Question about Karcher 2500 PSI Pressure Washer
Katcher pressure washer w/ 5hp Honda Engine
I have a 5 hp Honda engine on my Karcher pressure washer. It will only start and run with the choke pulled all the way out and it only runs at half the rpm's that it should. When choke is pushed in it sputters and quits. Can you help me??
Pour a bottle of carburettor or fuel injector cleaner in the fuel tank, replace the spark plug and set the spark pluglug gap at 0.7mm. Replace the air filter element. Also change engine oil if necessary (mobil 10w30 synthetic.
Posted on Feb 03, 2009
  • Mark Harnett
    Mark Harnett Jul 10, 2015
    That is your fix? your serious? That is ridiculous!
  • 26 Answers
Call up karcher and tell them your problem
Posted on Nov 05, 2008
I have a wood splitter that has a honda GCV160 5HP engine, when I choke it to start, it does find, but when I push the choke in, the engine will not run smoothly, it acts like it's not gettingg en
Sounds like debris in the carburettor. The carbs on these are relatively simple things which come apart easily. Check for debris or water in the float-bowl, and ensure both your idle and main jets are clear and you can see daylight through them.
Oct 10, 2012 | Karcher 2500 PSI Pressure Washer
I have a pressure washer with a hondaGC160 5.0 engine and i can't get it to start
1. make sure you have all fresh gas in the tank. 2. choke on 3. engine switch on (red thing on the side) 4 fuel switch on 5 make sure pressure is off hose (keep the trigger pulled) mess around with different choke positions and see if that works
May 15, 2011 | Honda Karcher G2400HH-R Pressure Washer
Honda engine will not start,,,new plug, new gas, new oil
Karcher Model G2650 OH with Honda 6.0 HP, GC 190 Engine. Engine won't start. New gas, has spark. Seems to flood instantly. Much gas in cylinder. Spark plug wet. Choke pulled out, power on. Oil OK. released pressure in line. Where can I down load a Honda Engine manual! Thank you !
Jul 06, 2010 | Karcher 2500 PSI Pressure Washer
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
Pressure Washer trouble The Engine Won't Turn Over. What's Wrong?
well for starters if you let it sit all winter you the pump probably froz up and you might be able to get it un jamed by pouring in oil (any kind) in the hose inlet and let sit one night the try starting
Jun 03, 2009 | Karcher 2500 PSI Pressure Washer
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
Honda 5hp engine wont run
check oil level. it has a low level shut off switch ?? May be it
May 04, 2009 | Karcher 2500 PSI Pressure Washer
% hp Honda Motor runs on choke
Dear LC39B,
Is it possible you are blaming the wrong part of the machine? Did you try the Honda Motor on its own? I am asking , because if the pump of the washer has some fault or a bit jammed, this will demand a lot of power from the Honda. You can try the Honda with no water connection and no gun.
Regarding the Honda motor, you should check the electrical system also. I am saying this because you did not mention it, in your service procedure.
Nov 02, 2008 | Karcher 2500 PSI Pressure Washer
Pressure washer wont run unless choke is on
I have a Karcher pressure washer w/ a 5hp Honda engine. It only will run while the choke is pulled out and only runs at about half the rpm's. When the choke is pushed in.. it coughs, sputters and shuts off. Can you tell me how to fix this....
May 12, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
1,227 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
