Question about RCA HD52W59 HDTV Projection Television
Capacitors The three capacitors to replace. CP 150, CP111, & CP 114 were do you find them? First my TV would just turn off and then back on. Now it is turning off and staying off after the 3 green light blinks. So I figure on replaces the flyback and the 3 capacitor.
  • ShawnRagus Nov 11, 2008
    What I meant was. Where can you buy the replacement capacitors? I've seen were it was said servicemanuals.vstore.ca for the flyback. And I've found 2 of the three capacitors CP150 and CP 114. But nothing of CP111.
  • ShawnRagus Nov 12, 2008
    No I don't think they were bubbled. Just with the TV at first turning off and then turning back on. And now finally it turned off and the green light flashed the 3 times and TV stayed off. I thought I would replace all while I was in there. The link above keeps changing to a different link "searchfusion.com"
    Sergeant:
    Champion:
  • 346 Answers
You can get these capacitors at radio shack (source)
Posted on Nov 13, 2008
  • RCA Master
  • 5,138 Answers
Sorry i am very sick with the Flu But the 3 caps you are looking for are on the deflection board which has the flyback on it Also all 3 caps will be green with gold writing cp 150 is 2200uf 16v use 25v the other 2 caps are neer by this one.
Posted on Nov 05, 2008
  • ladywinn
    ladywinn Nov 11, 2008
    Was cp150 bubbled up on top?2200uf 16v green with gold writing other 2 caps will be 220uf 35v, one may or not be 330uf 35v if not it will be same value as other 220uf 35v / You can also order rebuilt deflection board for 179.00 www.UED.com they have a list of boards that are in stock
  • ladywinn
    ladywinn Nov 18, 2008
    Have you check the second ribbon connector on deflection board For what ever the reason i have pulled ribbon connector up ,then make sure it is plug in good, Then tv went back to working. try this.
Tv wont turn on most of the time it will try three times then you have to wait a minute to try again
On yor Deflection board CK capacitors cp114 cp120 220uf 35v and cp150 1000uf 16v if cp 150 is swollen or puffed up on top replace all 3 caps Deflection board is the bottom board on left hand side with FBT flyback transfomer
Aug 12, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Replaced cp150 @cp114 plus flyback. tv runs great but not full screen.
Hi
Thanks for using FixYa. On the Deflection board there are 3 capacitors CP 114, 120 and 150. If you have already replaced two of them then replace CP 120: 330UF/35V/HF and post back if that makes any difference.
Thanks Rylee
Jun 05, 2010 | RCA D52W19 52" Rear Projection Television
The tv will not power up. Blinks three times and shuts down. TL010 shorted ,replaced but still has problem.
Hi
Thanks for using FixYa. On the Deflection board there are 3 capacitors CP 114, 120 and 150. If any of them is puffed up on top replace all the 3 capacitors CP150 2200UF 16 other 2 are 220UF 35v they will be green with gold writing on them. Resolder all pins on Fly Back Transformer (FBT) also. FBT could be in the power supply. Check the SMPS and in any event replace CP 120: 330UF/35V/HF & CP 150: 2200UF/16V/HF (May be bulged or vented)
Always Resolder Cl031 & Cl032 (usually looks ok on visual inspection but common to ring crack).
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 06, 2010 | RCA D52W136D 52 in. TV/DVD Combo
Rca model hd56w66 turned off and the power light will only come on for a few seconds tv will not completely turn on
3 capacitors on your deflection board it will be bottom board on left hand sise of TV cp 150 2200uf 16v use 25v if it is puffed up on top it is Bad other 2 are cp114 cp120 220uf 35v in same circuit. For capacitors Call Mats 1-800-628-1118
Dec 15, 2009 | RCA HD56W66 56" HDTV
Have a hard time turning on my TV, have a RCA big
there are caps in the smps board that require replacment cp 150 cp 120 cp114 and check solder connections at clo32
Oct 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv light turns on and off ,TV never actually comes on.
CK capacitor cp114,120,150 if ant of these caps are puffed up on top it is bad so replace all 3 capacitors cp 150 is 2200uf 16v other two are 220uf 35v
Feb 15, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca tv
ck cp 150 2200uf 16v cp 111 220uf 35v and cp 114 220 or 330uf 35v replace all 3 capacitors
Nov 26, 2008 | RCA D52W19 52" Rear Projection Television
3 green blinks
Look on Deflection board cp 150 2200uf 16v capacitor and there is 2 more capacitors 220uf 35v replace both of them. Green and Gold writing on caps.
Sep 09, 2008 | RCA D52W19 52" Rear Projection Television
D52W20 52 IN RCA
You need a new flyback. You can get one at the following link with free instant messageing online with a tech to take you through the replacement step by step. You need flyback 259296 here is the link
http://servicemanuals.vstore.ca/
Jul 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power button flashes 3 times but not turn on i here a sound in the back of the tv but tv will not come on was wondering if there are any easy checks or what might be a common problem for this and HOW DO I...
If you take off the back cover, cp 150 is located on the left circuit board. There are 3 or 4 C-shaped metal heat sinks in the board, and capacitor cp-150 is located inside the furthest one. Once you find cp 150 check the top of it to see if it is still flat, as opposed to puffed up. If it is puffed up I am almost certain this is you problem.
My tv would flash green 3 times and turn off for 45 seconds. It was taking up to 20 minutes to finally turn it on, so I bought a pack of 5 capacitors off of ebay to replace capacitor cp 150, which is just a (2200uF,16V) capacitor. I replaced it 10 minutes ago, and the tv turned right on. Fix Ya!
Jan 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 HDTV Projection Television Logo
271 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
