lower panel and clean the drain pump filter. Easy job, once the panel is removed the filter will be right in front. Get a bucket and unscrew the filter cover (3 very small screws at the bottom of the front panel) and you should find a ton of lint and stuff in there. This model has a pressure switch that detects if there is water in the tub. If so it will do this pause and slow spin. Once the pump filter is clean you should be good again. It worked for me.
Apr 08, 2008 | GE Energy Star WCVH6260F Front Load Washer
Don't properly spin out clothed leaves them soakng wet-Now it just keeps pausing and locking door and unlocking door without washing
sounds like there is a pumping/blockage problem. check the filter and all drain hoses/outlets. if all clear the pump may be faulty. is the drum turning at all?
Feb 16, 2008 | GE WSXH208A Front Load Washer
GE WBVH6240F Front Load Washer Logo
615 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
