I have a Barnstead (Thermolyne) Locator-8 for storage of cells in liquid nitrogen. A plug on my unit was lost during shipment, and the unit lost vacuum. Can someone service the unit and restore the vacuum?
  • 828 Answers
A unit of this type should be returned to the manufacturer for evaluation.
Posted on Nov 06, 2008
Temperature of liquid nitrogen
Hello, liquid nitrogen ranges from -320 F degrees to -346 F degrees.
Mar 16, 2015 | Cars & Trucks
How do I fix the unit when the water does not exit the drain but exits inside the house
I usually use nitrogen to clear the condensate line. You will have to cut the drain line and clear the line. Putting 3-4 drops of dishwashing liquid in drain once a month during A/c usage can prevent this from occurring.
Aug 23, 2014 | Heating & Cooling
Buyer wishes to stop shipment
Did you email or call the company? Refuse shipment when it arrives.
Oct 23, 2013 | Our Pet's Big Bone Storage Bin
ODOR OF NEW OVEN
this is normal as after manufacture these units are stored before shipment and they put a coating on the elements and bake racks so they don't rust during storage
Dec 10, 2012 | GE JGRP17 Gas Single Oven
Need manual for Barnstead Thermolyne 2200 Hot Plate HPA2235M
Uhm...the hotplate manual is here, but you do realize this is the PC Laptops area...and not lab equipment.
Nov 22, 2012 | Computers & Internet
Can not rec a dial tone, phone states no link to base move closer
If “No link to base. Move closer to base, try again.” is displayed
even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit.
• Make sure the base unit is not being used.
• Have both handsets and base unit nearby during registration.
• Follow steps 1–3 listed below. You have about 1 minute to complete them.
• Confirm the extension number of the handset which has lost the communication by placing the handset on the base unit or charger.
If you re-register the handset using the other handset’s extension number, the other handset will not function.
• If the handset beeps 3 times and “Error!!” is displayed, an error occurred. Try again from step 1.
• You can stop registration by pressing [OFF] on the handset, and pressing [LOCATOR/INTERCOM] on the base unit.
1 Base unit: Press and hold [LOCATOR/INTERCOM] until a beep sounds.
• The CHARGE indicator flashes.
2 Base unit: Press the extension number [1] (handset symbol 1 ) or [2] (handset symbol 2) of the
handset which has lost the communication.
3 Handset: Press and hold [FLASH/CALL WAIT] until “Handset Registering” is displayed.
• When registration is complete, a beep sounds from the handset and the display shows the number.
• Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
Feb 23, 2010 | Panasonic KX-TG2357 Cordless Phone
I just received my acer netbook and installed the power supply but the power indicator is saying "no power supply detected" does the power supply need to charge for a while brefore it is detected?
New computers ship with the battery half charged so they won't blow up during shipment.  Plug this puppy in and wait 6-8 hours for full charge.  Then disconnect and power on.  Give that a shot chap.
Oct 29, 2009 | Acer (56.04145.901) (5604145901) Power...
Sparking thermolyne 2200 hot plate 120v
The switch is fried, do not use! Replace switch immediately. This can cause a fire. Find a switch that will work for you at the hardware store.
Sep 26, 2009 | Kitchen Appliances - Others
I am only get 7 options not 8.
If you are trying to connect to computer, go to Tools & Apps/Tools/ option
# 8 is USB Mass Storage
Jul 27, 2009 | LG VX-8700 Cellular Phone
KX-TG1000N new handset 1
For KXTG1000 only
  • The base unit must be connected to the AC adapter and the power must be on
  • Press the following sequence of buttons on the base unit: * * 3 3 5 7 8 2
  • When the display reads "Enter Base ID", deregistration has been completed successfully
  • For KXTG1050 only
  • Disconnect the AC adapter
  • Hold the Locator button down while you plug in the AC adapter
  • When the Power light flashes, release the Locator button
  • Immediately press and hold the Locator button again, and release when the In Use light flashes
  • The Charge light should flash for 4 to 6 seconds and then turn off
  • When the Charge light stops flashing, press Locator again
  • In about 20 seconds, the handsets will deregister. When the displays read "Enter Base ID", deregistration has been completed successfully.
  • Jul 15, 2008 | Panasonic KX TG1000N Cordless Phone
    Heating & Cooling Logo
    69 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Donni Steen
