Question about Acer AL1914B (Black) 19 in. Flat Panel LCD Monitor
Image distortion Recently my monitor has been acting up- screen will get intermitent black dashes across it that blink and change position rapidly. This gets increasingly worse over 30 seconds or so, until it's unusable. It generally lasts about a minute, then goes back to fully normal operation. Powering off/on seemed to help with this initially, but no longer does. Any ideas? Thanks.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 50 Answers
Might be a loose connection to your screen and motherboard.
I have the somewhat same issue with my Dell Inspiron 15, It's a touch-screen laptop and whenever you jerk the screen it'll either Freeze in like colored bars, or it will change colors. Both of which are annoying.
If anything, it may be a loose connection.
Posted on Nov 28, 2017
SOURCE: Acer AL1912 19" LCD Monitor goes black after power up.
The problem with this monitor is a leaking capacitor on the power supply board. It is the middle one at the top in a row of three. The value is 10V 1000uf. Common problem for these.
Remove 4 screws from back of display. The case can be popped apart with a small flat putty knife at different points along the two seams. Three latches on each side and two at top and bottom. Push and twist at the latch points. There is a metal cover over the two boards. Power supply board to left. Screws and plugs can be romved. Unsolder Capacitor and replace. Radio Shack probably has them. Maybe a couple bucks. Be sure the power has been off for a while. These also have problems with the button board and corrosion at ribbon cable.
Posted on Feb 28, 2008
SOURCE: No Signal message displaying after screen goes black
I have the same problem. Its really great to see that this is a known issue. I tried the solution of viziks, allthough my monitor still has the name ''plug and play monitor'' . I wanted to try to install new drivers, where can i find those?
Posted on Jun 11, 2008
bammbammfran
  • 159 Answers
SOURCE: RE:monitor goes black
Monitor going black after a few seconds can be causd by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Posted on Oct 05, 2008
bammbammfran
  • 159 Answers
SOURCE: Acer AL1917 Monitor does not start up immediately.
You'll need to have your power board -inverter redone.
The capacitors are starting to fail and that eventually will stop it all together.
I repair many monitors through ebay with these types of problems.
If you take it apart and send me a picture, I can usually see the problem areas.
ebays
bammbammfran
Posted on Nov 06, 2008
  • 86 Answers
SOURCE: al1914 screen goes blank and won't come back on
Is the computer shutting down when this occurs? If so its an indication that the power supply might be failing.
Posted on Apr 25, 2009
Wide screen stretches all my photos
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.
Dec 09, 2011 | Samsung Computers & Internet
Tip
Wide screen monitor distortion Depending upon the screen resolution that has...
Depending upon the screen resolution that has been set in Display, the image will be distorted on these large wide screen monitors.
To correct this distortion.
1. Create a large circle image using a draw program such as Paint (hold down the Shift key as you create the circle as it will draw a perfect circle).
2. Open Control Panel - Display - Settings tab and adjust the Screen resolution slider, increase or decrease the screen resolution then bring the circle image to the front and check the image, if the circle is still distorted then change the screen resolution and check the circle again until you are satisfied with the image of the circle.
3. When you are satisfied then click apply.
on Feb 24, 2011 | Computers & Internet
Black color screen
Change your screen resolution to the highest setting first, in control panel, appearance/ themes. Next Push smart button on bottom right of monitor. Cinema mode should be highlighted hit autoset on monitor. Next hit the FUN button and highlight the 4:3 screen setting. This will expand your image to fit the screen without giving it that stretched and distorted appearance.
Jul 18, 2010 | LG W1953TPF 19" Monitor
There are these lines of static, distortions across my screen that only visible in certain situations. For instance, as I am tying this the bottom of the words 'static, distortion' are distorted (looks...
Go into control panel, properties, advanced, monitor, refresh rate and select display refresh rates that my monitor can display and then choose which one best suites you and your problem.
Jun 26, 2010 | Gateway FPD2275W LCD Monitor
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
A box stating not optimum mode-get distorted internet images
Sounds like your resolution is not set correctly.
Try going to Start-->Control Panel-->Display and choose the Settings Tab
Under there change the resolution slider bar to 1280x1024
Should do the trick!
Jul 11, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Sony a100 distortion dots - Im getting several
If these are single pixels on the LCD screen, they are normal. From pg. 8 of the user's guide:
"The LCD monitor is manufactured using extremely high-precision technology so over 99.99% of the pixels are operational for effective use. However, there may be some tiny black points and/or bright points (white, red, blue or green in color) that constantly appear on the LCD monitor. These points are normal in the manufacturing process and do not affect the images in any way. "
This may also be helpful.
"images may trail across the LCD monitor in a cold location. This is not a malfunction. When turning on the camera in a cold location, the LCD monitor may become temporarily dark. "
May 03, 2009 | Sony A100 Digital SLR & 18-70 Lens Kit...
Screen image appears fuzzy, jumpy and broken up into lines.
gardenman13, I would certainly complain to HP about their w22 monitor!! Find out if the units warranty is still valid and can be swapped-out for a REFURBISHED unit. Your w22 shouldn't be hazy, distorted, or flicker for any reason. My best guess is that it (w22) has problems inside with it's "cold-cathode-fluorescent-lamps" and electronic ballast circuit called an INVERTER circuit, which could also cause the main "switch-mode-power-supply" to go a little NUTS upon STARTUP!! FYI you are dealing with a technology similar to the curlie-Q CFL screw-in light bulbs. Their ballast's are called CONVERTERs (ac to ac) and are cheaper. Your lanps are thinner and straight, hung on rear of your LCD panel. I hope this was informative. Please rate this on fixya. 12fixlouie
Dec 11, 2008 | HP W22 LCD Monitor
View sonic flat screen monitor trouble
I have a Viewsonic Flat Screen - recently I turn it on and all I see is like tye dye colors across the monitor with a slight ghost images of windows trying to boot-up. What can I do to fix this. The monitor is about 1 1/2 year old.
Sep 08, 2008 | Computers & Internet
22-inch Wide screen X2Gen LCD Monitor
Monitor Help CH000241, No display on the monitor. CH000242, Distorted or skewed image on monitor. CH000243, Monitor has a tint of one color.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Gateway FPD2275W LCD Monitor
Acer AL1914B (Black) 19 in. Flat Panel LCD Monitor Logo
77 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
