Question about Panasonic PT-47WX49 47" Rear Projection Television
Convergence issue i was watching a movie with my family and the convergence went out of alignment. I have walked through the convergence adjustments and a couple issues remain. First, on the convergence 1 settings, the large green crosshair is to the far left, when I try to move it to the right, the picture gets worse. Second, I have been able to adjust the red and blue converences so that watching tv is somewhat bearable, but the right side/edge of the picture is a bit wave and clearly not lined up. It seems impossible to get everything to line up. If i try to line up the right side, the left seems to get messed up. any thoughts/suggestions?
  • Anonymous Nov 15, 2008
    We have the same problem. Ours is the blue wont line up and goes wiggley across the screen. How old is your tv and where did you get it.
  • billy558 Nov 18, 2008
    I have the same problem. I'm wondering what the cost is to fix it. Thanks!
  • 3 Answers
Try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
Posted on Nov 24, 2008
Rca r52wh74 - no auto convergance
The model number of your TV probably falls under the ITC-222 chassis design. Do a search based on that criteria and it should point you in the right direction. If I remember right, you need to replace FL231 on the deflector board though. Good luck
Jun 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Go to menu then setup look for convergence if it is missing on menu then you have a open FUSE/ FL231, But if you have convergence on menu then go into service mode turnTV off then PRESS and hold at same time ch- and vol- wait for set to come on then release TV should now be in Factory settings.
Feb 20, 2009 | RCA D52W23 52" HDTV CRT TV
RGB lamps are not aligned
You need to replace the convergence chips and convergence resistors. Check the site They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Jan 18, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
On this particular model when your convergence is out of alignment, and the auto convergence is suddenly missing from the TV's menu all together, there is a easy fix.
Diode on Main Power supply, Location dl321 and fuse at Location fl231.
This problem has a high failure rate.
Jan 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Panasonic PT-47WX49 47" Rear Projection Television Logo
160 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
