Question about Schwinn Cycling
Light for schwinn
Switch to hook to fender light needs to be wired to turn on and off light
  • 55 Answers
So whats the problem?
Posted on Nov 05, 2008
I have a 1993 gsxr 750w with an aftermarket tail and when I hook all the directionals up only the front work. If the back Is connected by its self they work.
Hi, Steven you need a load equalizer before diagnosing any turn signal/running light/parking light issue make sure the bulb is good and the light fuse has continuity with a test light. If you have replaced you OEM lights with LED lights you are going to need a load equalizer. If no turn signals work the cause could be a faulty turn signal module or the connector going to it, look for corroded, loose, or broken pins/sockets. Contact spray cleaner is great for removing corrosion. If your speedometer does not function properly it will have to be fixed first because your turn signal module gets the data from the speedometer for normal turn signal function. If your front turn signals don't work use a test light to check for power and ground at the bulb socket, then start backtracking the wiring through every wire connector to the turn signal switch/button and check for continuity, go all the way back to the fuse if necessary to find the cause of the malfunction. If your rear turn signals don't work check your rear fender wiring harness connector first for corroded, broken, loose pins/sockets, power, and a good ground, (the harness connector is usually located under the seat on the front of the rear fender) then keep tracing the wiring look for obvious harness damage caused by the rear tire. If you still can't find the malfunction backtrack from the rear fender wiring harness connector. If one side does not work you could have a faulty turn signal switch or module check for continuity. For more information about your issue and valuable "FREE" downloads that you will please click on the links below. Good luck and have a nice day.
Suzuki GSX R750W 1993 Service Manual
OEM parts for Suzuki
http://mybikemanuals.com/suzuki/suzuki-gsx-owners-manuals
Sep 13, 2016 | Suzuki GSX-R 750 Motorcycles
Truck wont start
It could be the fender mounted starter relay under the hood. Or if you took off the small wire at that relay (its from the ignition switch), it should have voltage when the key is held in start. If it does have power in start, probably the relay. If no power in start, either the switch or the neutral safety switch is acting up.
Jan 24, 2014 | 1985 Ford F150
How to Restore vintage Schwinn
There are screws holding these on the inside of the fenders connected to the frame. You will have to take the wheels off to get to them.
Sep 08, 2012 | Schwinn Cycling
How do i adjust the fenders on the schwinn meridian trike so they don't rub on the tires?
The real problem is with the lack of serious fender mounting hardware from Schwinn. There needs to be a solid one piece brace connecting both fenders and attaching to frame at the seat support.
These fenders will wobble and bend with little or no effort or pressure. A SERIOUS DESIGN FLAW!!! SHAME ON SCHWINN ENGENEERSa09fa725-94b1-4de7-ac1b-7d7fc027737a.jpg
Apr 12, 2012 | Schwinn Meridian Adult 26-Inch 3-Wheel...
My turn signals do not work. I have power from my flasher relay to my turn signal switch. At the switch there are 3 wires I assume one is direct power from the battery and the other two are for each...
Hi, Jdbutler03 before diagnosing any turn signal/running light/parking light issue make sure the bulb is good and the light fuse has continuity with a test light. If you have replaced you OEM lights with LED lights you are going to need a load equalizer. If no turn signals work the cause could be a faulty turn signal module or the connector going to it, look for corroded, loose, or broken pins/sockets. Contact spray cleaner is great for removing corrosion. If your speedometer does not function properly it will have to be fixed first because your turn signal module gets the data from the speedometer for normal turn signal function. If your front turn signals don't work use a test light to check for power and ground at the bulb socket, then start backtracking the wiring through every wire connector to the turn signal switch/button and check for continuity, go all the way back to the fuse if necessary to find the cause of the malfunction. If your rear turn signals don't work check your rear fender wiring harness connector first for corroded, broken, loose pins/sockets, power, and a good ground, (the harness connector is usually located under the seat on the front of the rear fender) then keep tracing the wiring look for obvious harness damage caused by the rear tire. If you still can't find the malfunction backtrack from the rear fender wiring harness connector. If one side does not work you could have a faulty turn signal switch or module check for continuity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Turn signals arent working
turn signal problem
Kawasaki VN 750 Service Manual
OEM Parts for Kawasaki
1994 Kawasaki Vulcan 750 Owner Manual
Apr 22, 2017 | 1992 kawasaki VN 750 Vulcan
Schwinn women's 26" Windwood front fender doesn't fit correctly.
You have it on backwards.  I had the exact same problem.  Turn the fender around so that the arms that connect to the axel are pointing forward.  They are going to be almost parallel to the ground.  Easy Peasy lemon Squeezy.
Mar 15, 2009 | Schwinn Windwood 26 Women s Cruiser...
Cycling Logo
44 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
