Worked fine for over a year. Had some work done on the car and since then I can hear callers when I answer or make a call, but they cannot hear me. What can I check?
Does anybody know where you can buy a new microphone?
For a Motorola IHF1000, the microphone connection is a 2pin black connector that connects inline to the power harness from the IHF1000 (Electronic Control Unit) ECU. See if that connection is loose. Also, if anything parts were removed on the path from the microphone to the Motorola IHF1000 ECU, the microphone wire may have been damaged.
Hey mawcab,
Based on the information provided it sounds like your microphone is not working. There a possibility it could simply be unplugged from the car kit control module. It will look like a head phone plug. If your car kit is aftermarket it was probably installed under the steering column. Check for a black box with an unplugged wire.
What type of work was done on the car?
Hope this helps!
Thanks for trying to help. I finally found out that the when the car was worked on, they must have crimped the speaker cord almost in half- making it un-useable. I had to replace the bluetooth unit entirely!
