Question about Sony KV-35S40 TV
Intermittent video My grandmother's Sony KV-35S40 has a great picture but intermittently the video cuts out...just a black screen but the audio remains. To fix the problem you just have to turn the set off and then back on. Sometimes this works immediately and sometimes you have to wait several minutes. When you do the off/on thing you will hear a relay click inside if the video is to return but if you don't hear the click there will be no video. She has had a couple of shops look at it and charge her but they can't correct the problem.
    Genius:
  • 1,694 Answers
Even though the pix is good when present, most "S" or "V"
Sony TV's have bad pix tubes.Check the date on the back of yours-is the date prior to 1999?........Then the tube is suspect.
From 1994 on, most common problems were bad connections,resulting in
power supply failures and vertical IC bad connects that just needed soldering.After thousands of successful Sony repairs, I
found that the 1 or 2 % that came back were "my fault" for
mistakenly using the wrong part.I make a good living saving TV's
from pre-mature burial and the first step is correct information to
evaluate-----perhaps that is why my customers keep coming
back to ask questions that get an experienced,logical answer!
Posted on Oct 29, 2007
    Problem Solver:
  • 17 Answers
These have multiple problems due to horrible design and poor assembly. You could probably hit or bump the thing and it would start to work, or fail if it is working. The trouble is loose connecions which are difficult to find. I can think of a better four letter word starting with "S" than "Sony" to describe their products. Perhaps the rhesus monkeys that put this together did not get enough crystal meth to keep them alert. Sometimes the IF module causes this, sometimes poor soldering on the main board can cause something similar. The causes are numerous. I cringe whenever someone brings me one of these and usually refuse the job unless it is a good customer who realizes that the problem is not my fault if it happens again. I think she has already suffered enough with this. Tell her to get an LCD TV with 1920X1080 resolution to replace it. I suggest Panasonic, Sharp, Sanyo, Funai, or Orion. Standard TV's are living on borrowed time anyway, so this is not as dire as it sounds.
Posted on Oct 19, 2007
Sony trinitron 32 inch television model no. KV-32FS13 doesnt have any video nor audio and standby light just blinks about 4 times
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check for any loose sodering points at the vertical output section.
Mar 27, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Have a kv-35s40, and when turned on picture goes on and off, sound is okay all the time. after about 10 minutes, picture then stays on, an tv works fine. only happens when first turned on.
Hello
Your TVs Base card socket, that is the socket connected to the base of the picture tube is loose. Just unplug it and replug again for tow or three times. Please note for any loose sodering occurs to the pins of the socket and the video output transistors fitted on the picture tube base card. This should rectify the problem.
Oct 17, 2010 | Sony KV-35S40 TV
Sony KV-27S10 has intermittent tuner issues. moving the cable connection on the back of the set sometimes clears the picture.
This was a common problem with the Tuners of these models. The replacing of the Tuner should fix the Problem. You may be able to order it from Sony.
Here is their Customer Service Number.
1800-222-Sony
I hope this helps,
Skyassoc
Oct 27, 2009 | Sony KV-27S10 27" TV
Screens nturns black but have audio
Ur video board is dead.Or the video socket connect to the CRT(tv tube) is cold solder.
Sep 06, 2009 | Sony KV-27V40 27" TV
Sony KV-32S66 Picture Rolling Up/Black Horizontal Lines
the problem there is a loose connection on the board,you said that you smacked the right side of the tv and it goes normal.there are parts that should be resolder on the board in order to back into normal operation.
Oct 22, 2008 | Sony KV-32S66 32" TV
Son Trunitron
You have bad solder connections on the vertical output integrated circuit. Since now nothing helps either the solder connections have become very bad OR the vertical output integrated circuit finally failed from the intermittent condition.
Feb 27, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Tv
you should take it to a TV repair place, they charge $50 to look it over.
Dec 17, 2007 | Sony KV-35S40 TV
Picture and sound went out suddenly on a Sony KV-35S40
sony has problem with bad picture tubes as well as flyback transformers .if you have shorted hori output then replace it if set shorts it out again your looking at bad flyback transformer as well as maybe leaky tube.
Oct 27, 2007 | Sony KV-35S40 TV
No video
try to resolder the flyback side,the vertical section,and the regulators.
Oct 15, 2007 | Sony KV-35S40 TV
Sony KV-35S40 TV Logo
49 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
