Question about Motorola Mobility RAZR V3
My Razr doesn't know that it's closed
Recently i changed the housing on my razr and i put everything back the way it was (at least i believe i did) but now the phone doesn't know that it's closed when i close it. The outer screen continues to show the logo. Not to mention that it makes it so that all the outer buttons are still functioning so anything that touches the phone makes it make noises and stuff. Any help would be greatly appreciated! Thanks
There is a magnet on the upper part that has to be sensed by a sensor on the lower part. If the phone is open, the magnet is located on the bottom right hand side of the upper part. The sensor is located above the right soft key. To fix mine...close the phone...I opened the battery door, above the battery on the left side is the back of the sensor... it did not appear to be glued to the housing...very gently push the sensor in... it should feel the magnet and the front screen should come on... at least it did on mine... good Luck
Posted on Jul 29, 2007
    Problem Solver:
  • 7 Answers
There is a little magnet in the inner half of the flip, below the screen. it is on the right side if you are looking at the phone as you would normally use it. I hope you kept the old housing...
Posted on Oct 10, 2006
It could be the battery. Or just the phone. Same thing happened to me actually. After about a week of it happening, it started to work properly again. But just in case, you might want to get it looked at or just get a new battery. Your provider should be more than happy to send you a new phone if it doesn't work.
Posted on Jun 10, 2007
I'm having the same problem with my phone... did you ever get it fixed without having to replace the phone?
Posted on Dec 14, 2006
Razr screens
Sounds like the phone is defective..Contact your cell phone provider to see if they are willing to replace it for you...I believe most company gives you one year warranty for the phone...
Hope that helps
Please rate accordingly
Thank you
COmputerrep
Mar 20, 2008 | Motorola Mobility RAZR V3
V3 outer screen
There's a tiny magnet in the top of the flip, near the hinge.. try taking a small magnet and hold it over the keypad near the hinge, and see if it doesn't think it's closed, if that magnet didn't get put back in the flip, then the phone won't know it's closed.
good luck!
Oct 26, 2007 | Motorola Mobility RAZR V3i Cellular Phone
I have a motorola razr v3x phone, problem with water damage
I dropped my in the bath tub giving my little girl a bath. I pulled the back cover and battery out and sat it upside down, back faceing up, under a lap and turned it over every hour. The next morning put the battery in and closed it up, no problems - till the next time it went swimming and had to repete the process.
Sep 16, 2009 | Motorola Mobility RAZR V3x Cellular Phone
RAZR won't turn back on, it just freezes
Try opening up the back then take out the battery make sure there isn't any dust or anything foreign inside near the battery connections. Put the battery back in, close up the back. Turn phone back on.
Jan 09, 2009 | Motorola Mobility RAZR V3
Broken Front LCD Screen On A Motorola RAZR V3C?
I have been buying and repairing razrs for a month now and know how to do this well first of all you will need a t6 screwdriver to take out the 4 screws then you need to seperate the housing with a credit card or somthing thin it may be a little tight but dont worry about it breaking it will come off some have two little flex cables connected and some have one check yours and disconnect then carfully pull your lcd out and put your new one in.
Sep 22, 2008 | Motorola Mobility RAZR V3
Strange issue with Motorola Razr
it also happened with my sony erricsson t230. i believed it is some kind of bug in there messing with ur phone.
Jul 09, 2008 | Motorola Mobility RAZR V3
RAZR V3M thinks it's always open - Screen will not turn off
in the top right corner you are suppose to have a little circular magnet that changes the screen when the phone is open or closed. I just changed my housing yesterday and took the magnet out and put it in my new housing but for some reason i have the same problem as you. so maybe you lost the magnet when you replaced the lcd and if that is the case then you are screwed. try have Motorola fix it, don't tell them you replaced the lcd
Dec 04, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Razr v3
maybe you should buy another housing, doesn't seems like fit on your phone!
Apr 06, 2007 | Motorola Mobility RAZR V3
New Message Wont Dissapear
So you called it and left it a messege? And then went back in a deleted it? If that doesnt work, take out the battery and leave it out for a bit and put it back in. *US Cellular Worker
Dec 10, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
121 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
