Im installing my logitech quickcam and after plugging in as prompted, a box popped up saying that file "usbccgp.sys" for windows xp system pack 2 is needed. Don't know what to do because I'm not sure if I can even find the xp install CD.
You may need to perform a clean install of the Logitech camera software if it didn't install properly or a another program in memory is conflicting with it. Removing the camera software and reinstalling it using a clean boot procedure may resolve the symptoms you are experiencing.
The following instructions will walk you through this process:
Remove the Logitech camera software.
Unplug the camera from the computer. Later you will be prompted by the software to plug in the camera; do so at that time only.
Open the Windows Control Panel.
Open the Add / Remove Programs window.
Locate the listing for the Logitech camera software and remove it. When prompted to remove the camera drivers files, click Yes.
Prepare the system for installation of the Logitech camera software.
Go to the Logitech Downloads Page and select your product to download the correct version of the Logitech camera software.
As long as it's a fairly new printer, 2000 +, just when you get to the compatibility screen select to install anyway. This happens because the drivers weren't signed by microsoft for use with xp.
look for yor camera model, click download software then choose your operating system on the next page that will give you the logitech software that you need to install to fix your issue
Do you have antispam or antimalware software running? mostlikely they removed or didnot let you install the file LVCM.sys which is part of the logitech drivers. Description: File LVCM.sys is located in the folder C:\Windows\System32\drivers. Known file sizes on Windows XP are 1317152 bytes (50% of all occurrence), 472396 bytes. The driver can be started or stopped from Services in the Control Panel or by other programs. The program is not visible. File LVCM.sys is a Microsoft signed file. The service has no detailed description. It is not a Windows core file. Therefore the technical security rating is 14% dangerous.
Important: Some malware camouflage themselves as LVCM.sys, particularly if they are located in c:\windows or c:\windows\system32 folder. Thus check the LVCM.sys process on your pc whether it is pest.
