Question about HP OfficeJet J4580 All-In-One Laser Printer
Ringer How do adjust the level of the ring tone or turn off the ringer completely
    Master:
  • 461 Answers
I looked but didn't see anything in the manual. Maybe the ringer is disabled if AutoAnswer is off. Here is a link to the manual.
Posted on Dec 12, 2008
I have a Meridian 9316 phone in my office and it continuously rings with no pause how to I stop the ringing besides from turning the volume off
Setting the ring tone and ringer volume You can choose one of the four different ring tones and set the ringer volume. To set the ring tone and volume: 1. Make sure that the ringer is turned ON. 2. Press the Set Options key. 3. Press the down arrow three times or press [3] to go directly to the item. 4. Press [3] and follow the instructions on the display. When picking the ring tone, press the volume bar to adjust the volume. 5. Press [Save] to end when you are satisfied with the ring tone and ringer volume.
Apr 30, 2015 | Nortel Meridian 9316CW - 1 Line...
My KX-TG4031 does not ring. I only hear the messages when someone phones. How do I turn on the ring tone?e
Open menu and scroll to see tones and ring volume. you can set this up to a desired level as it will ring to indicate the level. The volume also can be pushed up or down on the control pad. If this is not working there is fault on the ringer circuit. check if the ringer is switched off or put to silent.
Oct 04, 2011 | Panasonic KX TG4031 Cordless Phone
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
Please advise as to how to increase the VOLUME on my DECT 6.0 phone.
To adjust the ringer volume:
  1. With the phone in standby, press ^ or v. The display shows the current volume level and the handset sounds the ringer at that level.
  2. Use ^ to make the ringer volume louder or use v to make it softer or turn it off completely.
  3. When you hear the ringer volume level you want to use, stop pressing keys. The handset will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset won't ring. If you have any accessory handsets, other handsets will ring according to their individual settings.
To adjust the earpiece volume:
You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the earpiece.
To adjust the speaker volume:
You can choose from six volume levels for the handset speaker while on a speakerphone call. To adjust the handset speaker volume, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the handset speaker.
Note: The handset earpiece and the handset speaker have separate volume settings.
Apr 06, 2011 | Uniden DECT 6.0 Cordless Telephone...
How do I turn off the ringer volume??
I found this at hp website.
Adjust the volume
Your HP all-in-one provides three levels for adjusting the ring and speaker volume.
The ring volume is the volume of the phone rings. The speaker volume is the level of
everything else, such as the dial tones, fax tones, and button press beeps. The default
setting is Soft.
1 Press Setup.
2 Press 4, and then press 6.
This selects Basic Fax Setup and then selects Ring and Beep Volume.
3 Press to select one of the options: Soft, Loud, or Off.
Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring
tones.
4 Press OK.
Feb 22, 2010 | HP OfficeJet 6210 All-In-One InkJet...
How can I turn the ringer back on? Thank you
1 Press (MUTE/FUNCTION).
2 Scroll to “Ringer setting” by
pressing öor ñ, and press á.
3 Press áat “Ringer volume”.
4 Select the desired volume by
pressing öor ñ.
•Each time you press öor ñ, the
volume will change and ring.
To turn the ringer OFF:
press örepeatedly until “Off ?” is
displayed.
5 Press á(Save key).
•A beep sounds.
To turn the ringer ON:
Press ñin step 4.
•The ringer will sound at the LOW level.
•You can exit the programming mode any time by pressing (OFF).
•If set to OFF, “Ringer off” will be displayed while the handset is not in use.
•If you have received new calls, “Ringer off” will not be displayed but
“Received calls” will be displayed while the handset is not in use.
“Ringer off” will be displayed for about 5 seconds after completing operations
or lifting the handset from the base unit or the charger.
•You can also select the ringer volume while an external call is being received.
Press öor ñwhile the handset is just ringing.
•You can change the ringer tone for external calls. See page 49.
HIGH
MEDIUM
OFF
Ringer volume
Low High
Ringer volume
Off ?
LOW
ñ
ñ
ñ
ö
ö
ö
V.M. access
HRinger setting
Initial set
HRinger volume
Ringer tone
18
LCD
Oct 26, 2009 | Panasonic KX-TG2352 Cordless Phone
Not working ringer
menu
2 settings
3 tones
incoming call alert (set to ringing)
ringing tone ( pick your ring tone)
ringing volume (set to level 5 loudest)
vibrating alert (on)
message alert tone (pick tone)
instant message alert tone (standard)
keypad tones (on)
warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok
alert for (all calls)
Jul 03, 2009 | Nokia 3100
How to inactivate melody ringer
Base unit ringer tone
(use either the handset or the base unit)
Make sure the base unit is not being used.
Setting the base unit ringer tone by using the
4 Select the desired ringer tone by pressing [d]
or [B].
• The handset will ring and the ringer tone will
change. If the ringer volume has been turned off,
the handset will not ring
• You can also select the ringer tone by pressing [1]
to [7].
5 Press Save, then press [OFF].
Press VOLUME [<] or [>], then select the desired ringer tone by pressing
[1] to [7].
[1] to [3] : Bell ringer patterns [4] to [7] : Melody patterns
• After pressing VOLUME [<] or [>], the base unit will ring using the current ringer
tone.
• The base unit will ring and the ringer tone will change.
• To stop ringing, press [STOP].
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [d] or [B], then press
Select.
3 Scroll to “Set base unit” by pressing [d] or [B], then press Select.
4 Press Select at “Ringer tone”.
5 Select the desired ringer tone by pressing [d] or [B].
• The base unit will ring and the ringer tone will change. If the base unit ringer
volume has been turned off, the base unit will not ring
• You can also select the ringer tone by pressing [1] to [7].
6 Press Save, then press [OFF].
This Can Be Found On Page 17 And 18 Of The User Guide.
If You Do Not Have The User Guide It Can Be Downloaded Here
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Choosing Fixya.com
Dec 21, 2008 | Panasonic KX-TG2357 Cordless Phone
Programing
Here are some suggestions Volume You may adjust the ringer, speaker, handset and headset volumes independently with the VOLUME ^ and VOLUME v buttons. Your telephone comes with predetermined settings which can be adjusted to individual taste. You will hear an error tone when the maximum or minimum volume level is reached. During volume adjustment, a ?dashed line? icon shows in the display. Adjusting the Ringer Volume Press the VOLUME ^ or v button while in on-hook mode. And/or 1 Selecting a Ringer Tone You may select the ringer tone for each line independently. You may choose to turn the ringer off or select one of the four available ringer tones for each line. 1. Press STORE. The red indicator blinks indicating unit is in Store Mode. 2. Use the number pad to select a ringer tone 0 through 4 (selecting 0 turns the ringer off). 3. Press STORE and then press the desired line button. NOTE: The line indicators continue to flash for incoming calls even with the ringer disabled. You may not select the same ringer tone for both lines. Checking the Ringer Settings Check the setting or each ringer (on, off) by pressing STORE, followed by LINE 1 or LINE 2 button when the phone is on the hook. The ringer setting of the selected line will be shown in the display. If there are any further questions or comments please post here. Please rate this solution through fix-it. Thank you.
Jun 23, 2007 | GE 29485GE2 Three - Line Speakerphone w/...
HP OfficeJet J4580 All-In-One Laser Printer Logo
161 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
