Question about Frigidaire FEF355 Electric Kitchen Range
WHAT I NEED TO DO TO MAKE OVEN HEAT UP
WHEN I SET TURN OVEN ON I CAN SET THE DEGREE BUT OVEN WON"T HEAT UP AND THERE IS'T ANY F CODES POPPING UP
  • Anonymous Mar 30, 2014
    When i turn the button on the big cooktop won't heat
    Sergeant:
    Champion:
  • 324 Answers
Can you see the glow inside the bottom of the oven?if you can then your bake ignitor may be bad.
Posted on Nov 05, 2008
Samsung un55f6300afxza sometimes won't turn on
It is a common problem with a defective main board. You may re-flow the soldering yourself by this procedure.
Re-Flow Soldering Procedure for Main Board
    1.Pre-heat your kitchen oven to 385 degree (No more than 400 degree);
    2.Put the main board on a card board (like a pizza box board) in the oven;
    3.Heat it for 10 minutes (No more than 10 minutes);
    4.Turn the oven off & leave the door open, at this moment, do not touch or move the board until it colds down to the room temperature.
    5.Install the board in the TV & try it out.
Aug 31, 2017 | Samsung Televison & Video
Oven won't heat
You might have to unplug it let it set for a hour then plug it back in and it might set it self.
Dec 31, 2012 | KitchenAid Kitchen Ranges
Oven won't heat up, but no error codes
I called the repairman for help. Turns out that one of the suggestions would have worked if I could go to basement turn off breaker then run up and carry out the suggestion and run to the basement again and turn back on breaker, then up again faster. The repairman was able to fix problem by using me as the go between the breaker and the oven. He stayed up and I stayed down thereby eliminating the problem of not being able to run up and down fast enough myself. The two of us were able to make things happen in the time limit. I think I should have gotten a break on the bill since I played helper!! If anyone else has this problem and has closer access to the breakers than I, they would be able to cut the repairman out of the picture and save the service fee. Maybe I should run up and down from oven to breakers for a set amount of time for exercise in preparation for the next oven problem. May be easier to get a new oven without a computer in it if such a thing exist anymore because at 77+ I don't think I am going to get much faster even with exercise.
Dec 19, 2012 | Maytag CWE5800A Electric Double Oven
New oven won't heat
1.Check sensor connection. 2.Measure sensor resistance (1080 Ohms at 70 degrees F. Add 2 Ohms per degree F). 3.If resistance is not valid, replace sensor. 4.If sensor resistance and connections are good, then check for welded-closed relays on the control.
Here is the sensor to order if it is bad.
Nov 28, 2012 | Ovens
Mer6772bas ovens won't work, bottom oven won't open
F1-4 is a lower oven runaway clean error F9-3 is a lower oven door latch failure. Must be a bad door latch causing the errors.
GEMINI FAULT CODES
Aug 30, 2012 | Maytag MER6772BAS Gemini Electric Kitchen...
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
My oven does not heat to the correct temperature. If I set it for 325 degrees it will heat to 390 or so degrees. It always seems to be about 70 degrees too high. Accross all ranges of temperatures from...
The thermostat is the cause of the problem, normally the the only cure is to replace the oven thermostat,completely, or alternatively, compensate by setting a lower temperature when cooking.
this will work o/k if it is always the same variation in temperature across the range .
Dec 25, 2010 | Electrolux 30" Built-In Single Electric...
Makes a popping noise and fan tries to start fan when oven is not on.
Can't explain the popping, but the fan has a heat sensor that will turn it on when it gets to a factory set temperature.
Jul 07, 2009 | Whirlpool GH6177XP Microwave Oven
Maytag gas oven cycles every 20 seconds
yes it is normal . but i know your not the first to think its not , todays ovens are so tight , it only takes 10 seconds of heat to keep them at proper temp . it used to be that ovens where kept at a 3 degree sweep that is set at 350 turn on and up to 353 then off ,cool down to 350 and back on . this was a longer time off and a longer time on topday we keep to 1 degree ! 350 on to 351 off to 350 on and so on ....... so short berst of heat make for a more even oven ........ but i know i hate it too ! good luck
Jan 18, 2009 | Maytag CWG3100A Gas Single Oven
Frigidaire FEF355 Electric Kitchen Range Logo
338 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
