Question about Breadman TR2500BC Bread Maker
Bread pan jumps off of its fastener clips.
During second knead cycle, as dough ball becomes firmer, bread pan jumps up off of its two fasteners which are located on each side of the pan bay. I have to stand watch over the machine and push the bread pan back onto its fasteners when this happens. The problem will continue until the force of the kneading becomes lessened as the consistency of the dough ball changes. Thanks for your time. Dave
  • 3 more comments
  • gburg34 Feb 10, 2008
    Am having the same problem, although I haven't isolated it to any specific phase of kneading. I was hoping to find the solution at a Salton support site. That apparently does not exist. I will try bending out the clips on the side of the housing to better engage the spring clips on the pan and let you know how that works. The sound it makes is extremely annoying and, if allowed to go uncorrected, will surely damage the unit.
  • Anonymous Feb 14, 2008
    I've just bought the TR2500BC 10 years after I bought a really basic machine and I really enjoy all the features. I'm having the same problem with the pan and it doesn't seem to matter how big the loaf is or what type of bread it is. Any help would be greatly appreciated.
  • iwyllpa Mar 13, 2008
    I have this same problem with my Breadman Ultimate Plus. I've had it about a year now, and for the last 5 times I've made bread or so, the clips inside the breadmaker just haven't been enough to keep the breadpan stationary. This last loaf I made got to the point where I had to just hold it down the whole time it was on knead cycle 2. I've tried bending the clips a little bit, but I haven't wanted to do too much for fear of breaking it. Anyone have any ideas? Or for that matter, does anyone know where an official forum is so we can ask there?
  • Anonymous Apr 01, 2009
    Same thing--I usually just take the pan out at that point and wait for the kneading cycle to end; then put it back in. Very frustrating.
  • Anonymous Mar 12, 2014
    This happens mostly during the first knead, but sometimes during the second as well.
I have the answer to the TR2500BC pan popping off the base!! My husband and I made a loaf for testing the jump off. Ah HAH! I set the pan in, ok. felt it was down all the way. When it started to knead the ball and stop to reverse...it popped off. We looked at the side hook on top. ok. It popped off again. It was when my husband made sure the two tabs on the under side of the pan was in the opposit direction of the two buds in the base. at that point you MUST set the pan down with force until you get that distinctive click, click. Rock the pan front to back a bit as you push down. It has worked every time since I started that process. I make two loafs of bread a week with no problem of it hopping off. ENJOY.
Posted on Jul 20, 2008
I took a piece of #12 wire and placed it from one side of the pan into the hole in the clip to the other side of the pan in the hole in the clip. The pan can not move up and disengage when the wire is in place. the wire may be hot when the baking cycle is completed. This has worked great and we don't have to keep re-seating the pan.
Posted on May 11, 2009
Make four wedges, place two on each side of the pan. ensure the wedges have a lip that fits over the pan so it can not slide down into the heater coil
Posted on Aug 25, 2008
I have the same bread machine and sometimes it has the same problem. my solution is to take the pan out and place it back as deep as possible. i even made a little mark on one side of the pan and it's always on right side when it's in a machine. but the rule is to place the pan deep. sometimes it just looks like deep enough but not really. hope it'll help.
maria.
Posted on Apr 24, 2008
I have a similar problem and have done the following: I made four wedges to hold the pan in place with a little lip so they cannot slip down and contact the heater coil. Put the pan in place, pop in the wedges and you are away. If your machine is still under warranty they will replace it!
The first thing I tried to hold it in place was a spatula (big) The handle was the perfect width to hold the pan in place. From there I made the four wedges.
The first time I used mine, it popped out at least a half a dozen times. The handle sides of the pan, the edges were bent slightly down. I bent the edges slightly up. The pan seated much firmer and only popped out once the next time I used it. I think with a little more tweeking I'll have it fixed.
Posted on Jun 09, 2008
  • Exeter Oct 23, 2011
    I see that was my problem, too. The tabs on the bucket were sliding UNDER the clips in the "oven". The frequent answer of "with your finger pull the metal clips (in the "oven") outward to create more pressure" only increased the problem. With a pair of pliers I bent the tabs on the bucket upward as far as I could. Now it looks like they will stay hooked into the side clips of the "oven". I think those clips are place too high, and the manufacturer should address this and lower them in future models.
I had the same problem. When I called the company, they told me to add a tiny bit of water to the dough, 1tsp. at a time. This solves the problem. If you put your finger in the dough, it should be sticky. Be very careful adding the water because you can add too much with little effort. Good Luck!
Posted on Jan 01, 2009
SOURCE:
Kneading Paddle
All bread machines have a final "punch down" of the dough that lasts a few seconds before the final rise stage. When "punch down" is over that is when you can remove the dough ball, remove the paddle, set it aside and place the dough ball back in the pan. It usually helps to have your hands dusted with a little bit of flour.
Apr 21, 2013 | Morphy Richards Kitchen Appliances -...
Paddle problems.
All bread machines have a final "punch down" of the dough that lasts a few seconds before the final rise stage. When "punch down" is over that is when you can remove the dough ball, remove the paddle, set it aside and place the dough ball back in the pan. It usually helpsicon1.png to have your hands dusted with a little bit of flour.
Apr 21, 2013 | Morphy Richards 48280 FastBake Bread...
The paddle for my Breadman BK1060BC has been coming off during kneading. Today, I saw some grey residue in the dough. Is the problem with the paddle, pan or both? Thanks.
I just purchased this 2 days ago and started to use it. I noticed the bread pan would wobble and was noisy during the kneading cycle. On the second use the paddle came off during the kneading cycle. Being a service technician all my life, I started to analyze the problem. I was previously surprised how loose the bread pan fitted into the bread maker and suspected there should be something to support the pan and hold it in place. I could not see anything obvious, but after looking carefully I noticed spring clips on the bottom of the bread pan, and also mating spring clips in the bottom of the bread maker. If I pushed the bread pan down fairly hard into the bread maker the bread pan would snap firmly in place. This stopped the wobbling during the kneading cycle and the paddle coming off. I could not find anywhere in the manual where it explained the bread pan must be pushed firmly down into place until it snaps in. The manufacturer should explain this to their customers on their website.
Apr 23, 2011 | Breadman TR2500BC Bread Maker
My paddle keeps coming off when the dough is mixing. What's up with that?
Your paddle is probably worn out and has too much play in it. Some play is necessary to get it off for cleaning but it shouldn't be so loose it is coming off during kneading.
Nov 14, 2010 | Breadman TR444 Bread Maker
Kneading problem - lop-sided loaves
it is very imporant that you put the ingredients in the right order (water on the bottom, flour floating on top o it, yeast on the flour not touching the wwater). Also the amount of water is crucial.
The bread becomes evenly distributed during rise.
Rise problems might be due to improper kneading which in turn might be due to the pan jumping. Check that the pan is not jumping during kneading.
Jan 08, 2010 | Breadman TR2200C Ultimate Bread Maker
Bread pan pops out during the kneading 2 cycle
I had a similar problem after using the same machine for several years. It worked well for years and then popped off the shaft whenever I had a rather stilll dough. To solve the problem I bent the clips on each side of the bread pan that hold the pan into the machine up and toward the center of the machine. I did not use any tools to do the bending. It solved the problem. The pan no longer jumps up out of the clips and off of the shaft.
Jun 02, 2009 | Breadman TR2200C Ultimate Bread Maker
Bread pan pops out during kneading, hard to remove after baking
I have Breadman Ultimate for over 12 years now. I make bread 2-3 times a week for the past 10 years. I found that the bread pan popping out only happens when the motor shaft and the kneading paddle are not tightly engaged. I find this problem in the following two scenarios: 1. The bread pan was not pushed down all the way as described by cassie_hobbs and tlcquiltnut. 2. Debris filled up the motor-shaft bowl underneath the bread pan to prevent a tight engagement of the motor shaft and the kneading paddle. These debris are generated during the kneading process; part of the ingredients is pushed out of the shallow horizontal pan and accumulated underneath. To avoid the problem, I have to periodically remove debris from the shaft bowl and make sure the pan pushed all the way down. To reduce the debris, I made a simple cover for the bread pan by cutting an old aluminum baking dish. I always remove the cover after the kneading cycle to prevent the rising dough from reaching the bottom of the cover. Hope this helps. Wendy
Feb 22, 2009 | Breadman TR2200C Ultimate Bread Maker
Bread dough
IT NEEDS TO PROOF LONGER
Dec 10, 2008 | Hobart N50 Stand Mixer
West Bend Bakery Style Bread & dough Maker
west bend site.
http://www.focuselectrics.com/catalog.cfm?dest=dir&linkid=54&linkon=category
Jun 26, 2008 | West Bend 41053 Bread & Dough Maker
Breadman TR2500BC Bread Maker Logo
686 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Irene Tulloch
Steve Allison
Steve Allison
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
