Question about Leica D-lux 3 Digital Camera
Lens is stuck out, in telescopic mode
Lens won't retract back into the camera when I turn my camera off...OR when the camera is turned back on.  I can hear the camera "try" to move the lens, but it seems to be stuck
  • santosha Nov 05, 2008
    Tired the hard reset you advised...but no luck.
    Lens is still stuck "out".
  • 6,487 Answers
There's a possibility that some dirt are causing this to your camera's lens and the best way to resolve this is to take the lens apart and cleant but be very careful in doing that , and hopefully after cleaning everything will be working fine but if still the same problem there's a possibility that the lens itself is already bad....
Posted on Nov 05, 2008
  • 1,879 Answers
Use canned air around the lens area - even a small dirt will jam it since the clearance is very thin.
  • 13,433 Answers
Hi, since your camera lens is stuck / damaged. it will need to be taken apart and put back together possibly some parts might need to be replaced if damaged.
Your best bet is to contact your dealer if under warranty, if they charge you for the repair. Don't accept it a first sight.
Check www.advancecamera.com/repair and get a free repair estimate and see what is cheaper, ofcourse your dealer / camera maker might repair it for free incase its under warranty but I can't be sure of that.
Thanks, Let me know if you need anything else. Ekse
  • 10,594 Answers
You can try by push / pull lens gently while turning power ON of camera.
If this doesn't work camera needs Lens Assembly replacement and it would cost you more them camera worth. So option is to buy new camera.
Good Luck.
  • 790 Answers
Hello!!!
Try hard resetting once!!! Switch off ur camera , remove the batteries and press the power button for few seconds. then put the batteries back and try powering on!!
  • Kanth raj
    Kanth raj Nov 05, 2008
    Ok try this!!
    A stuck automatic lens cover is a fairly common
    problem, but it is normally easy to fix. A single grain of sand jamming
    the cover mechanism is normally the culprit, and you want to try to
    dislodge it: 1) Try blowing lots of compressed air around the lens
    cover to clean the mechanism. Or use a hair dryer for a few seconds
    (don't want to heat up the camera). Use no heat mode if possible. 2)
    Slide a thin strip of paper between the lens cover shutters and the
    outer support ring. Work it around 360 degres to clear out any debris
    that may be in there. 3) With the lens barrel extended and pointed
    downward, tap the lens barrel with a pencil while you extend and
    retract the lens by powering the camera on and off. Repeat the above
    three steps several times. If repeated tries don't work (keeping in
    mind that it usually does), it then may be necessary to open the lens
    barrel to access the lens cover mechanism.
    The
    lens cover mechanism is usually accessible for many cameras without
    needing to open up the camera case. Before starting, a reminder that I
    hold no responsibility should you damage your camera or worse. These
    repairs are intended as last resorts on expired warranty cameras that
    would otherwise be tossed.
    Sourcehttp://camerarepair.blogspot.com
My lens will not come out?
Fixing a Lens Error - Do It Yourself Digital Camera Repair
camerarepair.blogspot.com/.../fixing-lens-error-on-digital-camera.html
Dec 22, 2007 - Many camera makers will not honor repairing this problem under ..... i can view my pictures, and the lens does not come out, but when i just turn ...
Contact Stuck in My Eye: Please Help! - AllAboutVision.com
www.allaboutvision.com > Contact Lenses > FAQs
This can help "draw out" the stuck lens to the center of the eye where it can be easily removed. ... When the Contact Stuck in Your Eye Won't Come Out. If none of ...
Camera lens stuck? How to fix! - YouTube
? 3:01
https://www.youtube.com/watch?v=vJ6PLb21enY
May 31, 2011 - Uploaded by gearlock trinity
My camera telescopic lens was stuck and I fixed it, hope this helps! ... and I try it but won't work! and the ...
Jan 17, 2016 | Nikon COOLPIX L820 Digital Camera Deluxe...
How do I get the lens to retract, its stuck?
I would suggest taking it to the camera shop for repair. They are very touchy when trying a DYI repair.
Nov 18, 2014 | Nikon Coolpix L810 16 Megapixel Digital...
Konica Minolta Z6 camera lens won't retract or zoom out
I have the same problem. The lenses does not retract when turned off or function with the zoom control when turned on. Has anyone found a fix?
Dec 27, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Kodak Z700
Tentative solution:
I had the identical problem. I went as far as disassembling the camera ... not recommended.
Instead of fussing with the lens cover, I pressed on the lens assembly (gently), the lens retracted and the lens cover closed.
My camera works now. It will be my last Kodak.
Good Luck,
Mike
Jun 08, 2008 | Kodak EasyShare Z700 Digital Camera
Samsung camera power-on problem and beeping
same problem! camera HAD been dropped....carefully pull up with a gentle twist on the 'tilted ' side.
thanks for the tip! camera works fine!!
Oct 05, 2007 | Samsung Digimax S630 Digital Camera
Lens is stuck out
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 26, 2007 | Canon PowerShot A430 Digital Camera
Lens stuck
Aug 22, 2007 | Panasonic Lumix DMC-LC43 Digital Camera
Can't take picture
Needs to go back to Panasonic- an inherent fault.
Aug 16, 2007 | Panasonic Lumix DMC-LZ7 Digital Camera
Leica D-lux 3 Digital Camera Logo
Top Leica Cameras Experts
Steven Wander
Steven Wander
Are you a Leica Camera Expert? Answer questions, earn points and help others
