Gps receiver I have a telefunken gps receiver(TGPS-4300BT) that all of a sudden stopped working. When i switch it on i get the loading icon on the screen and nothing else happens. I've tried to reset it but it did'nt help. Could you perhaps assist me on what could be the problem and how to get around it. Thanks Americo Silva americosil@gmail.com
  • krielchris Apr 06, 2009
    I also have a TGPS 4300BT and if i switch it on it only shows me the settings tab along with options etc. But it does not go to the maps or any other features. I have tried resetting the device but nothing works. i also have a 2GIG card without maps. PLEASE HELP?!
    Chris Kriel
SOURCE: hi neeed to user guide for telefunken tgps374
Hi there, I have a user guide for this product. It is only a few pages with no actual technical specs on it just normal care guides and how to use. I have been having issues with mine. It never picks up GPS fast enough, the speaker on the GPS comes on and goes off all the time i get incorrect directions sometimes. Anyone else having these issues? how did you sort it out?
Posted on Aug 12, 2008
  • 78 Answers
SOURCE: Telefunken
These guys come preinstalled with Tele Atlas map, but for some reason I can't find any support for downloads for the maps to Telefunken GPS on their site. Best bet is to contact customer service directly at +31 20 582 94 91 or you can submit your question directly to customer support here.
Posted on Nov 17, 2008
  • 4 Answers
SOURCE: TVGo A03-IPTV ''Fail to initialize hardware''
You can find a solution in the follow link http://download.geniusnet.com/2007/Video/How_to_install_TVGo_A03_MCE_%20under%20WinVista.pdf
Posted on Feb 25, 2009
SOURCE: How to unlock telefunken TV set
I would reccomend the following: Press and hold in the "display" button on the remote for about 5 seconds.
This worked for me
Thank you, Regards
Posted on Nov 18, 2009
SOURCE: Casablanca fan stopped working suddenly, both fan & light
You must 'reset' the remote. I've had it happen quite a few times.
1. Turn off power to fan. Then back on.
2. Using remote cycle the following fan buttons from high to med to low, then from low to med to high again. That 'should' fix the problem.
Posted on Dec 30, 2009
MY GARMIN NUVI 650 NA SUDDENLY STOPPED WORKING. WHEN I TOUCH THE SCREEN NOTHING HAPPENS... (THIS MACHINE HAD BEEN WORKING SINCE 2007). PLEASE HELP
Is it charged? If you are using the cigarette lighter adapter plug, there is a fuse in the silver tip of plug...... unscrew it carefully..its spring loaded... check fuse
Oct 27, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin starts loading maps, then screen goes blank
First do the master reset -Hold down finger in lower right corner of screen and press switch on button. Hold still until asking of erasing all private data appears. FAST click on YES.
If it doesnt work:
From www.garmin.com -cllick on SUPPORT -> SOFTWARE
Get webupdater and install it. Run it and you'll find button "Find device". Of course you can't because it does restart all the time.
Hold down finger in UPPER LEFT corner of screen and press switch on button. Hold still for about 10 seconds (GARMIN appears and nothing more) and fast connect the USB.
HOLD switch until icon of connected computer appears on the screen. After then device stops resetting.
Webupdater can find your device, and now you can put a new firmware by doing step by step instructions from webupdater.
wildadam
Jun 19, 2010 | Garmin nuvi 1350 Car GPS Receiver
Garmin 1200 suddenly stopped loading up....
I am haveing the same problem
poky345@yahoo.com
Can not seem to find any reason?
Mar 31, 2010 | Garmin nuvi 1200 Car GPS Receiver
My garmin nuvi 255w stopped giving vocal instructions. It works other than that. Thanks!
just looking at mine, you turn it on... after it has loaded maps etc you will see a screen with a wrench and a speaker in the lower right corner. touch the speaker icon.... make sure the volume is turned up in the next screen and that it is not muted.
Mar 01, 2010 | Garmin nuvi 255W GPS Receiver
Unit screen says loading,stays on that
if this just happened all of a sudden and you havent tried to update it or anything (the update sometimes causes this) look on the left side of the gps under the flap, there will be a switch to reset your 2200t, but depending on when it was made,(early 2200t or late model 2200t) it will either have a two position slide switch or a switch you depress....
with the gps on, depress the switch and let it restart. if it is the slide switch, move it to the opposite possition then back again to restart it...if it doesnt start, use the power button to restart it.
let me know how you make out and if it doesnt work, i can tell you what to do next.
bill
ALL That is necessary for the Triumph Of evil is That good men do nothing.
Dec 09, 2009 | Magellan RoadMate 2200T GPS Receiver
My Bluetooth interation suddenly stopped working
Many problems related to pairing can be corrected by verifying that the latest firmware is loaded to the GPS unit and the phone. To update the firmware on the GPS, please use the WebUpdater program. To make sure the phone has the latest firmware updates, please contact the phone service provider for more information.
One additional tip is to always pair the phone with the GPS from the phone itself. Do not attempt to pair to the phone from the GPS unit.
Oct 07, 2008 | Garmin Nuvi 660 GPS Receiver
Telefunken
May 29, 2008 | Tomtom One Europe v2 GPS Receiver
Hi neeed to user guide for telefunken tgps374
Mar 13, 2008 | Tomtom One Europe v2 GPS Receiver
Nextar c3 gps unit
Try tapping the lower right corner of your screen and see if this will solve the problem! If this doesn't work, i can't help!
Nov 11, 2007 | Nextar P7 GPS Receiver
76 people viewed this question
 Grubhead
Grubhead
