Question about Dolphin 9551 Handheld Barcode Scanner
Store and upload transactions
Currently we are using scanners and would like to be able to work in our SAP system offline in the event of server downtime. Is there capability in the handheld to perform transactions offline and upload with the server is back up and running?
Thanks,
Allycen Brady
allycen.m.brady@accenture.com
Iterra elite II printer showing fatal error 131 code error
Error Code: -131, ErrorMessage: Connection to license server failed; if license server address is invalid, correct it; if TAO NT naming service stopped, activate it and restart License Manager
I was sure that all SAP B1, and MS SQL services are up, and running on the server side so I knew this is an issue related to the client side.
The solution was checking the file "b1-local-machine" which is located it under "C:\program files\SAP\SAP Business One DI API\Conf"
The value of the server ip was "localhost", and it should be the ip of my production server instead.
Hope that was helpful.
for more hrlp visit CBR Tech Solutions
Feb 04, 2014 | Elite Office Equipment & Supplies
My finger print is unable to obtain authentication or input/output error has occurred am using it to register student for jamb exam
Ade, if u r using your scanner on jamb website. You will need a
- You to provide 16 characters security key. - biometric license and - JAMB Biometrics Capture/uploader software.
* The biometric license gives you authentication while the JAMB Biometrics Capture software allows you to capture thumb-print even when there is no internet connection(offline) and automatically upload them to server when the internet is back.
You can thumb-print as many student as you can (I have seen a client who thumb-printed as many as 2000 in 3days).
We give technical advise and we have several license in stock to give away. While not call us today, if the problem is still persisting. Call 08132829820 or email us on biometricmasters2000-jamb@yahoo.com
Feb 18, 2011 | DigitalPersona U.are.U 4000 Fingerprint...
Digital persona is not supporting vista, kindly give solution for the same
Markata, Your operation system (Vista) is supported but it must be 32bit version if u r using your scanner on jamb website. You will need a - You to provide 16 characters security key. - biometric license and - JAMB Biometrics Capture/uploader software. - Your operating System software must be 32bit(XP, Vista, Win7)
* The biometric license gives you authentication while the JAMB Biometrics Capturesoftware allows you to capture thumb-print even when there is no internet connection(offline) and automatically upload them to server when the internet is back.
Feb 03, 2011 | DigitalPersona U.are.U 4000 Fingerprint...
I am trying to register my finger from digital persona but its giving an error report: unable to obtain authentication input/output error has occured.
Dear Big, if u r using your scanner on jamb website. You will need a - You to provide 16 characters security key. - biometric license and - JAMB Biometrics Capture/uploader software. - Your operating System software must be 32bit(XP, Vistat, Win7)
Jan 30, 2011 | DigitalPersona U.are.U 4000 Fingerprint...
Unable to obtain aunthentication input/out error has occured. module is not register.
Dear Mark, if u r using your scanner on jamb website. You will need a - You to provide 16 characters security key. - biometric license and - JAMB Biometrics Capture/uploader software. - Your operating System software must be 32bit(XP, Vistat, Win7)
Dec 16, 2010 | DigitalPersona U.are.U 4000 Fingerprint...
Step by step guide to installing sap on windows 2003
hi dear
SAP4.7 Installation On Server 2003 SAP 4.7 INSTALLATION GUIDE 1. CREATE C PARTITION 6GB AND D PARTITION 70GB. INSTALL O.S SERVER. SET SYSTEM YEAR TO 2010 OR 2. CREATE LOOPBACK ADAPTER. START→ SETTINGS→ CONTROL PANEL ADD OR REMOVE HARDWARE→ NEXT→ NEXT→ SELECT ADD ANEW DEVICE NEXT SELECT WANT TO SELECT THE HARDWARESELECT NETWORK ADAPTER SELECT MICROSOFT NEXT NEXT FINISH. 3. CREATE IP ADDRESS MY NETWORK PLACES LOCAL AREA CONNECTION RIGHT CLICK PROPERTIES SELECT INTERNET PROTOCOL (TCP/IP)ADDRESS CLICK ON PROPERTIES AND IN IP ADDRESS 200.200.200. 20 AND OK OK 4. VIRTUAL MEMORY MYCOMPUTER RIGHT CLICK PROPERTIES ADVANCED TAB CHANGE SELECT D DRIVE INITIAL SIZE 2000 MAXIMUM SIZE 2000 CLICK SETOK OK OK 5. COPY ALL THREE DVD IN D DRIVE. SEE THAT D DRIVEMUST HAVE ATLEAST 54-55 GB FREE SPACE. 6. JAVA 1.4 INSTALL [FROM DVD 1] JAVA 1.4 DOUBLE CLICK NEXT I ACCEPT NEXT NEXT NEXT FINISH. JAVA PATH MY COMPUTER RIGHT CLICK PROLPERTIES ADVANCED ENVIORNMENT VARIABLE [SYSTEMVARIABLES ] SELECT NEW VARIABLE NAME JAVA_HOME VARIABLE VALUE ----------- START RUN BROWSE SELECT DRIVE PROGRAM FILES ANDPASTE IN VARIABLE VALUE BOX {Enter Path of JAVA) OK OK OK . 7. ORACLE 8I INSTALL [FROM DVD 3 ] ORACLE 4 NT I386 SETUP ORACLE 8I NEXT NEXT NEXTGLOBAL DATABASE NAME ORA NEXT INSTALL FINISH [ OREXIT] 8. INSTALLATION . [FROM DVD 3] KER NT I386 NTPATCH R3 DLLN DOUBLE CLICK ON THIS PRESS OK. KER SAPINST NT SETUP. SAP 4.7 INSTALLATION SELECT THIS AND PRESS NEXT NEXT SYSTEM ID ----- GIVE ANY DIGIT ALPHABETS [EX: SAI] NEXT SELECT CENTRAL INTANCE NEXT NEXT SELECT LOCAL INSTALLATION NEXT NEXT SELECT C DRIVE NEXT ------- GIVE PASSWORD AS 123 IT WILL ASK TWO TIMES THATPASSWORD NEXT 9. AFTER INSTALLATION OF ABOVE STEP GO TO : \ RIGHT CLICK ON USR SHARING & SECURITY SHARETHE FOLDER IN SECURITY TAB TICK ALL ALLOW. GO TO PROGRAMS SAP INST ORACLE KERNEL CLICK ONPREPARE NEW INSTALLATION. THEN AGAIN GO TO PROGRAMS SAP INST ORACLE KERNEL CLICK ON SAPINST SERVE WITH GUI. AGAIN FOLLOWS THE STEP IN STEP 8 WITH THE FOLLOWINGCHANGES. SELECT DATABASE INSTANCE INSTEAD OF CENTRAL INSTANCE SELECT LOCAL INSTALLATION NEXT NEXT SELECT D DRIVE D DRIVE} FOR BOTH OPTIONS NEXT NEXT IN PACKAGE LOCATION GIVE THE ADDRESS OF DB1-----ETC. DB1 EXPORT 1 LABEL.ASC DB2 EXPORT 2 LABEL.ASC DB3 EXPORT 3 LABEL.ASC EXPORT 4 LABEL.ASC EXPORT 5 LABEL.ASC EXPORT 6 LABEL.ASC EXPORT 7 LABEL.ASC NEXT NEXT. SELECT THE OPTION NO MNLS REQUIRED AFTER THIS IT WILL TAKE 15 HRS FOR INSTALLATION. ITWILL SHOW SUCCESSFULLY INSTALLED. 10. GO TO GUI GUI WINDOWS WIN32 SETUP. ã NEXT NEXT SELECT ALL NEXT INSTALL. 11. AFTER THAT CLICK ON SAP LOGON IN THAT CLICK ONNEW ITEMS DESCRIPTION ANY NAME APPLICATION SERVER TO KNOW THISOPEN SAP MANAGEMENT CONSOLE, IN THAT CHECK THE NAME ABOVEPROCESS LIST AND FILL WITH THAT NAME. SYSTEM NUMBER 00 12. CLICK ON LOGON USER ID DDIC PASSWORD 19920706. THEN GO TO SU01 TRANSACTION. GIVE THE USER SAPUSER (this is the user name to logon to sap) THEN PRESS F8. GIVE ANY NAME IN LAST NAME INITIAL PASSWORD REPEAT PASSWORD. THEN CLICK THE TAB PROFILES GIVE SAP _ALL SAP_ NEW & THEN PRESS ENTER & SEE IT WILL ASK THE PASSWORD , THIS IS THE PASSWORD TOLOGON TO SAP, GIVE ANY PASSWORD AND LOG OFF. 13. AGAIN LOGIN TO SAP NEW ID & PASSWORD AND THEN GOTO SE38 AND CREATE A PROGRAM STARTING WITH LETTER IT WILL ASK FORACCESS KEY. IN THAT TYPE 366 87 66 322126 127 8 694. Thank you
Imrna
Pls rank me as possible have nice day
Apr 20, 2009 | Microsoft Windows Server Standard 2003 for...
Unix
Improving UNIX server performance NOTES.INI settings Most NOTES.INI settings that affect IBM® Lotus® Domino® server performance apply to all UNIX® platforms.
NSF_Buffer_Pool_Size_MB Many machines that run UNIX have very large amounts of physical RAM. Use the parameters NSF_Buffer_Pool_Size_MB or PercentSysAvailable Resources to control how much memory Domino is allowed to use. Each Domino instance on a UNIX machine can reference a maximum of 4GB of RAM.
Disk and memory requirements When a UNIX system runs Domino server software, the server must have enough disk space for program and data files and enough memory to handle swapping and the number of processes. You can also change several system parameters to improve server performance.
Disk I/O tuning Maintaining multiple file systems for operating system files, swap space, transaction logs, and data improves overall server performance.
Use RAID 0+1 hardware for the disk drives on which the data files reside. Use multiple smaller disk drives instead of a few large disk drives for Domino data. Domino does not perform simple predictable sequential reads; therefore, disable Read Ahead Cache and enable Write Cache.
Keeping swap space on its own separate striped volumes improves server performance at high loads. The transaction logs should always be on the most reliable and highest performing disk subsystem available to the system hosting the Domino server. Transaction logging must be on its own disk drives for improved server restart time, reliability, and availability. The logged transactions are written to disk as fast serial writes to a sequential file that is of configurable size in 4K blocks.
Console and database logging To improve server performance, limit the amount of information that is logged to the log file (LOG.NSF) and the console.
Feb 21, 2009 | Computers & Internet
Vista driver for 1200S scanner
Install on Vista and Windows 7 using driver files from a XP installation. Copy the following driver files from XP: umax.inf, layout.inf, sti.inf, scsiscan.sys, sti.dll, umaxscan.dll, umaxud32.dll, umax.pnf (this may be more files than you need, but it works). Edit the umax.inf file to remove all by the 1200s/SCSI related sections (or copy it from below). Perform a manual installation of the 1200s and select the umax.inf installation file that you copied and edited. This worked perfectly. My Umax 1200s is recognized and works great in Windows 7.
Umax.inf:
; UMAX.INF -- Windows Still Image Setup File
; Copyright (c) 2000 Microsoft Corporation
; Manufacturer: UMAX DATA SYSTEMS INC.
[Version]
LayoutFile=Layout.inf
Signature="$CHICAGO$"
Class=Image
ClassGUID={6bdd1fc6-810f-11d0-bec7-08002be2092f}
Provider=%Msft%
DriverVer=07/01/2001,5.1.2600.0
[ControlFlags]
ExcludeFromSelect=*
[DestinationDirs]
DefaultDestDir=11 ; LDID_SYS
[Manufacturer]
%Mfg%=Models
[Models]
;no button will be supported on inbox UMAX driver.
%SCSI\UMAX____ASTRA_1200S_____V.DeviceDesc% = SCSI.Scanner, UMAX____ASTRA_1200S_____V
; Device section
; All SCSI scanner (600S, 610S, 1200S, 1220S, 2400S, 2200-SCSI)
[SCSI.Scanner]
Include=sti.inf
Needs=STI.SCSISection
SubClass=StillImage
DeviceType=1
Capabilities=0x30
DeviceData=Scanner.DeviceData
AddReg=Scanner.AddReg, SCSI.Scanner.AddReg
CopyFiles=Scanner.DriverFiles,Scsi.Scanner.CopySys32Files
DelFiles=SCSI.Scanner.DelSysFiles
ICMProfiles="sRGB Color Space Profile.icm"
UninstallSection=SCSI.Scanner.Uninstall
[Device.Events]
; These are events that this device supports - uncomment the events
; supported by this scanner and provide a description for the
; event and the name of the application to launch. The name of the
; application is the name which the application uses to register itself
; with the STI.
Event1=%EVENT_1%,{2DA39CE1-4F33-11d3-9859-00104BF5E7FA},%APP_TO_LAUNCH_1%
Event2=%EVENT_2%,{2DA39CE2-4F33-11d3-9859-00104BF5E7FA},%APP_TO_LAUNCH_2%
Event3=%EVENT_3%,{2DA39CE3-4F33-11d3-9859-00104BF5E7FA},%APP_TO_LAUNCH_3%
; Services (no meaning on Win9x)
[SCSI.Scanner.Services]
Include= sti.inf
Needs= STI.SCSISection.Services
; DeviceData
[Scanner.DeviceData]
TwainDS="WIA-UMAX TWAIN DS"
Server=local
UI DLL=sti.dll
UI Class ID={4DB1AD10-3391-11D2-9A33-00C04FA36145}
[Device.DeviceData]
Server=local
UI DLL=sti.dll
; Flags which indicate which events should be recognized by the minidriver
; To recognize an event set the value of its mask to 1 to turn off an
; event set its eventmask to 0.
EventMask1=0
EventMask2=0
EventMask3=0
; The time interval between two subsequent activations of the event
; button on the scanner - If the time between activations is less than this
; then the event will be ignored. This value has to be specfied in milliseconds
; it must be larger than half a second and not more than 10 seconds.
DebounceTime=5000
; Enable polling for buttons event if 1
POLLING=0
; Enable Set Remote Wakeup (for LM9832/3, or LM9831 with updated EEPROM)
REMOTEWAKEUP=0
; AddReg
[Scanner.AddReg]
HKR,,HardwareConfig,1,2
[SCSI.Scanner.AddReg]
HKR,,USDClass,,"{92bf9f20-ca15-11d0-8350-bc0a6bbd28e3}"
HKCR,CLSID\{92bf9f20-ca15-11d0-8350-bc0a6bbd28e3},,,"UMAX WIA"
HKCR,CLSID\{92bf9f20-ca15-11d0-8350-bc0a6bbd28e3}\InProcServer32,,,%11%\umaxscan.dll
HKCR,CLSID\{92bf9f20-ca15-11d0-8350-bc0a6bbd28e3}\InProcServer32,ThreadingModel,,"Both"
; Copy files
[Scanner.DriverFiles]
umaxscan.dll
umaxud32.dll
[SCSI.Scanner.CopySys32Files]
;scsiscan.sys
;scsimap.sys
[SCSI.Scanner.DelSysFiles]
[SCSI.Scanner.Uninstall]
Jan 12, 2009 | Umax Astra 1200S Flatbed Scanner
Dolphin 9551 Handheld Barcode Scanner Logo
116 people viewed this question
Top Dolphin Computers & Internet Experts
matt
matt
Southpaw Jim
Lee Parker
Lee Parker
Are you a Dolphin Computer and Internet Expert? Answer questions, earn points and help others
