Hotpoint WF321 during rinse and spin, will not go into full spin as machine keeps filling with water.
Hi reposting as problem not been solved or answered properly.
The machine should be entering a spin cycle however water continues to enter the drum and drain, the spin will not advance because there is water in the drum still. When no power applied there is no water leaking through the water valve. The pressure switch has been replaced. Why is the machine sending a signal to the water valve solenoid when it should be closed? I understand solenoids are energized open, so where is the voltage coming from to open the water valve at the wrong time?
The water fills the drum, pressure then activates the pressure switch to de-energise the water valve solenoid closing it and stopping water from entering the drum.
If there was a leak in the rubber tube from the drum to pressure switch the drum would overfill.
regards
Scott
Hi, my machine will not complete the rinse & spin cycle, it appears to just keep repeating the cycle every time it should be going into a fast spin.
I have checked & cleaned pump and attaching hoses, tried different loads.
I have found if I disconnect the rubber tube from the pressure switch it spins OK.
I have blown down the tube and all seems clear (there is no resistance). II have also changed the pressure switch.
If left over night the first wash is OK, but after that it just keeps repeating the above cycle.
I have also checked the motor brushes which are fine.
Is there a vibration balance sensor somewhere that could prevent it from spinning?
I have noticed when I blocked the rubber tube to the pressure switch it reaches full spin speed, whereas previously before the above fault started it was not at full speed?
Help, please!
regards
Scott
Comment by scootbog, posted on Oct 27, 2008
Comment by scootbog, posted on Oct 27, 2008Hotpoint WF321 Washing Machine
  • bytor633 Jan 05, 2009
    Same thing is happening here, no idea why but it's REALLY iritating!
This was bugging me too. Even changed triac. All it was, was a worn belt. It was un even!
Posted on Jul 13, 2010
  • 38 Answers
You should check your pressure switch hose for a pin hole or better still just replace the hose and it should sort your problem out good luck hamstel
Posted on Nov 05, 2008
Kenmore he21 washer fill agitates drains but will not spin
Hello;
My name is Peter. I am a retired field service technician.
The model number you gave HE21 comes up as a Maytag hot water tank.
Open the front door of you unit. The model number should be at the top on a tag.
Repost your question with this model number.
Nov 10, 2014 | Washing Machines
Hotpoint wd440 just fills and drains does not move on from wash cycle
it ran for two hours but where did the water go? if it was not cutting off water then u most likely need to replace the water inlet value
Apr 07, 2014 | Washing Machines
Water won't quit filling and agitator does not engage into the cycle.
Did you solve this problem -have one doing the same-feed back -please!
Mar 22, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Hotpoint Electronic 800 WM 12 Aquarius won't rinse
If it won't rinse because it won't fill, it's most probably because the cold water inlet valve is faulty. Many machines will only rinse with cold water....No cold water.....No rinse!! Not a big job.....Nomess
Apr 13, 2010 | Washing Machines
My Hotpoint Ultima keeps displaying an F10 fault and doesnt spin correctly. However, if I then switch it to a rinse and spin cycle it seems to spin OK.
F10 meanswater level pressure switch not sensing correctly, there could be a blockage in the switch hose or chamber, or the switch could be faulty.
Jan 17, 2010 | Hotpoint Ultima WF860 Front Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Hotpoint WMA30 Front Loader Not Pumping Out but still fills if put on rinses, on spin tries but gives up
no easy way to get water out but try putting drain hose down at floor level into a bucket and that may work
fault is probably filter blocked.
to access filter, take rear back panel off. you will see a large diameter hose going from bottom of tub to pump. disconnect this hose at tub end - carefull, water will come out. filter is inside this hose. take it out, clean and reassemble
Oct 02, 2008 | Hotpoint WMA30 Front Load Washer
Washing Machines Logo
845 people viewed this question
Top Washing Machines Experts
