Question about Kenmore Elite HE4 Electric Dryer
Kenmore elite smartheat quitpak electric dyer
Unit takes three times longer to dry clothes. I felt the units exhaust outside and it is heating, not sure if cotinuously. I have cleaned out the exhaust tube... it is not blocked. No observable error codes. HELP
    Scholar:
  • 157 Answers
Hello talee725. the dryer has heat sensors located throughout. One at the air intake & exchaust of the heating element including the air exchaust of the drum. Disconnect the AC power, close the gas valve is gas powered, clean them and check the sensors with a DVM in the ohm scale for open ckt. They are usely round in shape with 2 wires connected. If test open call a local appliance parts/repair center for price and stock.
Posted on Nov 05, 2008
Yes i have a Kenmore Elite Smartheat quitepak 9 HE4 and its not drying at all. It takes 180min on hight to dry towels
If your dryer is STILL heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, double check your installation, first, to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer in a clogged state, or having improper air flow, will not dry efficiently and will cause the heating circuits to overheat. Eventually, this can lead to component failures and is the source of many fire hazards. If you have any questions, please post back with a complete MODEL NUMBER and let me know. I hope you find this information helpful.
Sep 22, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer is hot when opened, but takes 3 or 4 timed cycles to get clothes dry on very dry setting and timed setting
Check for a restriction in exhaust system,not just behind unit but all the way to outside vent,should feel warm decent airflow at outside vent.If not all you will end up with is warm moist clothes,You need good airflow to take away the moisture in the clothes not just heat.This issue can happen slowly over time and next thing you know its taking two or three times longer to dry even though when you open the door its hot inside.
Good luck
Aug 08, 2010 | Amana Dryers
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he3 takes wat to long to dry cloths
If your dryer is STILL heating, but you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some things to check before you assume there is a malfunction with your dryer:
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will actually take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter than usual in many cases as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back and let me know. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat failure.
Apr 21, 2010 | Kenmore Elite HE4 Electric Dryer
It takes longer to dry your clothes you have to restart the drye
first clean the pip from the unit to the outsde vent.
then inside your unit there are 2 felts that need to be cahnge, over time they go bad and the heat run out the drum and you can feel the hood is hot but it still not to good . it will save you electric bill when you fix it. :)
Dec 31, 2009 | Whirlpool LER4634J Electric Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
try drying load with vent tube disconnected may get warm and dusty but if works ok recheck vent completely also be sure vent is not being flattened when dryer is pushed back to wall also remove lower panel(clips along top edge each corner about 3-4 inches in)remove blower housing 2-3 screws and clean housing
Dec 12, 2008 | Dryers
Kenmore Elite H3 Dryer taking longer than normal to dry clothes
EVEN THOUGH THERE IS WARM AIR COMING OUT THE EXHAUST, IT STILL MAY HAVE A RESTRICTION IN THE DUCT WORK. DISCONNECT THE EXHAUST FROM THE BACK OF THE DRYER FOR ONE LOAD OF LAUNDRY. IF IT DRYS THE CLOTHES O.K., YOU HAVE A RESRICTION SOMEWHERE IN THE EXHAUST.
NOTE: DO NOT USE VINYL OR PLASTIC DUCTING. VINYL IS NOT U.L. APPROVED. PLASTIC PVC WILL ALLOW CONDENSATION TO PUDDLE INSIDE THE PIPE CAUSING A
COMPLETE RESTRICTION.
Mar 30, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4-lots of heat, clothes not drying
Poor drying problems with dryers generally are attributed to clogged ducting. You have probably heard this before, but the first (and least expensive) fix for any dryer with long dry times is to check the air movement. As well know, dryers require good air flow to ensure proper drying. Now, when you said the air movement is strong, were you checking it at the air vent exhaust outside, or were you checking on the back of the dryer? An easy way to tell if there's a clog in the ducting, or a clog in the dryer is to run one load with the dryer vent disconnected from the back of the machine. Only run one load like this. Not a good idea to blow hot moist air into an enclosed area of your home over a period of time because it can cause mildew problems. If the dryer blows freely and your clothes dry faster, you know you need to check the ducting from where it connects to the wall to where it ends at the exhaust vent. Often it is not enough to just clean the lint trap and the outside vent. You need to check what's in between them as well. Mice and birds are notorious for building nests in dryer vents and clogging them up. Now...if the dryer is blowing poorly at the exhaust port on the back of the dryer, you will need to remove the door kick panel under the door and remove the vent duct housing to get to the blower fan. Make sure you unplug the dryer before attempting this. There are live voltages present even with the dryer turned off. Lint can get trapped in vent housing and restrict the movement of the fan, which, in turn, will cause poor air movement and longer dry times. Last of all, take a temperature reading at the exhaust port on the back of the dryer. A good temperature reading is roughly 140 degrees F. If the temperature is too low, you may have an operating thermostat or high limit thermostat malfunctioning. Check your vent ducting, first and let me know if you need further assistance. I hope this helps you.
Aug 04, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
158 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
