Sony FD Trinitron KD-36XS955 36" TV Logo
monica alonso Posted on Oct 10, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Audio problem I was changing channels with the remote control when suddenly appeared a message that said something about the speakers, then the audio went off and I haven't been able to turn it on again. I have tried all buttons, please help me.
Anonymous
Level 2:
Sergeant:
  • Expert 337 Answers
  • Posted on Oct 10, 2006
Anonymous
Expert
Level 2:
Sergeant:
Answers
337
Questions
Helped
152147
Points
699
In your set's menu you should have an option to turn off/on the internal speakers,If you bring the menu up on the screen you should see options to change the video settings like color,brightness but also ther should be an option for audio witch include balance, treble,bass....in that screen you should see the option that says speakers try switching between on or off.Please let Us know how it goes or if you need more information.
I have Philips television when I try to change the channel from my cable media remote there is message coming as “only effect on tv” plus when I try to change the channel from my cable remote it’s...
That probably means you need a new remote. Or new batteries. The blinking light means it's trying to turn on but failed to do so because it's dead or old.
4answers
HTS9800W/12 and rear speakers
click this site:
http://www.avforums.com/forums/archive/index.php/t-378942.html
Vimax tv displays no sync on screen
Check its input connections. Check it for external RF input.
Error message on screen that says PO 1.15 V100
The error is likely to be from the satellite as the set model listed does not have that kind of error.
Panasonic CT 27 SL - 13 GL how to connect external speakers
This TV is set up to connect to an external amplifier which that controls the speakers. It has an analog audio output which means you need an RCA audio cable (2 RCA plugs (red and white) on each end. You can't directly connect a set of speakers. The audio output jacks at between the antenna in and the video inputs. Then you need to enter the menu and enter the Audio submenu. Go to the Speakers item. Turn the TV speakers to off and fixed audio out.(The amplifier will adjust the volume.) Use the Up/Down arrows to navigate through the menu options, press enter to enter a sub-menu and the volume up button to change a setting.
There is also a headphone jack which may be compatible with computer speakers. That has a 3.5 mm jack. To use headphones, set the Speakers Audio item to TV speakers Off and variable audio out. (The TV controls will adjust the volume.)
To use a Universal remote to set the audio or modify the channel list, you need one that matches the Menu function of the original remote. You may need to try multiple codes for Panasonic TVs to get the button to work. Some low-end universal remotes may not have the menu button; get a different remote or use the menu button on the front panel of the TV.
To set the channel list, press Menu and select Setup. Go to the Prog Chan option. Then set your Mode in the first option (Cable or Air). Then choose Auto Program to scan all channels or Manual Program to edit the channel list.
The manual for the TV is available at retrevo: http://www.retrevo.com/support/Panasonic-CT-27SL13-TVs-manual/id/275ag210/t/2/ . You will need to enter a code to access the manual. See page 5 of the manual for the input connections (page 7 of the PDF).
7helpful
Have Aiwa TV MODEL No. TV-A209 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its stuck...
have Aiwa TV MODEL No. TV-A209
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
O6895H
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
000 001 1
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
The speakers in my laptop suddenly stopped working - how do I reactivate them?
Hi, these instructions will help you with the Audio problem. These are the steps to setup and 'restore' theAudio Drivers Part (1) Click on the "Start" button, go to and click in the (right, pane) Control Panel.
Scroll to find, Options. Click, onI “Audio Devices, and Sound Themes” click, “Playback” click on the Active "Speakers.” Click “Configure” to "Audio channels" The (Speaker Setup) "wizard,” appear! Select (Test) click, Next! Follow the instructions. Part (2) Click 'Properties' change the "sound"(Level). Click on Enhancements, "Apply" changes. “The (Advanced), “not recommended!” In, the Controller Information (block), click on, Properties to "update" Drivers. Check to see if Device usage: (enable) if not? "Change it." *Note: Click "OK" to all change; 'Save' and Apply! Restart the computer when finished. " "Rating the solution on its helpfulness is appreciated, thanks"
Surround audio system: only 2 speakers work
Finally solved it. Push the "prologic" button several times until 4 channel appears in the display.
14helpful
Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
2answers
Don't know how to adjust volume on remote speakers
Can I ask you something? I have the same but the remote doesn't work, and I have no sound in the B speakers. I wonder if there's something that I have to do with the remote, or there's a problem with the receiver, Thanks.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
