Question about Whirlpool Refrigerators
It seems to be not working lights on just not cold as before no ice
Whirlpool doesn't seem to be getting as cold as before not making any ice either
    Scholar:
  • 62 Answers
First you should check to see if your fans are running, one by the compressor and the one inside the freezer. If they are working check in the freezer for frost or ice build up on the back panel. If you have ice build up on the back then you more than likely have a defrost problem. If it is a defrost problem you could temporarily get it to cool again by manually defrosting the unit. this is only temporary though and if you do this a tech will have a hard time diagnosing the problem until the ice builds up again. Let me know what you find with the checks I gave you and I can step you through the rest
Posted on Nov 05, 2008
Whirlpool conquest side by side. Ice began melting and red light for filter replacement was on. I changed the filter but it didn't seem to fix the issue. Few days later everything began working fine but...
Turn the temp control to max, does the compressor come on? If yes feel the discharge line at the back of the compressor, is it nice and cold? If yes you can eliminate the simple items, make sure all the fans are working inside the fridge and at the rear of the unit. Check to make sure the defrost drain/trap are clear. Let it run for a while, then drop the temp to the usual setting it, and see what happens.
Feb 26, 2015 | Whirlpool Refrigerators
My ice maker will work 1 cycle and then it wont work again for a few days. I can here the compressor start up and it hums for 10 seconds then a click happens and its over. No more humming.
Compressor over load switch is the clicking you here. check the compressor to see if it has a start capacitor if so check to see if it is good. if it dose not have one then check compressor relays make sure there in good working order.
Jul 01, 2013 | Sunpentown SPT IM-100 Portable Ice Maker,...
The temperature in our refrigerator (Whirlpool Gold GD22DF) is not low enough this morning. Things don't feel cold. I've moved everything to a cooler and removed a small block of ice in the vent...
possibly the air damper motor has failed and needs tech help . you can possibly get by blocking the air damper open slightly but permanent fix needs done
Oct 08, 2017 | Refrigerators
Ice maker not putting out water just hooked up ice maker kit
Are you getting ice? It seems like my brand-new electrolux does not produce cold water unless it is producing ice as well. We had to adjust the auger in the ice tray to start getting ice ... seems like our water is now getting colder.
Jul 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool model HAXNQ : lights out on fridge side only
Hummm... I would suspect your DOOR SWITCH on the fridge side... $11.321 shipped... eBay!
Anthony
Whirlpool 1118894 Door Switch
Dec 02, 2017 | Whirlpool GS5SHAXN Side by Side...
Our whirlpool 6 yr old refrig / freezer is not working correctly
Use a vacuum and clean under your fridge. A dryer cleaning brush will help make the job go much faster. Use a good light so you can get all the lint out. Give it 12 hours to level out. hope this is helpfull.. Saw
Aug 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Lights out inside refrigerarator and making noises
bad door switch unplug and pry out switch and replace the sound you are hearing are wires burning
Apr 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator not cooling
sounds like the fan in the freezer isn't working.
Mar 21, 2009 | Whirlpool ED5VHGXM Side by Side...
Whirlpool gold conquest refridgerator
if u find out let me know. when we turn both frig/freez switches off the frig light comes back on flashes to number 6. it still seems cold be like this 2-3 days the food still seems cold. good luck. jax, fl
Mar 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
53 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
