Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Kp-51ws510 sony tv.?
Replaced ic's (stk392-560) But keep blowing 5 amp pico fuse (only one fues of too on g board of power supply) and am trying to find if there is a resistor that needs to be replaced.?
would you know how to check the resistor to replace them and if that is my problem from blowing these fuse's?
Also do i have to take out the resistor (UN solider) to check if they are bad. or out of circuit. Have 16 resistor to match each ic pin. since the 2 ic.s have 18 legs each would be 32 resistor's..
if you could help that would be awesome thanks jason moore
tmoore15@indy.rr.com
  • 10,594 Answers
Let me know circuit code of blown fuses on G Board. It would be like... PS8001, PS8003 etc.
This info will help me to sort out problem in your TV's G Board.
Posted on Nov 05, 2008
Kd-46wt500 sony big screen colors dont line up is projectors goin out picture on tv is blurry pic looks stretched out as well
Can you verify the model number and see if its A KP46WT500 model? If so chances are just the convergence Ics ( stk 392-560 ) and pico fuses are the problem. There are 6 3.5 amp pico fuses directly beneath the heat sink fins on the D board ( where the Convergence ICs are located) Check those six pico fuses and also two 5 amp picos on the G board ( where power cord plugs in) if any of the picos on either board are open then the Convergence ICs will require replacement.
Sep 26, 2011 | Sony KP-46WT500 46" Rear Projection...
I have a sony widescreen projection tv model KP51WS510. the picture has shadows and shows double.
Thats caused by failed convergence ICs your model uses the STK392-560 ICs you will also need several 3.5 amp pico fuses and a couple of 5 amp pico fuses to do the repair. The Sony Type 1 convergence repair kit is the correct kit for your model. It contains the parts and the CD with repair instructions. The kits available from www.tvrepairworld.com
Aug 09, 2011 | Sony KP-51WS510 51" Rear Projection...
I have a sony kp-51ws510 projection tv, i replaced the convergence ic's and a pico fuse and then reset the convergence. The tv looks good except for a green shadow on lettering, also on the convergence...
Did you check the two pico fuses on the G board? Usually at least one will blow when the original ICs failed. I am attaching a pic that shows the 2 pico fuses on the G board.
Jul 08, 2011 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51 in. Rear Projection Keeps blinking 5 times. The red and green projectors are working fine, but the blue is not working. Sears service replaced the power supply, and the first board, then...
You may want to recheck your connections coming off the blue tube to the board. Also check the IC links/Pico fuses on the power board. I have a repair manual for this Tv if you need it. shanesebay304@yahoo.com
Dec 10, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 the picture is blurry, except for the center of the picture and the picture looks concaved. Sometimes it looks as if the picture is in 3D. Is this worth fixing?
You have a convergence problem very typical of rear projection tv's. This set has (2) STK392-560 IC's and there may also be a resistor or two that needs to be replaced.
<br>
<br>
I have found that on this set you need to check the pico fuses on the power supply board (there are two located parallel to each other) and on the convergence board (underneath the aluminum heat sink where the IC's are mounted).
Nov 29, 2009 | Sony KP-51WS510 51" Rear Projection...
KP-51WS510 convergence problem. Replaced IC's and pico fuse
Nothing else to look for but to Replace the Convergence Ic's
Nov 06, 2009 | Sony KP-51WS510 51" Rear Projection...
Convergence parts? What are the specific pico fuses and resistors
There are six 3.15 amp picos use 3.5 amp when replacing and there are two 5 amp picos on the G board the resistors if needed are 4.7 ohm 1/2watt
Sep 06, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP 51WS510 convergence problem
Please check pico fuses in D board and confirm +22 & -22 volt supply to convergence ICs.
Fuse numbers are as follows...
PS8001, PS8002, PS8003, PS8004, PS8005, PS8006
Dec 21, 2008 | Sony KP-51WS510 51" Rear Projection...
Tv screen problem
you have one bad ic or a blown pico fues or maybe both.!!! (On your g board)
replace all and make new..
jason tmoore15@indy.rr.com
Oct 13, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
130 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
