Question about Cuisinart DLC-5 Food Processor
I have ordered a replacement stem for my DLC-7, the stationary stem that covers the motor shaft. I'm not sure how to remove the one currently on the unit.
  • 8,596 Answers
Remove the pusher sleeve and lid from the work bowl first, then slide the work bowl out of the locked position. At this point, the stem should be exposed.
Posted on Nov 25, 2008
Blade of cusinart dlc 7 superpro food processor will not spin when food is in the bowl- works when no food is in it. Is it is the stem? How do I replace it?
It'll probably cost more to fix than replace. If you have a collection of blades, maybe find one in working order on a shopping site and meld the two together. Happy hunting! Happy New Year!!!!
Jan 01, 2015 | Food Processors
How do you get the motor shaft cover off? I need to replace the old one.
The shaft is spinning inside the sleeve. So is should not be hard to remove. With a DLC-7SP, I grabbed the spindle with some pliers, channel locks might do well and put a handle of a screwdriver between the pliers and the top deck and pried. Second attempt and it pulled up easily. Place the screwdriver beside one of the top deck screw covers to transfer force directly to the motor. Otherwise top deck would probably break.
Oct 07, 2010 | Cuisinart DLC-7SFP Pro Food Processor
Cracked plastic sheath on the motor drive shaft
Clean the old shaft to remove any contamination.
New one can be driven on with a hammer and block of wood.
Jul 08, 2010 | Cuisinart DLC-7SFP Pro Food Processor
The stem on my food processor is broken. Help to remove old part
Hi-I have a DLC-7, it looks a lot like yours. On my machine the stem is removed by pulling straight up. It is held only by the friction of a knurled section of the shaft, no threads or other fasteners. You could grip it lightly sideways with a pliers or vise-grips and then use hammer head to tap upwards on the side of the pliers. Squeeze the shaft firmly enough to grip it adequately, but not so hard as to crush it.
May 07, 2010 | Cuisinart DLC-8S Pro Custom Food Processor
How to put new shaft on cuisinart food processor model DLC-7E
Initial disclaimer: I am not recommending this course of action - my recommendation is to buy a new food processor. These units weren't designed for DIY repair, so this is going to be a difficult task. The final product probably isn't even going to be pretty. You are well out-of-warranty, or I wouldn't even consider posting this. First, make sure you have a DLC-7E shaft - the only way to get one at this point would be to buy a DLC-7E base from eBay or an after-market seller, as all of these were manufactured well over 20 years ago. I don't currently see any eBay listings for one, but they do crop up from time-to-time. Make sure the DLC-7E you are repairing and the old one from which you are wrenching the old shaft are unplugged and have been unplugged for an hour or longer just to be on the safe side. Unscrew the four screws on the bottom of the base on both units. If the bottom base does not come off after this, carefully pry out the four feet and unscrew any hidden screws that might be hidden underneath the feet (Careful - original feet cannot be ordered by normal means, and damage will only add to your total repair cost). Take note of the guts on the inside of both food processor bases - if you have to unscrew the motor body (4 screws that sit just underneath the top of the base), take note of everything that you are taking out so that you can put it back in its proper place when done. Wear leather gloves for safety. Please be aware that even an unplugged unit still has the potential to send several volts of electricity through your body - this is a potentially hazardous task. Once the motor body has been unscrewed and removed slightly (don't disconnect any wires or cables - just get the motor body out of your way), you will notice the old shaft that you intend on replacing. Look for any damage to the gears/bearing that surround this shaft. Try dabbing a small amount of USP-grade mineral oil on any bearings - clear away any dust or debris that may be obstructing the shaft from turning. Don't overapply the oil, or the wetness will seep into other electronic components in the motor and cause them to fail. Put your food processor back together, turn it on, and press the button/buttons on top of the base of the food processor with a pen with the food processor plugged in. If the shaft still won't turn, you definitely need to replace the old shaft (you can disregard some of these previous steps if your problem is that the spindle on the old shaft is worn).
Remove the screws and disassemble the processor base as described above. Since there is a layer of paint/coating surrounding the old motor shaft, removing the old shaft may cause paint flecking. Take the shaft from the one food processor base and insert it in the food processor you are trying to repair. Strip away any excess paint/coating from the new shaft. Make sure no paint flakes remain in the body of the food processor, or they will later cause more serious problems that will permanently damage your food processor - potential fire hazard as well. You will probably notice that the new shaft does not look as pretty as your original shaft, since the paint/coating will almost invariably get damaged in this process. Reassemble the base of the food processor, making sure no wires, etc. were knocked out of place in the process. This paint flecking will add to the cost of the repair - you may need to buy appliance body paint that dries to almost a rubbery consistency to make the final project look nice. All of the materials listed above could cost you $40 or more.
Like I said, I don't reccomend this course of action, but there's your answer.
Mar 11, 2009 | Cuisinart Food Processors
Cuisinart DLC-8 Plus Motor Shaft Cover broken.
I had the same problem: Cuisinart sent a "replacement" sheath for my DLC-8E which turned out to be the wrong one. When I replaced mine,which was cracked, none of my blades would fit over the new sheath! I "solved" the problem by purchasing a new DLC-8E motor base on Ebay for only $9.99!
Mar 09, 2009 | Cuisinart Food Processors
How to attach Cuisinart blades DLC 8 to DLC7 stem
The DLC-8 blades and the DLC-7 blades are not compatible. To attach the stem, first attach the stem to one of the compatible blades - the stem should day "DLC-7" for the DLC-7 blades - by inserting the first two tabs of the stem into the first two ridges of the blade connector - the left-most tab should be sticking out past the end of the blade connector - then slide the stem into place so that all tabs fit securely into the blade connector. Next, place the end with the blade up and insert the stem into the middle of the workbowl. There is a video for all Cuisinart food processors on the Cuisinart website.
-Tha Mp3 Doctor
Jan 01, 2009 | Food Processors
Sure, you can find it on amazon, here: Amazon com Cuisinart Motor Shaft cover. Hope this was helpful. have a nice day
Nov 16, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart Food processor
Go to the cuisinart website and you can buy replacement parts. You will have to buy the entire shaft not just the top but it is still good!
Mar 25, 2008 | Cuisinart DLC-10S Pro Classic Food...
Install Cuisinart stem cover
I was able to replace my pieces thru Small appliance.com I ordered new parts and the directions on how to remove the old stem and put the new one on.
Put a little vaseline in the rim of the new stem. Use a wooden block and a hammer or rubber mallet and lightly tap the new one into place.
Cuisinart called two weeks after the fact to say I have to send them the machine.....
Oct 17, 2007 | Cuisinart DLC-10S Pro Classic Food...
Cuisinart DLC-5 Food Processor Logo
338 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
downhille
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
