I have Direct tv and pused the wrong button on the remote to my Magnavox 20MF605T/17 TV. Now I can't get the picture back. How do I fix? Thanks, Curt
    Problem Solver:
  • 4 Answers
Depending on your TV and receiver there should be a button on the remote that says Format push that button a few times and see if the picture comes back.
Posted on Nov 05, 2008
Service menu codes phillips magnavox
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes
# Press {0} {6} {2} {5} {9} {7} {INFO+} on the remote.
# Press {0} {6} {2} {5} {9} {7} {STATUS} on the remote.
# Press {0} {6} {2} {5} {9} {7} {MENU} on the remote.
# Turn the TV off to exit the Service Menu
* Press {0} {6} {2} {5} {9} {6} {INFO+} on the remote.
* Press {0} {6} {2} {5} {9} {6} {STATUS} on the remote.
* Press {0} {6} {2} {5} {9} {6} {MENU} on the remote.
* Turn the TV off to exit the Service Menu.
* Press {0} {6} {1} {5} {9} {6} {MENU} on the remote.
* Press {0} {6} {1} {5} {9} {7} {MENU} on the remote.
* Turn the TV Off to exit the Service Menu.
* Press {1} {6} {2} {5} {9} {6} {MENU} on the remote.
* Press {1} {6} {2} {5} {9} {6} {STATUS} on the remote.
* With the TV off:
Models 15MF605T/17, 20MF605T/17, 15MF500T/37:
To Factory Mode:
Step 1 : Select the source "PC" and then turn off LCD-TV.
Step 2 : [Push "power " button and then push the "VOL- " and "VOL+" buttons at the same time immediately and hold it] about five seconds then release all buttons.
Press "menu"button and bring up factory mode indication
on Apr 29, 2015 | Magnavox Televison & Video
How to set up my memorex DVD remote to control my magnavox TV?
Sorry to be the bearer of bad news, but according to the manual in the link you posted, and from Google image searching to look closely at the remote, it doesn't appear to be a universal. The only way you can control your TV with it would be via the DVD player hooked into the TV, and then you will still only be able to control the standard functions of the DVD player (i.e. pause/play, stop, FF/Rew, menus, subtitles, etc.) but not the functions of the TV (i.e. volume, channel, power, etc.). Assuming you get yourself a new, actual universal remote to replace this with, I recommend this site in the future:
Sep 11, 2012 | Memorex Televison & Video
Is there an 800 number I can call o get the factory setting for the smart series Philips magnavox tv? It was manufactured in August of 2003.
Try this number- the unit may have a defect in it and may need repair- you don't say what is wrong with it.
Aug 09, 2012 | Philips Remanufactured Magnavox...
I purchased (from a friend who relocated) a Phillips/Magnavox model #9P5511C102 TV with a Magnavox remote control.. I used it for a while and then got Direct TV. Now, I cannot remember my tv code. After...
It sounds like you need a replacement remote. :-)
Unfortunately, from what I've found researching this for you, you can no longer buy the original remote. However, there is a substitute available that should be able to perform most if not all of the functions of the original.
The substitute remote is available for $35 from:
There is a picture of the suggested substitute on the sales site so you can see if it might be what you need. The site says it offers a 1 year money back guarantee, so if it isn't right you can always send it back.
Mar 18, 2011 | Philips Magnavox Learning Universal Remote
Tv has white lines across top of screen. philips magnavox 20MF605T/17
The tv has a vertical problem caused by one to three bad capacitors and possibly the ic, that will exhibit the symptoms you are describing.
Feb 19, 2011 | Philips Televison & Video
Remote control code for Magnavox 15MF605T/17
oif the codes in setup don't work for the direct tv remote, here is a code list at the end of the post
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
Hope this helps you out, good luck.
Nov 27, 2008 | Philips Magnavox Learning Universal Remote
Need manual
does your tv have a round button in the front of the tv push it then see if it turns on.
Nov 09, 2008 | Televison & Video
Remote codes
Contact Direct tv and they should have the codes to program the remote tothat tv. Or contact Universal remote @ 919-573-7854 919-573-7854
Aug 17, 2008 | Philips Magnavox Learning Universal Remote
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
