Question about Pentax *ist DS Digital Camera
Technical problem camera will not operate. a blinking battery symbol in display panel only. cr-v3 battery voltage test reading is 2.94v substituting with 4 aa duracell coppertop batteries does not do anything- non operative and no display
  • 2 more comments
  • henry weslake Oct 11, 2006
    a solution was found for the battery problem.
    although the cr-v3 batteries each tested 2.94v, they were underpowered to operate the camera.
    as for the 4 new aa duracell coppertop alkaline batteries which each tested 1.598v,they were either not strong enough or to slow to powerup.
    however,4 new aa energizer e2 batteries which each tested 1.615v operated the camera perfectly.
  • misterclick Nov 02, 2007
    My ist DS SLR digital has worked fine till now-using 4 re-chargeable AA batteries, which I realise have a life of about 18 months, started to display either empty batteries of half empty b's but now the former is displayed when in fact 4 lots of batteries have been tried . 1 set new;others have worked before and all still do so in partner's small non-SLR which shows all as being well charged. I cannot get any set of AA batteries to turn on the camera which is some 2 1/2 years old. Local repair shops indicate a circuit problem (sight unseen) & shipping off to Pentax UK the only answer. I cannot locate phone No. of Pentax Servicing to seek advise whether similar problems seen by them & likely "fix". Web sites do not indicate similar problems but I hear there have been some problems with this model. Any advice? Pentax Service Dept phone No.? I am only in UK from Australia till Xmas-in East Sussex near Eastbourne. ericstrac@gmail.com
  • discos Jan 15, 2009
    I had the same problem with flashing battery indicator, now after 3 years, the camera is broken : the indicator blinks, but nothing else happens. Many ist ds suffer problems alike (and shutter problems too); my camera is like new but dead, shame on Pentax, my K1000 and MX still do the job !
    There is no solution found for this problem, because fixing is too expensive.
  • kimbelj Feb 16, 2009
    I have had this camera for about 3 years. I've been able to use both disposable AA's and rechargeables without any issues. Over the last 6 months however the battery life has steadily degraded to where it is erratic. With fully charged 2500mah disposables I can only get a few shots before the camera will no longer operate. Disposable AA's will not even power up the display. The autoflash stopped working about a year ago, but I guess that's another problem.
    Problem Solver:
  • 14 Answers
I finally gave up on rechargeable AA batteries entirely with this camera due to the power management problems. Pentax has even issued a disclaimer stating they do not recommend using AAs even though the manual clearly states the camera can use them. I'm now using CRV3s exclusively with no further problems, except the cost - $20-$30 Canadian a pair. Each pair of CRV3s lasts 6 months to a year.
Posted on Mar 19, 2009
Ericstrac@gmail.com-once again-Pentax isd-ds now functioning normally as I substituted rechargeable AA batteries (which did NOT turn camera on even) for disposable batteries. The fact re
chargeable batteries initially worked fine is a slight mystery but from other blogs it seems some types are a problem & it is feasible that if one of 4 batteries is deficient then that coule be an answer-or bateries are nearing the end of their working life perhaps?? Will buy new aa energizer e2 s & use them as spares if they work ok. Great cameras & pleased it is not the camera needing repair! Cheers.
Posted on Jan 17, 2008
I purchased a *ist DS used a couple of weeks ago, and it turns out to have similar problems. This camera seems very fussy about batteries. I am using rechargeable NiMh AAs. After about 30-40 exposures, the camera shows battery depleted. If I turn the camera off, then back on, it will show a charge - sometimes a full charge and will work for another 20 or so exposures. It can keep this up for a couple of days.
I read an explanation in one of the photo blogs (can't remember which) that suggested this was caused by one or two incompletely charged batteries in set of 4. If one is discharged the current from the others supposedly will flow to it, giving fluctuating power readings to the power management curcuit. This sounded plausible enough that I purchased a new charger yesterday which monitors the charge on each battery. Too early to tell whether this solved the problem or not. The other option is to switch to disposable batteries.
Posted on Jan 16, 2008
SOURCE:
Battery indicator reads empty when batteries are fully charged
It looks like your question was cut short... all I see is "Battery indicator reads empty when batteries are..."
With my experience with the Pentax *ist DL, I think the problem is probably that brand new batteries still show "empty" on the indicator.
Chances are that you are not using the CR-V3 camera batteries in your *ist DL. I have tried 2400mAh NiMH rechargable batteries and brand new alkaline batteries in an attempt to save money.
Neither lasted anywhere near as long as the CR-V3 batteries! While you may be paying $15-$20 for two CR-V3 batteries, they last a LONG time!
One of the advantages of DSLRs (and digital cameras in general) is that you save money by no longer buying film and paying for developing/prints. But, even at $20 for two CR-V3 batteries, I save money! I am able to take several hundred photos on a pair of batteries (I think the manual says 500+) instead of $10-$15 ($2-$7 for film + $8 dev/print) for every 24-36 photos!
May 29, 2010 | Pentax *ist DL Digital Camera
My camera indicates that the batteries are low and won't power on. But, when I put new batteries in, it still indicates low battery. What can I do?
Chances are that you are not using CR-V3 camera batteries in your *ist DL. I have tried 2400mAh NiMH rechargable batteries and brand new alkaline batteries in an attempt to save money.
One of the advantages of DSLRs (and digital cameras in general) is that you save money by no longer buying film and paying for developing/prints. But, even at $20 for two CR-V3 batteries, I save money! I am able to take several hundred photos on a pair of batteries (I think the manual says 500 ) instead of $10-$15 ($2-$7 for film $8 dev/print) for every 24-36 photos!
May 09, 2010 | Pentax *ist DL Digital Camera
Power / batteries
This is a common problem...sometimes you have to turn it on a couple of times.
Mar 17, 2010 | Pentax *ist DL Digital Camera
Power on
I have same problem, Im gonna to try put a regular charger,then wi will see
Jun 20, 2008 | Olympus SP-350 Digital Camera
CR-V3 not working
I have read in Forums that FL-50 will not work with RECHARGABLE CR-V3s
Oct 08, 2006 | Olympus FL-50 TTL Flash
Fully charged battery last
Approximate number of recording images and playback times based on Minolta' s standard test condition* are as follows: *test condition: CIPA-compliant. (LCD monitor on, 1600x1200 size images, Normal image quality, Flash used with 50% of the frames) Recording Alkaline batteries : Approx. 80 frames Ni-MH batteries (2100mAh): Approx. 410 frames CR-V3 : Approx. 720 frames Playback Alkaline batteries : Approx. 275 min. Ni-MH batteries (2100mAh): Approx. 340 min. CR-V3 : Approx. 518 min.
Sep 19, 2005 | Konica Minolta DiMAGE E323 Digital Camera
LB-01 CR-V3 lithium Batteries
The Olympus CR-V3 lithium batteries will provide approximately 500 shots with typical usage (half of the images shot with flash/half without flash and minimal use of the LCD monitor). These batteries are not rechargeable.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
LB-01 CR-V3 lithium batteries
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Coolpix 2200/3200 Battery Compatibility
The Coolpix 2200 / 3200 camera is designed to use 2 (two) AA type batteries. Due to Nikon’s advanced power management technology, two standard AA Alkaline batteries can provide more than 100 photographs. For better performance, please consider using Nikon EN-MH1 rechargeable batteries. These are available as an optional accessory at Nikon dealers and at The Nikon Mall Recently a new type of battery, the CR-V3, has been released to the market from several battery venders. The CR-V3 is similar in shape to two connected AA batteries and easily fits in your Coolpix camera compartment. Nikon has confirmed compatibility only with the following battery brands. Please use one of the following brands when using CR-V3 type batteries. Duracell Sanyo Panasonic Due to it’s unique design the Eveready Energizer® brand CR-V3 battery may not be compatible with the Coolpix 2200/3200 camera.
Aug 30, 2005 | Nikon Coolpix 2200 Digital Camera
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Pentax *ist DS Digital Camera Logo
372 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
