Need to replace door on right side facing back of camera. Can I do this myself?
Just check out this link i m sending you for your device.
every thing is given in it as how to replace the door manually .save this link in your data base so you can use this if u face any other problem further other then this.
http://www.fixya.com/support/p223253-fuj...
just click this link and everything will be given clearly in it with diagrams and proper how to do instructions.
thanks.
If it does not require you to dismantle the whole case in order to replace the door you should be fine. Else, have a qualified tech at your local camera store do it for. Professional cameras like yours is not for DIY.
First question you need to ask is. Do I have a warranty on this camera? If so you should take it to their recommended service shop to avoid voiding it.
2nd question Can I find the parts I need either online or at a local retailer? If no then you are better of taking it to a service shop
3rd question Do I feel like I have the technical skill to disassemble this device make the repair and get it back together? If not take it to a service shop for repair
4th question Can the service shop give me an estimate for the repair that is less then 1/2 the value that I bought the camera for in the first place? If no.... then you might be better off buying a replacement camera
I hope this helps you
Dave
If you get a part and a disamble schematic you can.
Yes you can do it but you need some tolls to do that, but its better if you take it to a service center and let them do the job to avoid any further problem with it...
