Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Code F3 So, we followed your advice on the last solution. We replugged the J-2 harness and the probelm continued. Then, we pulled the thermostat sensor and will replace it. Now, the oven cleaning fan still runs and we are getting a Code F3. Can you tell me what Code F3 means? Here was your last solution. You are going to have to kill the power to the range and open the control panel by removing the four 1/4 inch hex screws. These are located undernieth the control as you open the door. Then by holding the panel on each side pull out. The J-2 harness will be on the main board. The harness will run from the display board to the main board. You want to unplug the harness and plug it back in for a good connection. Of course you want to make sure the harness is not damaged or burnt. Since you had this in the clean cycle when the code came up, the temperature sensor should be checked. I'm getting conflicting information on this error code. One sections states it's the j-2 harness on the board and another section states an overtemp condition and to check the temp. sensor. If you have the expertise you can ohm out the sensor to eliminate it. At room temp it will ohm out at approx. 1060 ohms. To tell you the truth from past experience I would go with the temperature sensor first. This is the probe in the oven. Removes from the front and of course least expensive. I have two part numbers for this sensor..(typical Maytag) 12001357 and 704657. If your serial number begins with 10 it would be the first one. Catriver, post back. n:
    President:
  • 878 Answers
The F3 has to do with the sensor, did you ohm out the last sensor? Check the new sensor and the harness that it connects to. F3 is cooling fan running with no funtions selected. The harness may be burnt or shorted. Catriver..post back.
Posted on Oct 10, 2006
GE JVM1440SH001 f3 error
see the commentaries and repair:
F3--Shorted key panel(touch pad), will occur if a shorted key panel is detected continuously over 60 seconds.
test the following:
1. Door is not closed (some models).
2. You waited to long (open and close door to wake it up).
3. Controller is confused (pull plug for a minute or two to reset).
4. Defective interlock switches.
5. Faulty controller or its power supply.
6. Touchpad or controller board contaminated by overenthusiastic cleaning.
7. Defective/damaged touchpad.
Jul 31, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
We are getting an F3 message on GE JVM1750DM microwave. After turning off power and then back on. It works for a few minutes, but then the F3 message come back ?
Hi
F3 error in your GE microwave means that the keypad/touchpad is bad and should be replaced. However, before replacing it you can follow these step by step instructions to clean the touchpad assembly and see if it works:
1) Unplug microwave
2) Remove two small screws from upper face plate
3) Remove screw on upper side of control panel
4) Life panel and pull out
5) Identify flat tape-like harness connecting circuit card to keypad
6) Wipe down harness with an all-purpose wipe
7) Use hairdryer to dry remaining leftover moisture
8) After this put the keypad back if its not solved then replace it.
Hope this helps...please post back for further assistance.
Daniel
Sep 05, 2011 | GE Microwave Ovens
Out of no where I get and F3 error messaGE AND A BEEP BEEP BEEP the model # is JES1036WF001
Hi
1) Unplug microwave
Daniel
Aug 06, 2011 | GE Microwave Ovens
BOTH OVENS ARE SHOWING F1-1 & F3-1 WHAT DOES THIS MEAN
F1 is a Defective touch pad or clock (ERC)
F3 is Shorted or open oven temperature sensor (RTD)
To test the touchpad do this test:
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
For the F3 code:
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
http://www.appliancepartspros.com
Jul 24, 2011 | Maytag Kitchen Ranges
What does an F3 trouble code mean? We were using the self-cleaning feature when this came on. We were cleaning it because we thought it might help the thermostat, which has been keeping the oven running...
Hi, F3 code means Shorted or open oven temperature sensor (RTD)
Solution Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Oct 10, 2010 | Maytag Ovens
I get a F3 code on the control panel and the oven doesn't seem to regulate the temperature anymore model 68HN6TVW
check the temperature sensor probe and harness as f3 code refers to that..
you will need to pull the range out from the wall and disconnect from power and remove the panels that cover the control panel and sensor probe area at the back of the oven.
sensor is part# 12001656 - Oven Sensor Kit 7" Long around 30-40 dollars plus shipping and tax, depending...
hope this helps,
best of luck,
ttfn
Nov 02, 2009 | Ovens
Oven will not turn on
Hi mcifaretto,
F3 code error indicates a bad oven temperature sensor (RTD). To fix this error, Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope this helps.
Thank you for using FixYa.
Oct 08, 2009 | Tappan TGF320 Gas Kitchen Range
Kenmore Oven gives fault code F3 when you turn on oven
Check the sensor harness, and the sensor harness connections at the sensor and oven control for an open circuit. Check for resistance on the sensor. It should not read as an open circuit. If the sensor shows resistance and the wiring and connections show continuity, then the problem is most likely on the control board itself. Possibly a bad connector or crack. You will probably have to replace the controller board (clock).
Dec 23, 2008 | Kenmore Kitchen Ranges
Oven won't stay on and give an F error message
Disconnect the power. Disconnect the sensor harness from the control. Measure the sensor resistance (white leads). The resistance should be 1080 ohms at room temp. If the sensor is open the resistance is usually over 2900 and you get an F3 message. If the sensor is shorted the resistance is usually less than 950 ohms and you get an F4 error message. Also look for damaged harness terminals if not a bad sensor.
Aug 31, 2007 | Ovens
Error codes F2 and F3
IF THE ABOVE SOLUTION DOES NOT WORK TRY THIS!
Do Not try to perform the below if: Oven is under warranty,You are not handy with a soldering gun, or Are afraid to do this.
The below solution applies only to my in-wall oven with F2 and F3 codes randomly, but presumably will work with other GE models.
I had the same trouble with a GE in-wall oven. The problem was on the electrical board behind the keypad. A pin that was soldered to the board, that was the input for the oven temp sensor, had cracked solder. So I re-soldered the pin and hopefully it will continue working.
If this fixes your oven please post back!
Apr 10, 2007 | GE Profile 30" Free-Standing 5 Burner Self...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
336 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
