Question about Sony KV-35V35 TV
Screen Flash I also Have the Screen Flash Issue but it seems to be not as bad after the TV is on for a while and also not as bad when I turn the brightness all the way down im pretty good with electronics if I could get a diagram or really good instructions on what I need to do to resolve this issue if anyone can help I would be forever thankful
  • mertle Jan 08, 2008
    sony kv 35S42
I have a sony trinitron model kv 35S42 i was told it is the ir board should i try the other solutions first? tv comes on but constantly flashes. when playing dvd doesn't flash as often mertle
Posted on Jan 08, 2008
I got a Samsung HDTV model LN40E550F7F.TV will not power on. The Power light is flashing First flash is bright and flash following is dim then back bright then dim.etc non stop.i looked at power supply...
Hi Ricky, Power supply card seems to have gone bad in this case.If you are technical, try replacing power supply board or consult someone qualified to handle your set.
Aug 24, 2014 | Televison & Video
VX37L Screen Suddenly Went Blank, Now No Image, Sound Only on Cable Input, VIZIO Logo Lights Up
turn on the set, grab a bright flash light and dim the lights in the room. Shine the flash light on the screen, if you see a faint picture on the screen, you are dealing with a backlight problem. There are several things that can cause this. One, a bad backlight inverter, two, faulty 24vdc power supply, three, bad main board, or a bad faulty backlamp.
May 10, 2013 | Vizio VX37L Television
I have sound but no picture
oh, so that's your problem. I'm willing to bet you have a picture but just no backlight. Now does the screen come on briefly when you first turn the TV on? Or is the screen black at all times?? Turn on the TV, turn off the lights in the room. Take a very bright flash light and shine it one the screen.I bet you see a dim picture. It sounds like you have a backlight problem. Either you are missing 24VDC from the power supply, 3.3VDC "backlight on" signal from the main board, a bad inverter, or a bad backlamp.
May 12, 2012 | Sony BRAVIA KDL-55XBR8 55 in. HDTV LCD TV
Sony kp 51hw40 rear projector turn off problem .
T8005 etc is NOT the issue.
This set was prone to bad picture tubes (has 3) and can flash bright blue (most common) and set when this happens detects too much current being drawn and shuts down.
There is a fairly easy way to try to deal with this and return set operation to fairly normal.
Not technical and no parts are needed.
Let me know if you want to know with a comment here and I will explain.
Apr 17, 2012 | Sony KP-51HW40 51" Rear Projection...
Tv turns itself off
hello. it sound's like you have a picture tube that is shorting out from a something arking in side of your set.!!! eather on the (CTR PIN COUSHION).!!! OR ON THS CHASSIE.!!! THAT WHAT MAKING IT DO THAT.!!! TIME TO GET A NEW SET.!!! HOPE THIS HELP'S YOU.!!! "GOOD LUCK"
Aug 11, 2008 | RCA 20F511T TV
Dlp tv hl-r5688w samsung
i believe the buld is bad replace it its cost from 200 to 500 dollars depending on the year and model
Jun 20, 2008 | Samsung Televison & Video
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
Sony Rear Projection TV Model # KP 53N74
I have had a similar issue with a Sony 52" circa 2001 tv. It was bad and then got better. The only problem now is that when I plug anything into the component 1-5 (but not 4) the screen is fuzzy. The DVD is plugged into 4 and it works fine. I tried plugging something else into that and it showed up in black and white. Very frustrating. Fancy TV if you only watch cable or a DVD. All other modes show up fuzzy. Sony recommended a tv repair place in St. Paul but they want around $400 just to look at it.
Sep 26, 2007 | Televison & Video
Tv Flashes
key2life316,
Your TV has a bad picture tube = no reasonable repair possible......time to go shopping!....................T.
Guest,
Your TV has a bad pix tube + a blown power supply!!
Time to move on ........T.
Aug 25, 2007 | Sony KV-35S42 35" TV
Televison & Video Logo
55 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
