Question about Canon Office Equipment & Supplies
I am installing the PIXMA MX7600; I installed all of the ink cartridges correctly; the lights lit up; I installed the clear cartridge then received and error B300 the ink cartridge is not recognized
  • 318 Answers
I have many of these faulty cartridges.On the cartridge there is a chip that is damadge.Take the cartridges back from the place you bought it to exchange with new one.
Please rate me!
Posted on Nov 06, 2008
Error E and 5
Number following "E"
Cause
How to correct
No paper. /
Paper does not feed.
If paper is not installed, load it and then press the <Black> or <Color> button. When paper is installed, check each of the following items and try printing again.
1. Confirm only recommended paper is installed.
2. Confirm paper is installed properly.
3. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
4. Clean the paper feed roller to resolve the error.
Paper jam
Remove the jammed paper.
If paper jams frequently occur, check the following:
1. Confirm there is no foreign material inside the machine.
2. Confirm only recommended paper is installed.
3. Confirm paper is installed properly.
4. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
Empty ink tank
An ink cartridge is empty.
To cancel printing, press the <Stop/Reset> button.
To continue printing, press <Black> or <Color> button.
After printing completes, replace the empty ink cartridge.
Printing with an empty ink cartridge may cause the machine to malfunction.
5
The ink cartridge(s) is not installed. / The ink cartridge(s) cannot be recognized.
The ink cartridge may not be installed properly, or an unsupported ink cartridge may be installed.
Install a recommended ink cartridge.
Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing.
If one of the ink cartridges is missing, this error can occur.
7
The ink cartridge is not installed in the appropriate position.
The ink cartridge is not installed in the proper position.
Install each ink cartridge in the proper position.
8
The waste ink absorber is almost full.
The waste ink absorber is getting full.
Press the <Black> or <Color> button to clear the error and continue printing.
Printing can continue until the waste ink absorber becomes full. If the waste ink absorber becomes full, the machine will require service.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
9
A specified period of time has elapsed without receiving a response from the digital camera. / A print mode compliant with PictBridge is not selected. / A specified period of time has elapsed without receiving a response from the digital camera.
The machine cannot communicate with the connected camera.
Disconnect the cable between the machine and the camera to clear the error.
Check the following items, then try printing again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the machine cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge.
Please refer to the camera instructions for more information about procedures required before and after connection to the machine.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the machine.
1 , 4
1 , 5
The ink cartridge cannot be recognized.
An unsupported ink cartridge may be installed.
Install only recommended ink cartridges.
1, 6
The ink level cannot be correctly detected.
A used ink cartridge may be installed, or the ink cartridge is empty.
Replace the ink cartridge.
Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
1 , 9
Scanning failed.
Scanning a document failed.
Check if the document is placed in the correct orientation / position and try the operation again.
2 , x
3 , x
4 , x
(Where x represents a number)
Turn the machine off, and remove the power cord from the electrical outlet.
Wait approximately ten minutes then plug in the power cord and turn the machine on.
If the problem is not resolved, the machine may require service.
Feb 18, 2012 | Canon PIXMA MP150 All-In-One InkJet...
7 orange light flashes and 1 green light flashes
This means that the ink cartridges have not been installed correctly.
Make sure that the black ink cartridge is installed in the left socket and the colored is in the right socket.
Make sure that you hear the click sound confirming that the cartridge has been placed correctly.
Sep 18, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
CANON PIXMA MX 328 EROR U051
Ink cartridge not installed, or not properly installed. Install the ink cartridge properly. If the error is not cleared, the ink cartridge may be defective. Replace the ink cartridge.
Aug 07, 2011 | Office Equipment & Supplies
What is error e5 in mp 198 printer
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly..
  • In certain models of Canon Pixma printers such as the Canon MP160 and Canon MP150, you may receive an E5 error when trying to print. In this state, you will not be able to use any of the functions of your printer. The error itself is an ink cartridge error. It may be that you are using generic or off-brand ink cartridges in your Canon Pixma printer. Canon Pixma printers do not work with other brands of print cartridges; invest in Canon brand ink cartridges and this should take care of your problem.
  • Nov 18, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
    How to change the ink on my Canon MX7600 printer
    Turn the printer on.
    Lift the printer cover until it locks in place.
    The empty cartridge will be flashing.
    Remove the cartridge by pushing the front clip and lifting it out of the carrier.
    Remove the wrapping from the new cartridge and the orange protective cap from the cartridge
    Insert the cartridge and press it down until it snaps in place.
    Close the cover.
    Run the nozzle cleaning utility and the alignment utility.
    If you need a manual you can download the manual from
    http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=16506
    Please rate this solution. Thanks.
    Dec 17, 2009 | Canon PIXMA MX7600 Multifunction inkjet
    Colour printing suddenly dominated by red/pink hue. All ink tanks in order
    It sounds like you are using aftermarket or refilled cartridges. To clear the sensors and nozzle, install new OEM cartridges, run deep cleaning a number of times (at least 3 times), and then the alignment utility.
    Aftermarket/refilled cartridges do not always meet the manufacturer's specifications for quality. Try cartridges from LDproducts.com for your printer. I've never had a problem with their aftermarket cartridges.
    Dec 13, 2009 | Canon PIXMA MX7600 Multifunction inkjet
    E16 error message for for canon pixma 210
    E16 must be "Ink remaining unknown".Press and hold the "resume" button for 5 seconds.
    Oct 15, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
    How to fix problem E16 in my printer canon mp160
    E16 – The ink level cannot be correctly recognized or detected.
    How to correct, fix: A used ink cartridge may be installed, or the ink cartridge is empty. Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
    Sep 03, 2009 | Canon PIXMA MP160 All-In-One InkJet...
    Canon mp160 error
    E5 means one of three things.
    1. The ink cartridges are not installed
    2. The ink cartridges installed are not compatible
    3. The ink cartridges are not installed correctly.
    Are you using genuine Canon or a copy cartridge? If copy then they may not be correct. If they are genuine Canon you may need a new printhead.
    Nov 14, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    Mp140 e2
    E3 – Paper jam error.
    How to correct, fix: Remove the jammed paper. If paper jams frequently occur, check the following:
    E4 – Empty ink tank.
    How to correct, fix: An ink cartridge is empty. To cancel printing, press the <Stop/Reset> button. To continue printing, press <Black> or <Color> button. After printing completes, replace the empty ink cartridge. Printing with an empty ink cartridge may cause the machine to malfunction.
    E5 – The ink cartridge(s) is not installed. The ink cartridge(s) cannot be recognized.
    How to correct, fix: Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing. If one of the ink cartridges is missing, this error can occur.
    E7 – The ink cartridge is not installed in the appropriate position.
    How to correct, fix: The ink cartridge is not installed in the proper position. Install each ink cartridge in the proper position.
    E8 – The ink wasteabsorber is almost full.
    How to correct, fix: The waste ink absorber is getting full. Press the <Black> or <Color> button to clear the error and continue printing. Printing can continue until the waste ink absorber becomes full. If the waste ink absorber becomes full, the machine will require service. The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
    E9 – A specified period of time has elapsed without receiving a response from the digital camera. A print mode compliant with PictBridge is not selected. A specified period of time has elapsed without receiving a response from the digital camera.
    How to correct, fix: The machine cannot communicate with the connected camera. Disconnect the cable between the machine and the camera to clear the error. Check the following items, then try printing again.
    1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct. If the camera does not support either one, the machine cannot print directly from the camera.
    2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge. Please refer to the camera instructions for more information about procedures required before and after connection to the machine.
    3. There may have been no response from the camera for the prescribed time. Re-connect the cable between the camera and the machine.
    E14 – Ink cartridge cannot be recognized.
    How to correct, fix: Unsupported ink cartridge may be installed.
    E15 – Install only recommended ink cartridges.
    How to correct, fix: Install only recommended ink cartridges.
    E19 – Scanning failed error.
    How to correct, fix: Scanning a document failed. Check if the document is placed in the correct orientation position and try the operation again.
    Aug 01, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
    121 people viewed this question
    old marine
    old marine
