Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Bad Caps 4 caps in the standup shielded module get bulges on top, replace them...seen it many times.
  • tmcollins Apr 03, 2008
    my green light just blinks away, what are CAPS, can i buy them, how $$$ am i looking at to get this TV fixed. thanks, i love my tv and lost and frustrated. thanks mycanning@yahoo.com
    Problem Solver:
  • 6 Answers
Steps to fix your TV: http://www.chrisandnat.com/temp/BlinkingTV.pdf
Posted on Sep 12, 2007
Jetway v266b rev 3.0-what ram memory to use??
You might wanna try DDR RAM, the highest size you will be able to get is is 1GB per module, so buy a few if a DDR module fits, and you may also want to look at the capacitors, make sure they're not bulging, I've seen a lot of these boards in computers, and when I've had to repair them, 99% of the time it was bad caps, so if they are bulging, I reccommend nichicon K series caps (NOT KZG, they're known defective)
Feb 22, 2013 | Computers & Internet
Squiggly lines all over untill it warms up then they are just up at the top
Sounds like bad capacitors in the power supply. check for bulging caps or replace the power supply
Mar 13, 2010 | Toshiba 57H82 57" Rear Projection...
When I turn on the TV it has a loud squeal for about 10 minutes until it seems to warm up.
I suspect you may have 2 capacitors in your control module that need to be replaced. When these caps start to go bad it will often show up as a problem with the sound. However, when they get really bad they can prevent the TV from turning on. Please see the link below, posted by stiv0. It gives detailed instructions on how to replace these caps and to tell if they're getting bad. If you follow these instructions you can take the back off the TV and check out the caps. If the tops of the caps are bulging they need to be replaced. Just be sure to replace them with the correct value (1000uf) and use caps that are rated at a higher voltage than the originals. I replace the 10v caps in my FLM 373B with 30V caps just to be on the safe side. If you know how to solder this is an easy and inexpensive fix. If you don't know how to solder find a friend who does. These caps have positive and negative terminals. It's important you solder the new caps in with the correct polarity. Stiv0 gives instructions on this. Even if the caps aren't bulging this fix is so inexpensive, less than 10$, that you may want to try it anyway. I hope this helps you out.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Feb 01, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
Picture goes to verticle colored lines then goes blue screen tv s
This is likely capacitors failing in your DM or FMT module. This model is know for the 1000uf caps going bad after 4 years or so. There are 4 on each board, plus 4 on the power supply that may go bad. You can tell by the bulging tops that are not flat. Two 3300uf caps go bad in the power supply regularly as well. I recommend getting a service center to send the whole signal block or chassis into Mitsubishi for rebuild to get it all taken care of. The dissassembly is very difficult and frustrating. If you have tons of time and determination you could repair yourself.
Dec 07, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Flashing power light tv wont come on mitsubishi 1080
If the tv has the continuous flashing led, you have a DM board problem. It is likely bad capacitors in the DM module.. there are 4 of them 1000uf caps that will go bad. They will get a bulging top on them when they go bad. . Mits recommends replacing them with 680uf caps with a comprable or higher voltage rating. The DM module in on the left side of the set (viewed from the back) and is somewhat difficult to remove.
Dec 03, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Blinking Light Problem on Ws-55513
If bad capacitors are the problem then replacing them will involve soldering.
If the problem is something else less visible then fault finding will be difficult without the proper service manual.
http://www.completeservicemanuals.com/mitsubishi/crt-projection-television/ws-55513-service-manual/prod_37.html
This will show the correct disassembly and test procedures.
Good luck.
Oct 20, 2007 | Mitsubishi WS-55513 55" Rear Projection...
TV wont come on.
if your timer light wont stop blinking? on the vary left of the chassis. is the stand up module or as it is called the digtil module. there are 4 1000 uf caps at 35 volts the top of the caps will be swoling
May 28, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Will not reset
4 caps in the standup shielded module get bulges on top--obvious failure. Replace them. Seen it many times
Oct 10, 2006 | Mitsubishi WS-55513 55" Rear Projection...
T V broke
4 caps in the stand up shielded module get bulges on top....replace them. Seen it several times.
Aug 30, 2006 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
