Question about HP f2105 21" LCD Monitor
Monitor wont Stay On!
Hi my monitor comes on for about 3 seconds, and then goes off? Any suggestions as to what might be the problem?
  • Anonymous Dec 17, 2008
    monitor shuts down but blue light stays on. if i turn power on and off monitor will flash on for about 3 seconds at a time.
  • Fran Bednar
    Fran Bednar May 11, 2010
    Does your power button light stay blu or green after the screen blacks out ? Or does it turn amber or orange ?
    Was the monitor hit hard on top or bottom or dropped ?
    Did the screen show and redness or a pink hue when started up when it was last running ?
    It sounds like the power-inverter board or a backlight bulb is causing your problem.
First you have to install anti-virus software, run a full scan and restart the computer. If you already have some on, then just run a full-scan. Then you have to erase a heck of a lot of things from your computer, prefferably everythingthat you dont use. Or you can use a flash drive or external hard drive, anything to take the stuff off your regular drive. The screen goes black but if you hold a energy saver light bulb close enough to it you can see what your doing (energy saver light because they are easy on your eyes). Then you have to downlaod something that would give you virtual memory (just type "virtual memory" in your search engine, anything really works and they are free - mostly). You may have to restart again after that. Finally, defragment the the computer AND LEAVE IT OFF FOR AT LEAST TWO HOURS.
This solution is not 100% cure but it has worked for me, and when I turned my computer on I still had to turn the monitor off and on a few times but it was much less and it eventually stayed on. Personally I wont turn it off again, but if your problem still persists, call a technical genius for help, or get a new computer - THE PROBLEM IS NOT THE MONITOR, ITS THE PCU.
Posted on Jan 31, 2009
Monitor wont stay on
turn off power saving mode on the monitor
Apr 10, 2016 | Hanns.G 22"" hi221dpb dvi widescreen lcd...
My monitor won't come out of sleep mode
when the computer enter the sleep mode, it is possible that the computer remove the check mark from this output activation.
When you have multiple ouptut like a internal LCD and output on a monitor, when going into sleep then waked up, laptop reactivate the internal LCD without reactivated the secondary monitor.
you could need to go in desktop property and reactivate the secondary monitor with the check mark listed : Activate.
If you only have one monitor but still a dual output card or two separate video card same thing can happend. try to connect the monitor on the second VGA or HDMI output and see if the video goes there.
then reactivate your secondary output and make it principal.
Does also happend when your computer is connected to a UPS power and your monitor is directly on the sector. (laptop issu also)
if a brief power outage arrive then the monitor shut down (no power) and the computer continu, as there is no monitor on the output any more Windows will automatically deactivate this monitor. when power goes back, this output is no longuer providing video. I suggest putting the monitor on a UPS as well.
Jan 03, 2014 | Westinghouse Electric L1916HW 19" Monitor
Monitor comes on but then shuts off in about a second
Try reducing the resolution (boot at safe mode)
Stelios.
Feb 22, 2010 | Dell UltraSharp 1908FP Monitor
When i turn on my flatron 22 inch monitor the blue power button comes on for a second then goes out,it will not stay on.
HI,
your monitor is not working properly, bcoz monitor data cable no connected properly into the System or any internal problem in your monitor.
Thanks
Aug 15, 2009 | LG 22" FLATRON LCD Monitor
Monitor comes on momentarily then black...tried 2nd monitor same
I suggest you try another video card in your computer. This may be the culprit if the second monitor did the same thing as the first. If the different video card does the same thing, I would then suspect the motherboard.
May 31, 2009 | Samsung SyncMaster 931BF LCD Monitor
Dell E156FP Monitor Problem
If the screen is not completely black (i.e. just very very dim, turn the lights off to see) try using the controls at the bottom of the monitor to reset to factory settings (all settings). I have had this problem with two dell monitors so far and this seems to work.
Jan 08, 2009 | Dell E156FP 15" LCD Monitor
Lt982s
Hi...there,
You've got a busted backlight inverter...
Dec 17, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
Monitor going black
HP's are known for bad capacitors in the power supply.
Replacing them is simple if you know how..not so simple if you don't.
Try your local TV repair centre. It should not cost alot to have the capacitors replaced.
Hope it helps =)
Apr 06, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
HP f2105 21" LCD Monitor Logo
214 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
