Question about Freecom (24358) 160 GB Network Hard Drive
Freecom hard drive stopped working for no reason light on but computer can't
Freecom sslaba
3 Suggested Answers
  • 102 Answers
SOURCE: Freecom Password Delete
Everything is possible. Few points. Is this external hd? Did you used the software and the drivers given by the manufacturer? Which OS are you using?
Yes it is possible to erase everything on any type of the drive and start from scratch. You can do this by formatting the drive make sure you do NTFS format.
Let me know please!
Posted on Dec 16, 2007
  • 413 Answers
SOURCE: freecom external hard drive classic 2.5
Have a look here>
http://www.freecom.com/ecDrivers.asp
I can't see any Mac drivers for the drive...
I found this page>
http://freecom-usb-osx.sourceforge.net/
You might be able to get some help here...
Posted on Jul 01, 2009
57 varieties
  • 1653 Answers
SOURCE: My computer has found new hardware for my freecom external storag
It should automatically allocate a drive letter to it. Go to windows explorer and hit F5 to refresh the display and you should see a new drive letter with the name of FREECOM next to it.
Posted on Oct 05, 2009
My hard disk freecom is stuck,but i am able to see the memory status how can i get my data back
The computer repair stores have special software that might help and is worth considering because this is something you cannot do alone.
Mar 19, 2012 | Freecom Computers & Internet
How do I backup files to my Freecom external hard drive XS 3.5 ?? Ive installed it but cannot workout how to use it !! there are no manuals !!
you can open Computer on your screen and then there is C: drive and Freecom labeled to it. Open first the C drive, click Ctrl + A to highlight everything. Then click Ctrl + C. Then go back to Computer and click Freecom. Then click Ctrl + V. All the files will be transferred to Freecom. Then you may proceed for your next step. That is how you back up files.
Aug 10, 2010 | Computers & Internet
Freecom Classic SL hard drive stopped working
Probable reason for failure of a disk is power, if the power is adequate may be some of its components like inductor, diodes in series with the power line are opened, check for any burn marks on the pcb
Jul 14, 2010 | Freecom Classic (22095) (22095)...
Oct 05, 2009 | Freecom (24358) 160 GB Network Hard Drive
My 250gb hard drive is not working
Assuming this external hard drie is powered via USB, you probably just need the drivers:
http://www.freecom.com/ecsupportdetail.asp?serie=Mobile+Hard+Drives&group=1148826&interface=1148827
Jul 01, 2009 | Freecom (24358) 160 GB Network Hard Drive
Freecom external hard drive classic 2.5
Have a look here>
I found this page>
Jan 03, 2009 | Freecom (24358) 160 GB Network Hard Drive
Freecom 400GB Hard drive not recognized.its a Freecom mobile drive xxs 400gb , my pc just cant recgnize the hard drive
I'll assume your using Windows.
I'll assume it's a USB drive.
I'll assume it is an external drive.
And I'll assume it's formatted as NTFS.
Try using the USB (or FireWire) port for anouther drive to see if that is the problem, if it is then reinstall the driver for the port, through the Computer Managment Concole (assuming yur using windows).
If you formatted the drive as FAT, re-format it as NTFS.
Jan 02, 2009 | Computers & Internet
Freecom 400 GB external hard drive not being read by computer an re-installing Freecom Personal suite. When I turn on the external hard drove the power light comes on ( and stays on) and the drive itself...
hi there,
sounds like you have a hardware problem...you should look into trying this drive on another system to see if the same thing is happening without the drive software ...and if it works try to recover all your data from this drive as soon as possible...hardware problems are most time intermittent ... so they work now then say after a while they stop...
Apr 13, 2008 | Computers & Internet
Freecom 400gb Drive
Have you tried to connect those drive individually and checked if they get detected when stand-alone? If they get detected stand-alone, install the Freedom software happen. Cheers
May 23, 2007 | Freecom (24358) 160 GB Network Hard Drive
Freecom (24358) 160 GB Network Hard Drive Logo
249 people viewed this question
Top Freecom Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Geoff
Are you a Freecom Computer and Internet Expert? Answer questions, earn points and help others
